Projects Model A
Discussion in 'The Hokey Ass Message Board' started by pennafxu, Nov 9, 2010.
  1. pennafxu
    pennafxu
    from Kentucky
    1” drop front crossmember from p and j... needs to be welded in at a 5-7 deg angle
    brEad and patmanta like this.
  2. pennafxu
    pennafxu
    from Kentucky
    Peripheral oil filter... I used to use these on my chopper builds... www.whiskycityleathers.com “gold finger” build. This is a nice chrome Harley pile filter cover too!
    brEad likes this.
  3. pennafxu
    pennafxu
    from Kentucky
    Storage space for the one in the lead, the 29!!
  4. pennafxu
    pennafxu
    from Kentucky
    Got the ch***is mobile... and ready for exhaust
    brEad, patmanta and LAROKE like this.
  5. pennafxu
    pennafxu
    from Kentucky
    Sooo Excited!
    It was under there...
    That’s a lotta instruction for 12 bolts. [emoji23]
    brEad and tb33anda3rd like this.
  6. pennafxu
    pennafxu
    from Kentucky
    Plus these gaskets aren’t really for my application. IMG_1787.JPG IMG_1788.JPG
    Kinda like 1 ??
    Hotrodmyk, patmanta and LAROKE like this.
  7. pennafxu
    pennafxu
    from Kentucky
    IMG_1792.JPG IMG_1793.JPG IMG_1794.JPG IMG_1795.JPG IMG_1796.JPG IMG_1797.JPG
    Love the look of these bad boyz
    Lil'Alb, brEad, patmanta and 3 others like this.
  8. loudbang
  9. pennafxu
    pennafxu
    from Kentucky
    You gotta give a reason man! I might just drill 3 spots to have multiplicity of locations...
  10. loudbang
    Just personal preference. I like them turned down. :)
    dana barlow and brady1929 like this.
  11. pennafxu
    pennafxu
    from Kentucky
    So I’m about to order my driveshaft. I need to know whether I have a 6 or 10 spline rear. I’m pretty sure it’s a 6 spline from all my reading. Any insight would help. @alchemy
  12. alchemy
    alchemy
    Doesn't matter, you have a yoke on it already. They will need to know the size of yoke, and the measurements to the trans. Most driveshaft builders have a worksheet to fill out with all the key measurements they want.
    brady1929 and loudbang like this.
  13. pennafxu
    pennafxu
    from Kentucky
    @alchemy Did the original rear ends come with a yoke like that?
  14. alchemy
    alchemy
    I had to search through ten pages to get a glimpse of the yoke. Show me a closeup of it and I can tell you. Some F-1 pickups had open drive stock, but vendors are now making conversions. Did you buy it like this?
    Eitherhow, the driveshaft builder won't care where it came from, he only needs to know what size the X is.
    loudbang and pennafxu like this.
  15. pennafxu
    pennafxu
    from Kentucky
    Thank you... it came like this.
  16. pennafxu
    pennafxu
    from Kentucky
    Here is the page to order...
  17. pennafxu
    pennafxu
    from Kentucky
    Unfortunately they won’t squeeze into this little beauty. I guess I can use it on the 33...
    LAROKE, patmanta and loudbang like this.
  18. pennafxu
    pennafxu
    from Kentucky
    So as I went to measure for the driveline I noticed the first line said “ride height, supported rear end” obviously with it being on jack stands I said maybe another day! I was curious to see if the engine would spin. I grabbed the correct tools and the first go was tough... it finally spins with nice compression. Should I shoot some oil down the plug holes? I’m going to flip it and fill up the oil pump/pick up to prime it when I follow the break in procedure, with 3 hot/cold cycles and head-torques. Should I take the heads off? Or am I over thinking this. I’m going to build an engine test stand to break in all of my engines. It’s been sitting for close to a decade... @alchemy
  19. pennafxu
    pennafxu
    from Kentucky
    Yoke... @alchemy
    The steel 2” drive lines start at $320... the engine is well under 250hp... if I do solid burnouts will I be ok? Will my rear end hold up? I’m going to beef up the ladder bars.
  20. alchemy
    alchemy
    The drive shaft won't be the weak link, it will be the axle keys. I really doubt you could ever break a driveshaft.
    When you are ready to start the engine, fill all the oil through the port on the back of the engine, topside of the bellhousing. It will take a large funnel attached to a hose and fitting, and a lot of time and patience. This will allow it to fill the gallery and pump from the top. Then turn the engine over slowly a couple times before lighting it up.
  21. patmanta
    patmanta
    from Woburn, MA
    SECONDED^
    Your tires are skinny too so you should get a lot of miles out of your keys and axles with that flathead and 5 speed.
    What is the measurement you need to get? Have you checked it against stock Corvette shafts? IIRC you can get an aluminum Vette shaft close if not dead on between a T5 and a rear end in a Model A ch***is but don't quote me. I had one when I was messing around trying to tie a Ford 3.03 to a 47 Ford open drive rear many moons ago now. I paid like $50 for it.
  22. pennafxu
    pennafxu
    from Kentucky
    He may be in hot rod heaven but he continues to teach...
    brEad and LAROKE like this.
  23. pennafxu
    pennafxu
    from Kentucky
    IMG_1951.JPG IMG_1952.JPG IMG_1953.JPG IMG_1954.JPG IMG_1955.JPG IMG_1956.JPG IMG_1957.JPG
    Will use this to check the block for leaks...
  24. pennafxu
    pennafxu
    from Kentucky
    Top hose kit...
  25. pennafxu
    pennafxu
    from Kentucky
    Need to re-drill to 4 1/2
  26. pennafxu
    pennafxu
    from Kentucky
    pulled off the rubber booties, and ordered 90 degree ones…
  27. pennafxu
    pennafxu
    from Kentucky
    86BA5A45-F244-42CF-BBB7-552AFA58D3E8.jpeg 3227BDF7-D468-4C76-AA2D-A6685C9D9AA6.jpeg 981E9B7E-8924-4367-8432-20E50988150A.jpeg
    it’s amazing how a little order makes the “engine bay” clean up.
    brEad, patmanta, LAROKE and 1 other person like this.
  28. pennafxu
    pennafxu
    from Kentucky
    they were bolted to 2 intake holes and retorqued…
  29. alchemy
    alchemy
    Might want to wait til you get the generator and belts in place before you remove all the slack from the plug wires. Sometimes those fanbelts don't end up where you planned, and you need to go around them.
    loudbang and brady1929 like this.
  30. pennafxu
    pennafxu
    from Kentucky
    Just a test fit… they are actually too short I think.
