Projects ONE PIECE AT A TIME ('47 FORD COUPE)
Discussion in 'The Hokey Ass Message Board' started by topher5150, Mar 1, 2017.
  1. topher5150
    topher5150
    Saw this made me think of me
    1Nimrod, brEad and Thor1 like this.
  2. topher5150
    topher5150
    Time for a fresh air break. Does this stuff come in gallon?
  3. topher5150
    topher5150
    Made some seat brackets to
    1Nimrod, Okie Pete, bobss396 and 2 others like this.
  4. topher5150
    topher5150
    Got the back seat in place and I got to say I'm pretty impressed with the headroom back here... Leg room not so much
    1Nimrod and Okie Pete like this.
  5. phat rat
    phat rat
    Your seat back must be awful thick or you really tipped the bottom forward. The front of the bottom cushion in mine is barely overlapping the drop to the floor and my car is a business cpe
    1Nimrod likes this.
  6. topher5150
    topher5150
    Mine is a club coupe so I have the full seat in the back. There's a piece of wood that attaches to do B pillar to support the front of the cushion bottom
  7. phat rat
    phat rat
    I know yours is a club cpe. I mentioned that mine was a business cpe but I put a full rear seat in it. Your back seat is way too big for the car. I had 2/3 guys in my rear seat riding around one time. Just trying to help you out with your problem. Now I'll put it to rest
    1Nimrod likes this.
  8. topher5150
    topher5150
    Started on the driver's side come to find out I left the gas on from earlier this week so I tacked everything in place until I get more gas.
  9. banjeaux bob
    banjeaux bob
    from alaska
    My buddy Paul has been working on his '46 Merc longer than I have known him(37 years). It's looking pretty good. It's been low budget all the way. I asked him just the other day if he kept a journal and had pictures of the journey. Nope.
    1Nimrod and Thor1 like this.
  10. topher5150
    topher5150
    That's as long as I've been living
  11. topher5150
    topher5150
    Made some brackets to fit the holes of my previous seat layout
  12. topher5150
    topher5150
    Got some more work done on the back seats. I used the old lower seat hooks they don't seem to work as well as I thought they would.
    Got the front seats in place messing with the recliner
  13. topher5150
    topher5150
    Well today went from bad to worse. I tried changing the ****** cooling lines on the wife's car couldn't get it unhooked so I put it back together for someone else. Went to get burgers and it died in the drive thru. Got a call from the mechanic and said that the cooling line to the radiator snapped inside so now I need a new radiator.
    Wasn't able to get a ride to work today so thought I'd make the best of it and got some more work done on the headers IMG_20210719_090744340.jpg IMG_20210719_111054073_HDR.jpg
  14. 1-SHOT
    1-SHOT
    from Denton
    Good excuse to work on your hot rod
    1Nimrod, brEad and topher5150 like this.
  15. topher5150
    topher5150
    The wife says I need to take more time off. So what do I do on my day off I work
    1Nimrod, Okie Pete and Thor1 like this.
  16. spudshaft
    spudshaft
    I may have missed it, but what are the new front seats out of? They remind me of tbird seats. I’m enjoying your posts on your project.
  17. topher5150
    topher5150
    thank you. The front seats are from a 65-66?? Thunderbird and the steering wheel is from a 68 Thunderbird
  18. 1-SHOT
    1-SHOT
    from Denton
    Is it one of the swing away columns for easy entry and exit?
    1Nimrod likes this.
  19. topher5150
    topher5150
    Just the steering wheel is T-bird, the column is from an 80s Bronco.
    1Nimrod likes this.
  20. topher5150
    topher5150
    Putting some ideas together for my exhaust maybe a small cover so you don't see it go though the fender.
  21. topher5150
    topher5150
    I swear I've spent more time and money in a single day on my wife's got-dang car than I have on the hot rod all year. At this rate, she is going to have a brand new car by the end of the year.:mad::mad::mad:
    ==Sorry just needed to rant a bid==
  22. 1-SHOT
    1-SHOT
    from Denton
    What’s the temperature rating on those side pipes? That’s cheaper than building some and decide you don’t like them. Good idea
  23. topher5150
    topher5150
    I wanted to see how it would hook up with the headers I'm making and it seems pretty straight forward. The plan is to run them through the back of the fenders where the running boards would go. I found some on speedway that are a little larger dia than lake pipes but have built in baffles
  24. 1-SHOT
    1-SHOT
    from Denton
    My experience with side pipes they get a drone effect and annoying. I have had them on several Vetts.
  25. topher5150
    topher5150
    I don't know why I've been putting this off for so long but I'm glad that I finally got the fender apart, stripped, sanded, and some primer
  26. topher5150
    topher5150
    Found out there is a junkyard with lots of older trucks right down the road from where they're having the northern Nationals. $100 and an hour later I got a column and a Holley double pumper IMG_20210911_121518416_HDR.jpg
    1Nimrod, Okie Pete, RICH B and 2 others like this.
  27. topher5150
    topher5150
    Not the most traditional exhaust but on the flip side I won't go deef
    1Nimrod, Bandit Billy and brEad like this.
  28. topher5150
    topher5150
    Thinking out loud...I have a GM p/s box would modifying the stock Ford drag link to fit the GM pitman arm be something easier than trying to bend a pitman arm
  29. topher5150
    topher5150
    Went junkyarding today with my Christmas money and finally got a set of usable steelies. IMG_20220101_132829600.jpg
    1Nimrod, Okie Pete, brEad and 2 others like this.
  30. topher5150
    topher5150
    Went to the Kazoo swap meet today. It was pretty pretty sad about half the tables were empty only in the main building. I only saw two trailers outside. On the bright side I found a twin for my spotlight and another huh cap IMG_20220205_130334213.jpg
    1Nimrod, Okie Pete, brEad and 4 others like this.
