Projects 33 3 Window Coupe
Discussion in 'Traditional Hot Rods' started by pennafxu, Mar 4, 2021.
  1. pennafxu
    pennafxu
    from Kentucky
    About 1 month for this then I will flip it...
    Tim and loudbang like this.
  2. pennafxu
    pennafxu
    from Kentucky
    Last one on this side...
    Hopefully the block checks out... the last piston on this bank was giving me fits. But I got it to go in the end.
    patmanta, Tim and loudbang like this.
  3. pennafxu
    pennafxu
    from Kentucky
    So completely done with this block!! Yay. Now off to the machine shop.
    Nailhead A-V8, patmanta, Tim and 2 others like this.
  4. dumprat
    dumprat
    from b.c.
    Doesn't even look like it has the common bolt hole cracks! Nice.
    loudbang and pennafxu like this.
  5. pennafxu
    pennafxu
    from Kentucky
    I will be relieving this if it checks out to lower the compression. Probably will port and polish too.
  6. pennafxu
    pennafxu
    from Kentucky
    Will use this as a template for the other blocks...
  7. pennafxu
    pennafxu
    from Kentucky
    He may be in hotrod heaven, but his knowledge lives on
  8. pennafxu
    pennafxu
    from Kentucky
    IMG_1951.JPG IMG_1952.JPG IMG_1953.JPG IMG_1954.JPG IMG_1955.JPG IMG_1956.JPG IMG_1957.JPG
    Can’t wait to try this out in my 3 blocks
  9. pennafxu
    pennafxu
    from Kentucky
    Got the engine ready for delivery… 34C8E1FC-4794-4937-B9A0-9B42175DC4C0.jpeg 63CDFD0E-29C0-4215-AC90-B28BCB41FE68.jpeg 2C52D362-DA53-46EF-8A19-FCB3E760DD43.jpeg F71A2A8F-DB8C-4FB0-A0FC-1E346B89C7C3.jpeg
    Nailhead A-V8, Tim and brEad like this.
  10. pennafxu
    pennafxu
    from Kentucky
    Will yank out the soaked engine here shortly…
    brEad likes this.
  11. pennafxu
    pennafxu
    from Kentucky
    2753CD68-FA16-4023-AA1A-275248787B83.jpeg D5AFC104-73D8-425A-B9D9-B6ADE6AC5581.jpeg
    Vic Walter, Tim, brEad and 2 others like this.
  12. loudbang
    brady1929 and pennafxu like this.
  13. 4ever18
    4ever18
    They are, in deed, 2 door sedan doors. Lots of folks convert them to 3 window coupe doors. He will need to fabricate a replacement top, rear corner of the door. Since the plans call for a heavy chop, the original 3 window coupe top door hinge will be eliminated.
    as for fabrication of the new door top corner, guys have used the front, rounded door tops from another door - or fabbed the door top from scratch. Lazze has a YouTube video showing how he uses a bead roller to make these new door tops.
  14. pennafxu
    pennafxu
    from Kentucky
    Preach brother preach!
    loudbang and 4ever18 like this.
  15. pennafxu
    pennafxu
    from Kentucky
    Something’s wrong with you… lol
  16. pennafxu
    pennafxu
    from Kentucky
    0770AD96-ED75-4BC3-B473-CA072658356F.jpeg 0770AD96-ED75-4BC3-B473-CA072658356F.jpeg ABDBF4F5-ACB7-44B3-989D-8B9D6EC842D5.jpeg D3C94F6D-430A-4455-93B2-CBCB569CDFA2.jpeg 6FFDE446-1BDE-4449-B9D9-5A67F6F6B9F6.jpeg 3D742424-DC27-4C2E-8E85-7F892E674093.jpeg 4E45500F-E1DF-4E7E-B4A5-A01BDCE02FAB.jpeg
    This went a lot easier… I wish I had presoaked the other one in the primordial goo like this one… the crank turned very easily!! Unfortunately the lifter ***embly will need cut out as it won’t budge… Now my next block will be even easier, yippee!
  17. pennafxu
    pennafxu
    from Kentucky
    D6D4DFA0-710F-4591-A6B6-EE1BCAD65CD5.jpeg D095FD3B-63D2-4E76-9ED1-4F7ACBA76E76.jpeg 0064AA54-6319-491A-809A-7FF15902F5B6.jpeg 51AB2BD5-C8B7-4150-B8B8-2F9234495C92.jpeg B96F55DB-03B3-43CB-B1C9-C2AD10F71054.jpeg 15 down and 1 to go… what a total nightmare. . This took almost 3 hrs.
    loudbang, j hansen and brEad like this.
  18. AmishMike
    AmishMike
    Looks like pretty nice patio u blasting grease & crud all over. Hope boss ok with mess
    Blues4U, Hollywood-East and pennafxu like this.
  19. pennafxu
    pennafxu
    from Kentucky
    Probably not… but hopefully zep to the rescue
  20. loudbang
    But But But Honey look how good my block turned out. :rolleyes:
  21. And now the patio has patina! ;)
    Nailhead A-V8, pennafxu and loudbang like this.
  22. pennafxu
    pennafxu
    from Kentucky
    If that patina patio doesn’t clean up good I’ll be sleeping on it…
  23. rusty valley
    rusty valley
    Pretty cool vise grips, never seen that type before. Have you got the correct flathead valve tools? makes life simpler
  24. pennafxu
    pennafxu
    from Kentucky
    Yes… need to get these darn clips out first
  25. Tim
    Tim
    from KCMO
    Just finding this thread now, looks like I’ve got some reading to do!
    Outback and pennafxu like this.
  26. pennafxu
    pennafxu
    from Kentucky
    Will attack this tomorrow
    24A6717B-4E2E-4777-8E09-5B8B8C3BA6B5.jpeg 45DEA9B4-1B25-40AA-AF47-AE0B88C1F12E.jpeg 415525DD-B568-451B-BF21-4E73A5B959BB.jpeg E8D73D2D-00EA-4FC4-BCE8-93ACA435D9F6.jpeg 1006085F-F534-424D-931D-4212E099C93E.jpeg
    rusty valley and loudbang like this.
  27. pennafxu
    pennafxu
    from Kentucky
    Four of these ***emblies came out…
    97202C6F-F08F-4FB7-A6F1-B0A9D755CD3F.jpeg DB5FEDBF-8828-4EDC-9B5B-CFF2F6D0AFA2.jpeg F631842F-E646-4E9B-89D7-7ECCC72E6B25.jpeg
  28. pennafxu
    pennafxu
    from Kentucky
    Then disaster hit…
    55C2C388-70E4-4B7E-A8CE-36C46A010B52.jpeg 69902FDF-77C1-4D6F-A268-1C7D307EAE01.jpeg
    the handle snapped… I will need to weld on a thick rod.
    Squablow and loudbang like this.
  29. pennafxu
    pennafxu
    from Kentucky
    On another note the patio is coming along…I need a stiff brush and more Zep
  30. dumprat
    dumprat
    from b.c.
    I have an old Electrolux valve tool that looks like a pry bar. It works really well for stuck valves.
    Outback and loudbang like this.
