Projects 1931 Roadster AV8 Build
Discussion in 'Traditional Hot Rods' started by 53studecoupe, Nov 30, 2019.
  1. sloppy jalopies
    sloppy jalopies
    don't know if it is because you needed to swap sides with the stanchions to get enough layback ?
    but the top "pins" should point forward and there is a bulge on the lower section of the stanchion that would be in the rear as a stop...
    also the tapped holes to mount the side curtain pins would be on the front side...
    i post this in case a guy sees your pix and doesn't know they are swapped... my $0.02
  2. 53studecoupe
    53studecoupe
    from Eagle WI
    I saw this coming and I am glad you are pointing it out. Yes I wanted the stanchions to lay back but because of the locking tab it doesn't allow that. Swaping sides then causes the ears to point the wrong way. This could cause the top to fold up while driving. Not sure what to do about it other than removing the tab and place the stanchions back. Can't be the first guy to encounter this. Any ideas?
  3. 53studecoupe
    53studecoupe
    from Eagle WI
    My solution was to drill a hole thru the pin or ear and drive the thumb screw into it. Just like it is originally but on the other side. One other thing that plays in my favor is the top is completely ridged when installed. By that I mean both bows can't move unless I unbolt them. The folding irons are fixed in the extended position when in place by a screw so they will not collapse either. This keeps a lot of tension on the stanchions.
  4. 53studecoupe
    53studecoupe
    from Eagle WI
    Here are some pictures of my header mocked up. 20210603_115035.jpg 20210603_114814.jpg
    oliver westlund, Jet96 and walter like this.
  5. 53studecoupe
    53studecoupe
    from Eagle WI
    Well it folds up behind the seat. I didn't expect that. This project is finished for now. Ready to start priming everything before it gets humid and my bare metal starts rusting. 20210604_180255.jpg 20210604_180315.jpg
  6. 53studecoupe
    53studecoupe
    from Eagle WI
    Went to a swap meet this morning and sold some spare model A parts.
    Hopefully I will not regret it.
    Anyway I scored an aluminum pressure plate 10" for a flathead.
    I believe it to be a Schaefer unit. To cheap to p*** on being brand new and with a special sindered surface. Screenshot_20210605-202033_eBay.jpg
    Jet96 and brEad like this.
  7. 53studecoupe
    53studecoupe
    from Eagle WI
    Update: out of the garage photo op. Sure could use some tire money 20210607_155750.jpg
  8. Tim
    Tim
    from KCMO
    Looks fantastic :)
  9. 53studecoupe
    53studecoupe
    from Eagle WI
    Thanks man....that means a lot to me.
  10. panhead_pete
    panhead_pete
    Feel your pain re tire prices :( Even sourcing them is becoming problematic with common sizes being back ordered. I ended up buying mine from this guy as Coker and Speedway were out of stock.
    https://www.ebay.com/usr/3910pplus
    If you are still trying to resolve the fuel tank the Bishop and Tardel book used a 1920-25 Mode T tank located to the left side and ran a battery box next to it. Apparently a perfect fit. Sorry about the sideways pic. 198201905_339404414210866_1022003712589135906_n.jpg
  11. sloppy jalopies
    sloppy jalopies
    remember that a round tank goes from 1/4 tank to zip in a hurry...
    a rectangular tank the same length and width will have its gauge level drop evenly from full to empty...
    hight times width times length... divided by 231 gives you its volume in gallons... HIH.
  12. 53studecoupe
    53studecoupe
    from Eagle WI
    I called Speedway last week and they had the big and Littles in stock
    As far as the tank goes I just wanted a little more volume than the T.
    This would not take up so much floor space ahead of kickup in the trunk.
    42merc and brEad like this.
  13. 53studecoupe
    53studecoupe
    from Eagle WI
    Ordered my Firestone tires from Speedway Motors Thursday. Already received the fronts and all 4 tubes today. No backorder for the 4.00/4.75-16 or the backs 7.00-16.
    Should have them mounted this coming week. Then we will really see how it looks. Meanwhile I welded in a fill in from the quarter to the package tray. I am sure this was covered with the interior but I have no plans for an interior other than the seat. 20210502_164600.jpg
    48fordnut, brEad and Tim like this.
  14. dmar836
    dmar836
    I really want to see it with those new tires!
    Tim likes this.
  15. Tim
    Tim
    from KCMO
  16. 53studecoupe
    53studecoupe
    from Eagle WI
    Me too! I am so used to the fat fronts I am sure I will be shocked by the small tires. 20210416_113700.jpg
    brEad likes this.
  17. 53studecoupe
    53studecoupe
    from Eagle WI
    Well here it is with its new shoes. It's going to take a little time getting used to. 450/475 x 16 front 700 x 16 back. 4" kickup in the rear with T rear spring 4 leaves removed. 4" drop front reverse eye 2 leaves removed. I think the stance is pretty good for the first try. The rear is a little tight to the fenders at the fender brace and the front tires look too far inboard for my liking. 20210615_150237.jpg 20210615_151641.jpg 20210615_150221.jpg
  18. 53studecoupe
    53studecoupe
    from Eagle WI
    What do you guys think? Good or bad
  19. brEad
    brEad
    Looks killer! I love an A with fenders.
  20. brady1929
    brady1929
  21. dmar836
    dmar836
  22. 53studecoupe
    53studecoupe
    from Eagle WI
    I moved the front tire out 1.5" closer to the fender. I like the look better. I might have followed the Vern Tardel book too closely. Being an open wheel roadster it wouldn't be an issue. Also the 4" wires are not helping any. 20210617_095127.jpg 20210617_094911.jpg 20210617_094617.jpg Not sure my next move or just live with it. Any thoughts.....
  23. j ripper
    j ripper
    from napa ca.
    I think it looks great narrow like you had it, but also looks good spaced out. I’m struggling with this now as I’m using a 32-36 axle with wishbone, so narrow like you had is out of the question. As for the rear, I did a spring behind setup to Model A wheelbase and it looks exactly like yours. Everything was just tacked up, so I cut the crossmember loose, shortened the TT (again) and I ended up taking close to 1” out of the wheelbase.
  24. 53studecoupe
    53studecoupe
    from Eagle WI
    I guess that is why we mock this stuff up early on. My options would be a wider dropped axle or do I dare say spacers?
  25. wheeltramp brian
    wheeltramp brian
    Car looks perfect to me.good job!
  26. warbird1
    warbird1
    Looks good to me narrow... centers the tire in the fender.
  27. sloppy jalopies
    sloppy jalopies
    bet the tires will rub alot less with the axle being narrow...
  28. 53studecoupe
    53studecoupe
    from Eagle WI
    You are probably right.
  29. 53studecoupe
    53studecoupe
    from Eagle WI
    Well it had to happen. I blew the car apart and finished welding a few things. Body finishing and priming will begin. Boring stuff really. I enjoy a good challenge in fabrication but it is coming to an end. Maybe I will build a gas tank cause I can.... 20210621_161141.jpg
    oliver westlund, brEad and warbird1 like this.
  30. getow
    getow
    Ha. I just noticed the upper shock mounts. Sweet
