Projects 1939 Packard Custom
Discussion in 'Traditional Customs' started by CadMad, Apr 15, 2020.
  1. CadMad
    CadMad
    2374065E-2A8C-4B17-BE58-A055507069C4.jpeg CA50DC5A-250D-44C0-B285-7196DDC23F4D.jpeg B41168BD-E4BA-4F5D-8041-9E963539567D.jpeg 3AC00D19-D105-4698-B86E-3675C943270E.jpeg 6DDB21FD-BCE1-4A45-9FE0-ECBC7DC497BA.jpeg Put in a full day yesterday. Focussed on door gaps and alignment of door. Welded in inner lower sill and it had the added bonus of pulling it all into alignment. Door closes like a bank vault now. I also added a little more sweep to the dash/armrest corner . Just about ready to turn her round and start on other door.
    ClarkH, Okie Pete, charleyw and 28 others like this.
  2. GordonC
    GordonC
    This thing is just so cool!
    Hnstray likes this.
  3. CadMad
    CadMad
    It really is “one piece at a time”. Made a stainless transition from firewall to cowl side. This will be bolted in place , not welded. Other side is mirror image. CD62D604-65B6-4701-875D-0B32B5A63CC8.jpeg 53E00B73-D374-4DE5-B96F-098A4E175ABC.jpeg
    GordonC, Okie Pete, Squablow and 13 others like this.
  4. @CadMad, let me just say that it’s high time you and Gene Winfield sat down and had a very long talk about customs. Just sayin.
  5. CadMad
    CadMad
    Gene has way too much energy for me. He’d wear me out.
  6. Ralphies54
    Ralphies54
    Just read and was blown away by 14 pages of fantastic body forming, you are certainly a master craftsman at you trade.
    I too like working with metal, mostly rust repair unfortunately, but If I opened my garage door each day and was greeted with the Strone about tools and debris that you seem to be able to work in and turn out the quality you do, well I would just close the door and go back to the sofa because I need some semblance of order to get any thing done. That said I am still in awe of your skills and am waiting to see and read more pages. Ralphie
    chryslerfan55 and partssaloon like this.
  7. CadMad
    CadMad
    42B6AEB0-EF7D-4B9D-A138-16F572265C97.jpeg Thanks Ralphie. I think. I work in a big team. Me and my multiple personalities.
    What appears as total chaos to everyone else seems to work as organised chaos (at least in my mind.)
    I’ve worked in a few immaculate work environments and I nearly went “crazier” achieving little more than cleaning up each day and polishing the tools and workshop floor.
    My brother came over a few weeks ago and we did a big cleanup .... and I’m still looking for bits that have been put somewhere by him.
    I do an 11 hour day most days. I figure that if I can live with it then that extra hour a day ordinarily spent cleaning up is better spent making something.
    It is getting better as each new bit goes onto the cars. But the Packard is my afterhours escape . I’m making unobtainable 53 Eldorado bits for half a dozen cars by work day. I’ve got a big workshop overhaul approaching and a mezzanine going in to give me extra storage . I nervously can see that soaking up a precious week of work time.
    Even got 18 ventilator bases done for one of my dad’s jobs over the weekend ( he’s 82 and still chases the odd job). So a lot of work is realised each week.
  8. CadMad
    CadMad
    Here’s what that valuable hour afforded me this arvo. Got the top piece of the firewall folded up. Still got to trim the top and put nutcerts in to hold it all together, 0E0DC359-EAD5-4AE4-AC5E-AF353F467D6B.jpeg but that is another day
  9. CadMad
    CadMad
    49E27ACF-00C0-4395-982E-7D93924DF42B.jpeg E2522630-CDF1-4118-91D1-41ECB5B9A2FD.jpeg Ok. Been busy on other stuff... but it’s time to build the other front fender. This was the good one. The other was twice as bad .
    I made a wire form template jig off the other side and then flipped it all over. First job is to add the 4 inch extension at the cut. Then the tapered rear. Then fill in the missing gaps. Easy!!! Very little of the original fender will be used.
  10. theHIGHLANDER
    theHIGHLANDER
    That's a Packard "Feathered Bail" radiator cap that heralds the early days. The variant before that one (still a feathered bail) was similar with a more rounded base. The early caps through about 28-29 operated by flipping the bail and tilting the cap open. The coachbuilders at LeBaron thought enough of it to use it on the iconic LeBaron Speesters of 1934. Quite elgant and less obtrusive than others, the bail adding another dimension of style to it. My personal favorite. Here's one on a 34:
    The spear on the side, nice touch adding the "hook" to the rear of that molding. A little trivia there too, in 1929 one of the coachbuilders (Brewster I think) noted a special town car by Hibbard and Darrin. May have been a Rolls Royce. They asked to borrow the spear design for a hood element on a Packard, but inverted, pointing down vs up on the Hibbard and Darrin car. It was a hit and became a design element for almost all Packard models through 1952 or 53. Seeing those design cues used without excess is the very essense of work like this. Good stuff mate.
