Looking to Get Started...
Discussion in 'The Hokey Ass Message Board' started by Tribalmonkey, Dec 14, 2020.
  1. lothiandon1940
    lothiandon1940
    I realize yours is metal, but most gl*** roadsters have a metal bar behind the dash, running from one side to the other. It helps stiffen up the entire cowl section for sure and helps to minimize "cowl shake". A bulkhead behind the ****pit between the interior and the trunk will go a long way in adding some structural stability to the whole car.
    Joe Blow, Tribalmonkey and loudbang like this.
  2. tb33anda3rd
    tb33anda3rd
    once all the repairs are made to the body, and the body is properly mounted to the ch***is they are "fine". boxing the ch***is will improve it.
    Tribalmonkey, Dustyp489 and loudbang like this.
  3. Tribalmonkey
    Tribalmonkey
    Thanks Joey! Very excited to get the new/old windshield frame.
    lothiandon1940 likes this.
  4. Joe Blow
    Joe Blow
    That's kinda/sorta what I did on my coupe Don. When I rewired and moved the battery up front, I put a piece of angle iron across the back side of the firewall - from brace to brace. Gave me a place to hang the battery, place to mount terminal blocks and a wiring channel.....and really stiffened the body.
  5. Tribalmonkey
    Tribalmonkey
    Thanks Don and tb33anda3rd! I was thinking the same thing. Should I get the measurements or just eyeball it? Hate to permanently stiffen the cowl and bulkhead without the proper dimensions. TM
    lothiandon1940 and Joe Blow like this.
  6. Tribalmonkey
    Tribalmonkey
    Joe Blow- I like the angle iron solution. What did you do behind the seat?
    lothiandon1940, loudbang and Joe Blow like this.
  7. Joe Blow
    Joe Blow
    Thanks man. Metal bulkhead between the trunk and interior.
  8. Tribalmonkey
    Tribalmonkey
    Found these at a flee market for $1. Seems like good flare for ‘Ratty’. 71A0071C-5B6A-4241-A34A-B0F7833825D5.jpeg
    loudbang, Joe Blow and lothiandon1940 like this.
  9. Tribalmonkey
    Tribalmonkey
    Cool Doodle Bugs at the Flee Market/Tractor Pull.
    032BFA40-2590-449E-9395-BBF40D929666.jpeg F412738E-C910-4F92-8937-4B97721FA8BB.jpeg 573EC7F0-4401-4811-A489-F4FED45EF70F.jpeg 6796D6DE-6298-4FE6-86D7-420B136EC2E0.jpeg
  10. Tribalmonkey
    Tribalmonkey
    I worked this evening on the Roadster. I’d say the motor runs great; however, the steering and front end are shot. Steering box would need a complete rebuild and I’m not sure that would do it. The king pins have excessive play. I also see movement in the spring perch radius rod areas.
    I think my priorities right now are to:
    1. Fix the steering by either finding a better condition model a box or swap over to F1 steering if I can find something.
    2. Replace much of the front end with the Okie Joe drop axle I have for my coupe. I have new 32 spindles, spring perches, and king pins all set up with the axle.
    3. Get a seat.
    4. Clean and seal the fuel tank.
    5. Fix the brakes.
    6. Fix the windshield. I should be getting my Ukrop replacement frame sometime this week :)
    I still need to make some decisions.
    -Do I work on the mech brakes or start the move now to juice? I don’t have any of the juice parts.
    -F1 steering now or just get a model a box? Same. I dont have the F1 parts.
    -Take my fuel tank somewhere to clean and seal or try to do it myself?
    I still would like to get the roadster on the road soon with the banger and do the A-V8 build over the winter.
    Open to your recommendations. TM
    loudbang and lothiandon1940 like this.
  11. Tribalmonkey
    Tribalmonkey
    A few things. First, I went through all the adjustments on my two tooth steering box and then added oil. The oil pretty much ran right through. 8D7EC21D-4721-478B-B95C-24BCC231826D.jpeg
    Then I realized that the drag link and tie rod have been wearing against other for some time now. Maybe a shorter pitman arm would solve this. 6FC989D1-127C-4267-8A5E-4788F0386D49.jpeg
  12. Tribalmonkey
    Tribalmonkey
    Also started cutting some unneeded riveted parts off the frame. BB2C553B-7F3C-40EC-BD8A-08B063B7E603.jpeg
    loudbang, Joe Blow and tb33anda3rd like this.
