Technical Hei wiring issue
Discussion in 'The Hokey Ass Message Board' started by Love_The_Lifestyle, Jun 4, 2021.
  1. Got an electrical question.
    55 Oldsmobile 88
    Car doesn’t have a solenoid or relay.
    Wires from the ignition
    Sol. Goes to starter
    Ign. Splits off. 1 wire goes to hei bat. The other goes to the alternator (plug 1)
    Bat. Goes to the battery.
    Wire from battery goes to the alternator lug then jumps to alternator (plug 2)
    The car starts with no issues. But it doesn’t die when you kill the key.
  2. 427 sleeper
    427 sleeper
    Disconnect the plug from the alternator and see if it turns off.
  3. I disconnected the jump wire that goes from the alternator lug to plug2 on the alternator.
    The car dies, but the battery doesn’t charge.
  4. Mr48chev
    Not an Hei issue it is an HEI wiring issue.
    The simple solution is to put a diode in the exciter wire so power doesn't feed back to the ignition.
    Something like this. [​IMG]
    That diode can be had from M***ey Ferguson tractor and probably Ford New Holland for a couple of bucks or you can readily find a similar diode. You can order the 1N5408 diode on Amazon and get a batch of them for about 6 bucks.
    Or if you have a Radio Shack that still has parts you can find them there. You just solder them in the wire and put a piece of heat shrink tubing over them.
    OzMerc39 and 427 sleeper like this.
  5. BamaMav
    BamaMav
    from Berry, AL
    Ignition is backfeeding from the alternator. You need to isolate the alternator hot wire from the ignition wire. Some cars have a diode in the ignition wire to prevent backfeeding like this.
    Mr48 Chevy typed quicker than I did...
    427 sleeper likes this.
  6. 427 sleeper
    427 sleeper
    Mr48chev types faster than me. What he posted is the problem.
  7. Doublepumper
    Doublepumper
    from WA-OR, USA
    Sounds like you need to add an anti feedback diode connector. antifeedbackdiode.jpg
  8. Mr48chev
    That would be really simple.
    I did find several offerings for those on Ebay but none from regular parts houses. one example.
    eBay item number:
    201247906131
  9. 427 sleeper
    427 sleeper
    That's a nifty little DoHickey you got there... :cool:
  10. Thank you! I appreciate it. Just ordered a pack from amazon.
  11. Thank you everyone who answered.
    ive always had someone else do the wiring cause wiring stresses me out lmao.