    Okie Pete, Hnstray, brEad and 6 others like this.
  11. CadMad
    CadMad
    You nailed it Highlander. Yes, I’ve looked at all the elements individually and as a whole. As each new piece “becomes one” it is sometimes even a shock to me. It’s one thing to dream it and imagine it, but to see it in the metal is what motivates me.
    I’m glad you are enjoying the ride without turning a wheel.
    GordonC, theHIGHLANDER, brEad and 7 others like this.
  12. theHIGHLANDER
    theHIGHLANDER
    Wheels are turning, no doubt. They just spin in a different direction in this hemisphere...;)
    simplestone and loudbang like this.
  13. CadMad
    CadMad
    F44BE0B5-7E44-4E56-B1EE-3FC09DAD2A99.jpeg 908B1D92-0702-4DB6-AC36-23367BE9EA86.jpeg Fabrication and repair work is underway.
    ClarkH, Sandgroper, pwschuh and 17 others like this.
  14. Quentin, you're an artist! Just to say. what a build! i love to watch whatcha doin'. Cheers, Carsten
  15. CadMad
    CadMad
    My ex wife would say “******** Artist”.
    Hnstray likes this.
  16. choptop40
    choptop40
    best of the best....sir !!!
  17. CadMad
    CadMad
    75E550AD-335B-4586-92E0-6B9FBCE1AB99.jpeg Welded up. That’s a bit better. Now it has some form I can tap it up.... and then start on the nose.
    Sandgroper, Hnstray, brEad and 10 others like this.
  18. CadMad
    CadMad
    543CB539-5C40-4D5C-842F-5160C776602F.jpeg A89FB25C-F630-4FAF-9CB4-4C3C2BFE6D8D.jpeg C6151AD7-0978-48CB-92E0-1662FAACEEF9.jpeg Lots of wheeling in this piece. Nearly ready to weld it in.
    ClarkH, GordonC, ottoman and 18 others like this.
  19. Fabber McGee
    Fabber McGee
    Anyone else notice how much concrete is showing today? Wish my shop had that much uncluttered floor, haha.
    Hnstray likes this.
  20. CadMad
    CadMad
    Hahaha. Yes. My mate Pete came over yesterday and nearly had a fit and grabbed a broom. We found the lost ark of the covenant , the holy grail and my virginity. Still looking for my 1/2 inch ratchet spanner though.
  21. CadMad
    CadMad
    140CBF96-027D-4B8D-96C1-769C6054A7FB.jpeg Just welding in the nose makes a huge difference. What was a big floppy pile of **** is now a rigid form. Still gotta make the inner panel but it’s a huge psychological boost.
    40two, ClarkH, GordonC and 27 others like this.
  22. Squablow
    Squablow
    Looks fantastic.
    kidcampbell71 and loudbang like this.
  23. 1-SHOT
    1-SHOT
    from Denton
    41 GMC K-18, Hnstray and loudbang like this.
  24. Guy Patterson
    Guy Patterson
    Going to be a beautiful custom
    41 GMC K-18 and Hnstray like this.
  25. brEad
    brEad
    Great inspiration in that pic!
    41 GMC K-18 and loudbang like this.
  26. CadMad
    CadMad
    1B69FB48-39E0-4E70-AC41-BD2CE55C0C9F.jpeg I’m so excited.... so I’ll keep posting daily updates. Till you all get sick of it. I couldn’t resist the chance before work to modify the other 39 Buick headlight so I could see it’s face for the first time.
  27. j hansen
    j hansen
    Feel free to post twice a day, or more:D,,,think no one
    would get sick of it.
    And the face looks very good.
  28. simplestone
    simplestone
    This thread is always the first one I check! That front end looks great.
    Keep it going, man!
  29. 41 GMC K-18
    41 GMC K-18
    I have really been enjoying this build, its truly amazing to watch the progress, and the speed and accuracy of the progress is stunning!
    There are many metal masters out there in the world, so far the builds of Cody Wall's are simply amazing, but I have to confess, this particular build with its complexity, and the rapid updates, are a daily dose of "GOOD" that really makes my day !
    I would love to see Cody Walls and CadMad, square off at some neutral point on the planet, and have a compe***ion, that is a say a 5 day event, to see what they could accomplish in the realm of automotive creativity with some exotic materials and something that is challenging to them both!
    I will let your imaginations run wild, as to what the metal forming task would be, and of course, it should all be on YouTube for everybody to watch and enjoy and learn something!
  30. rotten ron
    rotten ron
    What a talent.
    loudbang and 41 GMC K-18 like this.
