Ez wiring harness
Discussion in 'The Hokey Ass Message Board' started by Michael Dieter, Jun 9, 2021.
  1. Michael Dieter
    Michael Dieter
    I have a 1964 Pontiac Catalina with the ez wiring 12 circuit I’m putting in my headlight switch the dash lights always stay on and on my turn signals I can’t get to work it seems my turn gauge ac/heat and coil fuse do not have any power to them when I test them with test light. Thank you for any help you would have
  2. squirrel
    These probably get power from the ignition switch? I'd check that the ignition switch is working.
    The light switch..you'll have to give more details about how you have it wired. Pictures help a lot. Some times dash light and turn signal problems have to do with the gauge cluster not being properly grounded.
    Michael Dieter likes this.
  3. Michael Dieter
    Michael Dieter
  4. The EZ Wiring fuse block has a couple of linked bars installed, which powers a row of fuses, either directly from the battery, or through the "on" circuit of the ignition switch. It appears by what you describe is the headlight switch is wired incorrectly and is powering the dash lights constantly. Gauges, a/c, and coil is usually powered by the on circuit, and sounds like no power supply. Squirrel is right, more info is needed.
    Michael Dieter and squirrel like this.
  5. How clear are the instructions? I always but THEIR headlight switch when I get a harness (not from EZ). Harness kits force you to do it their way and not the way the car was configured from the factory.
  6. You can sort out the removed factory headlight switch with an ohm-meter. Typically they have 5 posts. One power, two parking light posts, one headlight post, and one dash light post integral with a rheostat. It would help to have a factory wiring schematic. With that and the EZ kit instructions, things will be much easier.
    Michael Dieter and alanp561 like this.
  7. Here is wiring info for GM headlight switch:
    loudbang and Michael Dieter like this.
  8. Michael Dieter
    Michael Dieter
    I have a factory wiring diagram and the ez wiring for headlight switch
    White wires go to door jam
    Red wire goes to fuse power
    Green wire is unfused power
    Gray wire is dash lights
    Brown wire is parking lights front and rear but dash lights will stay on but everything else works as should
    now the ignition got tricky had 8 prongs but only used 4
    Ing sw coil and the ign sw ing wire to took to prong labeled 2
    Ing sw power took to the b prong
    Ing sw start took to the s prong
    Ing ACC took to the a prong
    now for directional signal
    Purple to flasher wire
    Yellow to lr turn
    Green to rr turn
    The double light blue is with left indicating light and left front signal
    The double dark blue is right indicator and right front signal
    I know it’s a mess I’ve never done this before and wanted to learn but now I’m getting kinda overwhelmed thank you for any help
  9. I'd work on one thing at a time, until that is accomplished, then move on, in this order.
    1. Ignition switch
    2. Headlight switch
    3. Turn signal problem
    4. Other?
  10. Michael Dieter
    Michael Dieter
    I think the ignition switch is right and working but I maybe wrong and that might be why I’m having problems else where
  11. I have installed 2 kits in the past that the signal flasher did not work. First kit I looked for hours what the problem may be , 2 kit it was evident much quicker .
  12. Michael Dieter
    Michael Dieter
    If I use the hazard wire on the purple wire And take out the purple wire from flasher everything works but works through the hazard fuse and relay but works with car off because of being hazard wire and that I’m asking for problems if leave a signal on
  13. Michael Dieter
    Michael Dieter
    So messing around with wiring some should the coil and and see start wire go to a prong on ignition that has power when key is on or a prong that has power only as cranking ? I put it on prong that had power with key on and it gave power to my fuses that weren’t getting power so I do have my ignition wiring messed up any help would be appreciated
  14. Coil pink wire should have power when car is running.
    The small purple wire to starter solenoid should only have power in the start position of ignition switch.
  15. Michael Dieter
    Michael Dieter
    That’s a wiring diagram of cars old wiring and a photo of the wires I have with new harness
    the one prong has power when cranking now when car starts to m not sure if it keeps power I don’t have car to that point yet, but I think that’s the one I would want to starter solenoid because the power probably shuts off after, now the coil should that only get power after the car starts up or when key is turned forward ?
  16. The ignition switch, the wire pin for the coil is the one with power in BOTH run and start.
    Do you have a meter so you can put key into switch and see which connectors are active in each key position?
  17. Michael Dieter
    Michael Dieter
    I do have a meter what should I be looking for when I use the meter, I used a test light earlier and saw the prongs that turned on when turned key to on and the ones that turned off when key was off and one prong light up as I held key and turned motor and stopped lighting when I stopped cranking but left key on
  18. Does one pin get power in both start and run? I hope so, for the coil.
  19. 5brown1
    5brown1
    I received great service from the EZ Wire tech support when I had a question. I have installed two of their kits.
  20. Michael Dieter
    Michael Dieter
    I have not received the same service as you, I’ve tried emailing and calling with no reply’s
  21. I use the ohm meter rather than a battery and test light. I try to keep battery disconnected when I'm working.
    Set the date ohm meter to a small/low number scale like 20 ohms.
    One lead goes to battery input on switch. The other lead you move from pin to pin while setting the key to each of it's four positions. Much the same as using a test light. Just don't have to deal with 400 cold cranking amps in your workspace.
    Sounds like you are making progress.
  22. Rebel Wire appears to have a superior tech support as they are an Alliance Member here and frequently offer tips and assistance in a dedicated thread here. While I have no experience with EZ Wire I am glad I went with a Rebel Wire kit.
    j3harleys and 325w like this.
  23. 1971BB427
    1971BB427
    from Oregon
    Only time I've ever had trouble with new wire harness kits is when I had to re-pin the connector for lights, and signals on the column. Both times it turned out to be pinned wire connectors that didn't hold when plugged in, and simply pushing the individual wires in on both sides of the connectors fixed the problems I saw.
  24. Rebel is good on customer service, so is Kwik Wire. I called them to verify what I already thought was right. Now they put more information up on their site.
    j3harleys likes this.
  25. Michael Dieter
    Michael Dieter
    Thank you I will give that a try when I get home from work and I think I am making lead way on the project sometimes I just have to walk away for a bit and come back later to it I will let you know how I make out with it thank you.
    pprather likes this.
  26. Mr48chev
    The dash lights feed off the rheostat. Turn the rheostat switch all the way one way and you turn the dome lights on because you ground the dome lights just as you would when you open the door and the door button grounds them. Turn it the other way and it controls the power to the dash lights to control how bright or dim you want them. That should feed from the head or park light power and only come on if you have the switch in either head or park light position.
    I'm with Pprather in that I use an ohm meter to figure out where the circuits go and how they feed.
  27. Michael Dieter
    Michael Dieter
    So I got car running and everything working properly minus the horn and done lights not turning off with door switches ? The horn will beep if I push the the button with my test light grounded so I’m thinking it a ground issue and the dome light I’m kinda at a loss
  28. I think dome light switches complete the ground circuit.
    Can others confirm?
  29. AngleDrive
    AngleDrive
    from Florida
    Yes, normally they do. Power is fused then sent to dome light. Also some headlight switches have ground on rheostat to switch the dome circuit on.
  30. Michael Dieter
    Michael Dieter
    There is no switch at dome light but not that I look at it I have the headliner out of car I wonder if housing is grounding to the roof of car and that’s completing the circuit and causing the light to stay on ?
    bobss396 likes this.
