Projects Wire Wheels for 1933 Ford
Discussion in 'Traditional Hot Rods' started by 50thstatenova, Jun 10, 2021.
  1. 50thstatenova
    50thstatenova
    Hi
    Thinking about switching wheels on my 1933 Ford to 52 Hot Rod Wire Wheels powder coated Red with 1933 Ford hubcaps and trim rings. Can I get any suggestions on this set up or should I keep wheels as is. Any input greatly appreciated. Thinking of going with 15 x 5 front and 15 x 8 in rear. Not sure of backspacing. Thanks, Wes Teixeira, US Army Retired. Currently living in Las Vegas.
  2. neds29
    neds29
    No opinion on the wheels but those are really nice flames.
    50thstatenova likes this.
  3. Bandit Billy
    Bandit Billy
    mahalo no kāu lawelawe ʻana
    I may have just insulted your mother or thanked you for your service, I intended on the latter.
    I wouldn't change the wheels, looks great the way it is! Spend the money you saved on golf balls and spam sandwiches.
    50thstatenova and warhorseracing like this.
  4. 50thstatenova
    50thstatenova
    Thanks Ned
  5. X38
    X38
    Keep the flames, keep the wheels.
    Get rid of the flames, then the wires would be okay.
    Blues4U and 50thstatenova like this.
  6. 50thstatenova
    50thstatenova
    Mahalo Billy Aloha, Wes
  7. 50thstatenova
    50thstatenova
    Thanks
  8. redo32
    redo32
    I think a Hot Rod should have Halibrand or 5 spoke, although I think grey spokes look tougher. Drop that side view over on the photoshop page and see if you like it better with wires.
  9. 2935ford
    2935ford
    Me too.....if wire wheels.....no flames!
  10. dirt t
    dirt t
    What is your bolt pattern?
  11. Kiwi 4d
    Kiwi 4d
    The above comments ,leave it as is, or no flames and wires mirror my thought exactly. Flames and wires just don't work together, in my mind anyway. Change for the sake of change ???
  12. 50thstatenova
    50thstatenova
    Ford
  13. 50thstatenova
    50thstatenova
    Agree with comments on leaving as is with flames. Thanks
  14. AULIZ
    AULIZ
    Looks good with flames and AR wheels.
    Looks older, if You sandblast spokes and paint those semi gloss grey (cast iron colour).
    Beautyful simple Rod !
    A
  15. Mr48chev
    Ok before some of you get your undies in a knot you can't untie. I dug out my secret decoder ring and came up with Hot Rod 52 Wire Wheels For Sale | Wire Spoke Rims | Truespoke Wheels
    Meaning the wheel he is asking about is a Truespoke #52 bare steel wheel that he wants to powder coat.
    Being that they are Truespokes I don't think bolt pattern is an issue. Nor is fitting to his drums/rotors or back spacing
    5thsatenova, if that is what you think you want, head on go for it. My best bud who p***ed away a couple of years ago ran True spokes on every rig he owned cool car wise and outside of one set rusting I never heard him fuss about them.
  16. jaracer
    jaracer
  17. Rocky
    Rocky
    Classified Editor
    Welp, when I first got my 34 on the street I picked up a set of 55 Chrysler wires, painted. They were 5 inches wide and the rears were widened to 7.5 inches. I had them powder coated and ran them for 2 years or so. All the time I really wanted to run old American Torque thrust wheels so I made the change. Glad I did. 34falleaves10_18.jpg 34nighttime11_20.jpg
    50thstatenova and CycleTech like this.
  18. poco
    poco
    from oklahoma
    Don't change a thing.
  19. dirt t
    dirt t
    I have 15" X 4.5" bolt pattern Chrysler wheels.
    I made an adapter and tac welded it to rim for hub cap.
  20. Blues4U
    Blues4U
    from So Cal
    That car looks *****in both ways, but I kinda favor the wire's, it's just a great look.
    Question about wire wheels, including the True Spokes, do you have to run a tube with those wheels?
  21. dirt t
    dirt t
    Tube , yes
  22. Rocky
    Rocky
    Classified Editor
    I didn't run tubes. I had the wheels sand blasted and powder coated. Then I ran a wide bead of quality silicone sealer around the center of the wheel where the spokes attached to the rim. Never had a problem with leaks.
