Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. leon bee
    leon bee
    Backed the Hudson out under her own power:
  2. e1956v
    e1956v
    Alliance Vendor
    Ok round two today on getting the new windshield ****oned down. @&$”£€%#?$”:(
    How the **** did they get to the back A pillar to body studs to put the nuts on, on the ***embly line for ****s sake. I gave up again today and next weekend is the Tri-State swap meet in Denver, I hate cussing so much on Sunday it just ain’t right. I still have to do the drivers side and fight around the emergency brake and the hood release.
    3D4897A2-C851-4C03-9E84-A05AADAD622F.jpeg D9FA36BC-DC20-4B86-8A3A-FE605DC026D9.jpeg E297BB25-D03C-41DA-A9A8-86D6BFBD140D.jpeg
  3. RICH B
    RICH B
    Covered the header panel and installed the visors on my coupe. Probably should have switched out the windshield first; but what is the fun in not doing stuff twice.
    Elcohaulic, 40two, LAROKE and 2 others like this.
  4. topher5150
    topher5150
    40two, charleyw, LAROKE and 2 others like this.
  5. gimpyshotrods
    gimpyshotrods
    The manifold came in for my blower, so I stacked it all up.
  6. topher5150
    topher5150
    ok now you got me wondering
  7. j hansen
    j hansen
    We need an explanation of what this is!:)
    Sky Six and LAROKE like this.
  8. topher5150
    topher5150
  9. gimpyshotrods
    gimpyshotrods
    I will probably start a long list of complaints from the trad-police if I talk about it.
  10. gimpyshotrods
    gimpyshotrods
    Pluis the transmission is from 1966.
  11. spanners
    spanners
    The transmission might be from 1966 but it would've been designed in 1965 so it fits.
    LAROKE likes this.
  12. gimpyshotrods
    gimpyshotrods
    It was designed between 1962 and 1963, alongside the TH400 and ST400, which made the scene in 1964.
    This is a TH425, and debuted in 1966 in the new Olds Toronado, albeit as a FWD transaxle, facing the other way.
    It shares almost all of the same parts inside as a TH400. All the one-way stuff is just backwards.
    I have the fixed-pitch (the broken case being used for the mock-up) and a variable-pitch torque converter units.
    Atwater Mike, LAROKE and Max Gearhead like this.
  13. 210superair
    210superair
    from Michigan
    Yesterday was bath day to wash off all the big fat dead bugs from flying down country back roads with my buddy Mike....
    guthriesmith likes this.
  14. Blues4U
    Blues4U
    from So Cal
    I agree, I think a separate tech thread on this would be great.
    impala4speed likes this.
  15. Almostdone
    Almostdone
    Changing the lube in the rear end after the first 600 miles on the car. Don’t beat me up for having the rear on jack stands and the front on dollies. Giddyup.
    John
    Lil32, j hansen and 210superair like this.
  16. Sky Six
    Sky Six
    from Arizona
    Hells bells, I don't even have dollies. :)
    You'll get no grief from me.
    Almostdone and Chicster like this.
  17. hotrodjack33
    hotrodjack33
    Shoulda put the jack-stands on dollies too...and made it REALLY exciting;)
  18. gimpyshotrods
    gimpyshotrods
    I welded swivel casters to my jack stands. Much easier to roll the car around when it is on the stands.
    Almostdone likes this.
  19. milwscruffy
    milwscruffy
    Making room for these on this... 197657617_10218918141213741_2322083831206877594_n.jpg 199756074_10218918130813481_8330729646979597539_n.jpg 197614315_10218918131893508_5307636630048328314_n.jpg
    mgtstumpy, RICH B, Lil32 and 3 others like this.
  20. j hansen
    j hansen
    ^^^Nice^^^
    milwscruffy likes this.
  21. vtwhead
    vtwhead
    Lotta meat there! What is the plan for motivation?
  22. milwscruffy
    milwscruffy
    Blown, injected 398 C.I. 1st Gen. Hemi. Engine should be complete by late summer.
    mgtstumpy and Max Gearhead like this.
  23. Got the A out from its winter resting spot.
  24. TA DAD
    TA DAD
    from NC
    I took the lazy way out the first round and mounted the tank on top of the frame. that wasn't the look I was after so I re-did that and in the process had to notch the frame. Then It needed to be boxed, well are you just going to do one side ? But in the end it looks much better. studebaker build 009.JPG studebaker build 001.JPG STUDEBAKER BUILD 005.JPG STUDEBAKER BUILD 006.JPG
    Blues4U, Lil32, dehartcarl and 6 others like this.
  25. 32 hudson
    32 hudson
    Looks good ! Well done .
  26. TA DAD
    TA DAD
    from NC
    Thank you !
  27. RICH B
    RICH B
    Decided to start trying to close off the trunk on my coupe. I had collected some package shelf brackets off a derelict 5W and 5W front cross piece from a street rod shop. Made some mounts off the drip tray as I neglected to weld some when I made the tray and cut down the 5W shelf brackets to a fit the 3W. Followed up with a plywood shelf, the 5W front board, and some similar to stock wood under braces. All fit pretty good. Next need to get some ABS sheet for the inner panels. Also added the tack strip around the doors since the seat was out. Wish I had some windlace to add when I was in there. Next time I guess.
  28. Lloyd's paint & glass
    Posted on my build thread, but i got the seat back in, carpet, made a pleated cover for the transmission tunnel, and cut out a panel for the tailgate and carpeted it :D 20210614_155313.jpg 20210614_154820.jpg
  29. Lloyd's paint & glass
  30. saltflats
    saltflats
    from Missouri
    I ordered rod and main bearings. :)