  13. Tribalmonkey
    Tribalmonkey
  14. Tribalmonkey
    Tribalmonkey
  15. Tribalmonkey
    Tribalmonkey
  16. Tribalmonkey
    Tribalmonkey
    3C717802-AEC6-45DA-A513-A55B158428C3.jpeg 120E344A-C689-4181-99FE-31DB93A9B8F0.jpeg Started the effort to clean the inside of the gas tank. Added 16 bolts to help with the process. First, one gallon of lacquer thinner. Shook. Drained. Next, 2 gallons of gas. Shook. Drained. X 4. Then dish soap and water. Rinsed x?? Then one gallon of Evaporust. Turned it about every hour.
    I plan to let it sit in the bottom tonight and then turn it several times tomorrow. Will that be enough? I doubt it. I have Red Kote once it’s ready to seal.
  17. tb33anda3rd
    tb33anda3rd
    I would avoid the sealer unless you cut the tank apart and blast the inside to make sure you have ALL the mess out. sealer over loose scale or crud will break loose and cause a worse problem.
    you could clean it the best you can and install the original type shut off with a short stand pipe. this will pick fuel up above the bottom of the tank, so any remaining or anything else that breaks loose won't go down the pipe.
    greaser, Tribalmonkey and loudbang like this.
  18. tb33anda3rd
    tb33anda3rd
    here is a look at the baffles. don't cut open the face side like this. IMG_9789.JPG IMG_9790.JPG
  19. Tribalmonkey
    Tribalmonkey
    Thanks for the advice! Not a moment too soon. I will just try my best to clean it up and remove as much rust as I can. I may have to get more rust remover as I am not confident one applications going to be enough for this one.
    Not sure about the valve and the stand up pipe. This is the 31 that has a pipe and valve outside the firewall.
  20. F-ONE
    F-ONE
    from Alabama
    Whatever you you do do not use Muriatic Acid.
    Oh it'll get rid of the rust but.....
    It's too hot. That stuff is for cleaning concrete.
    Muriatic Acid will also chlorinate the steel. It's like bleach, not on the steel, but in it.:eek: It cleans it but eventually it'll rust and rust away very rapidly.
  21. Tribalmonkey
    Tribalmonkey
    More great advice. I’d be making mistakes left and right without you guys. Thanks!
  22. Tribalmonkey
    Tribalmonkey
    My plan is to rinse the evaporust out with water later today or tomorrow morning, dry the tank with a heat gun, coat the inside with Marvel Mystery Oil to keep from flash rusting, and then install it and start using it. Good plan?
    tb33anda3rd likes this.
  23. Tribalmonkey
    Tribalmonkey
    Something that alludes me…. Lots of talk about using a ‘T’ spring in the rear… sounds good…
    Where are all these ‘T’ springs? Where do I get mine? TM
    Joe Blow likes this.
  24. Joe Blow
    Joe Blow
    They're talking about a Model T spring. A modified (less leafs) reversed eye Model T spring lowers the rear end about 2 1/2" from stock.
    Tribalmonkey and lothiandon1940 like this.
  25. Tribalmonkey
    Tribalmonkey
    Thanks for the response Joe Blow - I understand what it is. I have seen threads where people are saying they are laying around all over the place. Where can I get one? Used?
  26. Tribalmonkey
    Tribalmonkey
    UPS guy brought my @J.Ukrop deluxe windshield frame today! 856659E2-A7A8-45B6-B64A-BFF8B3E39FBC.jpeg
    Also got a cool old post card from Magic Mountain :)
    Dannerr, Tim, J.Ukrop and 2 others like this.
  27. lothiandon1940
    lothiandon1940
    ...........Eaton Detroit Spring would be the first place I would look. Posie's maybe as well. I don't know where to look for a used (real) T spring.
    Tribalmonkey likes this.
  28. Tribalmonkey
    Tribalmonkey
    Thanks Don. Yeah… same here. I thought maybe there was some treasure trove of T Springs that I didn’t know about. Didn’t they make about 15 million T’s?
  29. Joe Blow
    Joe Blow
    Doh!......sorry bout that.....was taking it literally.o_O There was a member on here a couple of years ago selling new modified T springs for lowering the rear end. Can't remember who it was.
    lothiandon1940 and Tribalmonkey like this.
  30. Joe Blow
    Joe Blow
