Technical Spinning push rod?
Discussion in 'The Hokey Ass Message Board' started by dumprat, Jun 10, 2021.
  1. dumprat
    dumprat
    from b.c.
    I have a new set of hot heads adjustable push rods, new lifters, and a reground cam. I have one pushrod that spins like crazy! It's a little noisy but I have never seen anything like this.
    Stogy likes this.
    Is it adjusted the same as the others ?
    have you compared it to another pushrod ? Could it be machined or ???? Something wrong and be defective.
    how much faster is it spinning ?
    On what cylinder ? Intake or exhaust ? Bad slightly collapsed or shorter push rod ?
    I dunno man I’m just throwing stuff out there strange issue you have .
    observation will be the key to success on this one !
    Stogy likes this.
  3. dumprat
    dumprat
    from b.c.
    Exhaust. Everything looks to be ok. Wonder if the cam has a little too much ramp or something?
    Stogy likes this.
  4. Mike VV
    Mike VV
    from SoCal
    The spinning lifter is causing the pushrod to spin.
    It's not the "ramp" that may be excessive, but the angle that the lobe is ground at, that "makes" the lifters spin.
    Could that lobe have too much angle...don't understand how, but most anything is possible.
    I'd give that lifter a check every now and again to make sure that it's in good shape and not eating itself and the cam lobe.
    Mike
  5. Rocky
    Rocky
    Classified Editor
    Let Hot Heads know what's happening.
    brushwolf and Stogy like this.
  6. dalesnyder
    dalesnyder
    If you have 15 pushrods that don't spin, you need to start planning your next engine rebuild.
  7. finn
    finn
    The cam lobe is causing the spin.
    Move the pushrod in question, and I suspect the spin will stay with the lobe, not the pushrod.
    If it stays with the lobe like I suspect, try a different lifter.
    The other possibility is that the lifter bore isn’t parallel to the others.
  8. Truckedup
    Truckedup
    pushrod spin is a result of lifter spin caused by the crown on the lifter face, the lobe design and most engines have the lifters offset to the cam lobe...
  9. dumprat
    dumprat
    from b.c.
    Not exactly easy to check on. I will move the pushrod and see what happens.
    They all spin slowly, just this one is way faster. The engine isn't broke in, I'm hoping it will calm down. Lifters seem noisy at this point too.
  10. I need some of you Lifter Scientists to school me as needed.
    Is a bad lifter that doesn't pump back up as fast as the other "normal" ones also a possibility??
    I'm wondering if that's why it checks out when it's adjusted with the engine at rest, but noisy and possibly loose when under operating load.
  11. 1971BB427
    1971BB427
    from Oregon
    The looser the adjustment, the faster a lifter/pushrod will spin. If one spins more than others, it's likely got more lash than the others.
  12. dumprat
    dumprat
    from b.c.
    @1971BB427 that sounds reasonable. I am going to try a more scientific method of adjustment tomorrow.
    Set the pushrod to slight drag, then put .020 preload with a dial indicator to measure it.
  13. 1935ply
    1935ply
    from peyton,co
    The hydraulics I set with a dial indictor at .050 - .060. If you were comparing it to a small block that would equal the one turn that is a common adjustment. The slow turning of a lifter is to keep them and the lobe from wearing.
  14. 1971BB427
    1971BB427
    from Oregon
    Yes, don't get them too tight! If they don't turn much, they'll wear out, not oil properly, or not let the valve fully close.
  15. dumprat
    dumprat
    from b.c.
    Dodge spec on the lifters is .050-.090
  16. Joe Travers
    Joe Travers
    from Louisiana
    What weight oil are you running? Lifters like a multi-weight oil, like a 10W-40. I prefer Lucas Hot Rod for high zinc content.
    Joe
    loudbang and Chicster like this.
  17. Budget36
    Budget36
    Curious on the pushrods wearing if they don’t turn, what happens with a roller lifter and the pushrod?
  18. Great question
  19. Jmountainjr
    Jmountainjr
    The pushrod spin is a result of the lifter spin. Flat tappet lifters need to spin so as not to wear the cam lobe. Roller lifters don't need to / can't spin.
    loudbang and Desoto291Hemi like this.
  20. Budget36
    Budget36
    I guess my question was more in regards to replies that indicated the pushrod needs to spin or it will wear.
    klleetrucking likes this.
  21. dumprat
    dumprat
    from b.c.
    Got it sorted today. Did a careful job of setting the valves and gave them one full turn of preload. About .030. It seems to be about right. I had a couple set with more than that and that bank of cylinders got noisy.
  22. dumprat
    dumprat
    from b.c.
    Btw ford small blocks with roller lifters used hardened pushrods in cop cars and taxi cabs. They actually wear the rockers out. Mustangs got soft **** pushrods.
  23. dumprat
    dumprat
    from b.c.
    Shell rotella 10-40. Engine runs at 60psi constant. It's running over the relief valve.
    Joe Travers likes this.
