Technical Stripped window regulator repair
Discussion in 'The Hokey Ass Message Board' started by LongroofRon, Jun 6, 2021.
  1. LongroofRon
    LongroofRon
    Hopped in my wagon, went to roll the window down and it just went chunk-chunk, and the window didn't move... makes sense after 300+ thousand miles I guess. I pretty much always drive with the window down, so this was unacceptable. Basically rendered the car useless to me, I couldn't stand it. I sourced out another one at a junkyard, but it was used, so it was probably wore in the same spot anyway. Thus I decided just to fix my regulator, mostly because I'm cheap. Took some pictures along the way and figured I'd do a little write up on it
    ClayMart likes this.
  2. LongroofRon
    LongroofRon
    So here's the problem area. The rest of the teeth were okay, so I'm just going to fix the ones that were real bad. 20210530_130146.jpg
    fauj likes this.
  3. LongroofRon
    LongroofRon
    I cut out a piece of some similar thickness steel, clamped it to the bad area, and sprayed some ****m steel blue over it to transfer over the location of the teeth. 20210530_130826.jpg
    Ford52PU and fauj like this.
  4. LongroofRon
    LongroofRon
    I cut out the area in the old regulator to fit the patch in, and tacked in the new piece, making sure to line up the pattern of the teeth. 20210530_132318.jpg
    '40ford, Ford52PU, fauj and 1 other person like this.
  5. LongroofRon
    LongroofRon
    With the new piece on place I put a center punch mark for each tooth, in approximately the middle of the gullet for each tooth. 20210530_133007.jpg
    gary macdonald, Ford52PU and fauj like this.
  6. LongroofRon
    LongroofRon
    Next I dug through the drill bits and found one whose diameter matched the gullet of the tooth, and drilled out each center punch. 20210530_133524.jpg
  7. LongroofRon
    LongroofRon
    I cut of the excess of the patch, to a little larger than the major radius of the teeth. 20210530_134505.jpg
  8. Budget36
    Budget36
  9. LongroofRon
    LongroofRon
    I used a cutoff wheel to cut to the bottom of the tooth and rough it out, and them sanded the top of the teeth a little closer to their final height. 20210530_135115.jpg
    Ford52PU, LAROKE and fauj like this.
  10. LongroofRon
    LongroofRon
    I finished off each tooth with the file. A little tedious, but if you go one at a time you can test it as you go using the teeth in the crank. And just like that it's ready to go back together. The gears mesh pretty smooth, especially once it's in the door again, its hard to feel any hiccups. 20210530_140915.jpg
    Packrat, osut362, VANDENPLAS and 11 others like this.
  11. LongroofRon
    LongroofRon
    Just a quick demo, hopefully that will help someone fix a part they don't want to, or just can't buy.
    BigRRR, Budget36 and leon bee like this.
  12. X38
    X38
    Just missed tech week!
    fauj and anothercarguy like this.
  13. Marty Strode
    Marty Strode
    Now that's tenacity ! Good job.
  14. mohr hp
    mohr hp
    from Georgia
    That's pretty good. Lotta patience there. As an alternative, if you have a similarly worn spare, how about splicing in a good section of the spare's teeth from where it is less worn-to save effort?
    LongroofRon and RMR&C like this.
  15. brading
    brading
    Nice job you have made of that repair. You certainly have got patience
    LongroofRon likes this.
  16. ClayMart
    ClayMart
    Well played! Especially since it's the kind of repair that requires a bit of forethought and planning and not a lot of specialty tools and equipment that you may not already have in your shop. :cool:
    Wonder if this could have been done by clamping your repair plate onto the back of the regulator in an area where the teeth are still in good shape? Then, with the proper size bit, bore into the repair section using the existing teeth as a drill guide.
    :rolleyes:
  17. larry k
    larry k
    I just mig welded up the damaged teeth bigger than they needed to be , and ground and then filed them to size using the good ones as a pattern ,looks and works good .
    LongroofRon and fauj like this.
  18. 56MercMan
    56MercMan
    Looks good. The way I have repaired them in the past is just to weld onto the existing metal then shape the weld into the teeth. Has been holding for over 10 yrs now with electric windows.
    Looks like @larry k did the same and beat me to the response.
  19. Great work, very creative! Thanks for sharing!
  20. jimmy six
    jimmy six
    Restoring a car at $100 an hour is the reason some stop or never should have started. Your repair is they way I think. How can I do this myself? I just replaced a refrigerator part I had repaired 3 times that wasn’t available until lately. Call me cheap or resourceful but I will try almost anything and always have.... my dad was the same.
    fauj, Wanderlust, VANDENPLAS and 2 others like this.
  21. LongroofRon
    LongroofRon
  22. LongroofRon
    LongroofRon
    Oh true, that would probably be a better way to get a good transfer of the teeth profile. Just have to line up the edges, but the radius would be the same
  23. LongroofRon
    LongroofRon
    Exactly. Having a car that you can't buy parts for really taught me that lesson, but I'm glad I kept that mindset.
  24. F-ONE
    F-ONE
    from Alabama
    Kudos..to you.
    This is actually fixing something rather than replacing it. In the era of ****py replacement parts, more of us will need these types of skills.
    LongroofRon and Budget36 like this.
  25. Mr48chev
    All I can say is WOW, that is quite an effort and pretty well all hand done.
    LongroofRon and VANDENPLAS like this.
  26. Fortunateson
    Fortunateson
    Nice job! Mart at Marts Garage on YouTube just posted a video onthe weld up the worn teeth and file process. Man, the HAMB is so full of useful tech and great humour I don't know why non car people aren't members!
  27. 38Chevy454
    38Chevy454
    Good job on the rebuild. Agree that a home repair not only saves money, but gives great satisfaction in saving a part.
    fauj and Wanderlust like this.
  28. 40FORDPU
    40FORDPU
    A lot of time and effort, with a great result..well done.
    fauj likes this.
  29. trollst
    trollst
    Showoff.....I'd never have thought of that. Simple, so simple, I could do that, great idea.
    fauj and Budget36 like this.
  30. Greg Rogers
    Greg Rogers
