Technical The Supercharger Thread To End All Supercharger Threads
Discussion in 'The Hokey Ass Message Board' started by Speed Gems, Sep 30, 2019.
  1. seb fontana
    seb fontana
    from ct
    wfo I would make a big mess! A fellow suggested to slip the rotors in tight fitting tube and fill with a burret, should give volumn of cavities in each rotor, add them up. Sounds logical.
  2. seb fontana
    seb fontana
    from ct
    I have a Judson Vane Supercharger [VW-11] I plan to put on my Crosley; originally for a 36-40 hp VW. These have to be lubricated with a minuet amount of oil through a type of metering device. There is a fellow in CT about an hr away from me that rebuilds them and can help with the oiling system. Original application on the VW the Carburetor is removed and supercharger bolted in its place, carb bolted to supercharger. Add a pulley to the crankshaft and a drive belt. The supercharger main body is about 5" dia. 6" long. Made of cast iron so weighs a few pounds.
    Hotrodmyk, Jet96, j-jock and 2 others like this.
  3. Deuces
    Deuces
    It's for a minibike or go kart...:);)
  4. Deuces
    Deuces
    Thief!.... o_O;):)
    Actually, I found it here on the hamb.... Don't know which thread though....:(
    Jet96, loudbang and Speed Gems like this.
  5. s.e.charles
    s.e.charles
    tons of fun reading here: TheSamba.com :: Search the Site
    ever consider adding a single fog light ... ?
    (good looking ride!)
    Jet96 and loudbang like this.
  6. seb fontana
    seb fontana
    from ct
    Got two, much faster!!:) Thanks for thesamba.
    Deuces and loudbang like this.
  7. loudbang, seb fontana and Speed Gems like this.
  8. SR100
    SR100
    Looks like an Aisin supercharger, probably an AMR500. No idea about the long front drive or carb adapter, though. If you can find a clearer pic, you might be able to read the name on the drive. Looks like L??T???S.
    loudbang and s.e.charles like this.
  9. winduptoy
    winduptoy
    Spot on, It is an AMR500 that Loveless Performance is working on. I would say the conversion isn't mature yet but in process.
    It went like stink until the supercharger locked up. I've got new bearings in it but need to work on the drive....paying jobs and caregiving for parents have taken a front seat to the project....that's what I get for being a boiler repair man when it was 7 degrees F out this morning....
    Jet96, loudbang and s.e.charles like this.
  10. seb fontana
    seb fontana
    from ct
    7F = COLD!
    winduptoy and loudbang like this.
  11. s.e.charles
    s.e.charles
    winduptoy - good onya.
    projects can wait/ people can't.
    winduptoy, loudbang and seb fontana like this.
  12. Speed Gems
    Speed Gems
    Here's a new one on me. I did a search and only found 4 or 5 threads on them.
    Deuces, Jet96, mgtstumpy and 2 others like this.
  13. mgtstumpy
    mgtstumpy
    Jet96, Deuces, Montana1 and 8 others like this.
  14. alsancle
    alsancle
  15. loudbang
  16. loudbang
  17. loudbang
  18. loudbang
  19. mgtstumpy
    mgtstumpy
  20. JimSibley
    JimSibley
    I like my superchargers. 86F42015-A2DB-418E-9103-0FDDA9298D69.jpeg 4652A9CF-71F0-439B-B681-9BEA0BC2B469.jpeg 3FB9BDEE-6F8F-4EEA-B8D1-A6FDC15B0795.jpeg
    Jet96, 4tford, Speed Gems and 7 others like this.
  21. loudbang
  22. loudbang
  23. Saw this at car show last Saturday…..
    Don’t know if it’s old or new, just thought it was neat!
    Jet96, Fordors, loudbang and 5 others like this.
  24. Speed Gems
    Speed Gems
  25. 270ci
    270ci
    An early Tom Cobbs setup from the 50's. I believe Don Purdhomme owns it now.
    Jet96, Fordors, Deuces and 4 others like this.
  26. 270ci
    270ci
    A hairbrained deal I put together quite a few years ago.
    Jet96, Deuces, Dustyp489 and 4 others like this.
  27. Speed Gems
    Speed Gems
  28. loudbang
  29. loudbang
  30. loudbang
