Hot Rods Mis-named Automotive Equipment...
Discussion in 'The Hokey Ass Message Board' started by Fortunateson, Jun 13, 2021.
  1. Fortunateson
    Fortunateson
    I knew that boat comment would get ya! I was just bullshipping you....
    Baumi, fauj, 302GMC and 1 other person like this.
  2. Turn signals called "blinkers"
    clem and VANDENPLAS like this.
  3. Never understood this one, they should be called “ Haha Your ****ed “
    brando1956, jimmy six, weps and 11 others like this.
  4. X38
    X38
    Yep, blinkers.
  5. DDDenny
    I cringe when people call a quarter panel a fender.
  6. oldiron 440
    oldiron 440
    I had an employee that drove his 50 Buick for years with no brakes only using the parking brake.
    lothiandon1940 likes this.
  7. Dave G in Gansevoort
    from Upstate NY
    My wife had a 88 mustang gt. That 302 used a quart of oil between oil changes from new. No leaks, just p***es thru ... never understood that one
  8. oldiron 440
    oldiron 440
    How about the wobbler bearing everyone calls for?
  9. Lil32
    Lil32
    how about "indicators"
    lothiandon1940 and Desoto291Hemi like this.
  10. greybeard360
    greybeard360
    Way back in the hot rod days (remember those?) Cars had 4 fenders.
  11. Sky Six
    Sky Six
    from Arizona
    Can you have a hood ornament on a bonnet ???
  12. Pete1
    Pete1
    from Wa.
    It really is an emergency brake. Suppose you are being chased by a cop for running moonshine. You are going 70 mph. You grab a big handfull or "emergency brake", spin the steering wheel hard left and end up going the other way as the cop goes on by you the opposite way. You are home free to deliver another load.
    Rear wheel only brakes are many things to many people.
  13. DDDenny
    How about semaphore trafficators.
    fauj and 302GMC like this.
  14. stuart in mn
    stuart in mn
    Cubby hole.
    Ned Ludd likes this.
  15. MeanGene427
    MeanGene427
    from Napa
    I remember hearing when I was a kid that the dividing line between a ship and a boat was that any vessel that could be loaded and carried on a "ship" was a "boat". But then again, submarines were known as "boats"?
  16. stillrunners
    stillrunners
    from dallas
    Dang it was a hot one down here in Texas today as I sat ? took ? placed ? some vintage parts out to the curb no one would ever want ? Was it called a Merc torque converter in 1951 ?
  17. lostone
    lostone
    from kansas
    Around the shop "beatin iron"..
    ClarkH likes this.
  18. multi angle swing press .
  19. Commonly called “**** you overs” in our shop!
  20. goldmountain
    goldmountain
    How about jubillie clips and Gudgeon pins?
  21. Rckt98
    Rckt98
    We call them guards ( I guess short for mud guards).
    Ned Ludd and clem like this.
  22. jaracer
    jaracer
    Points; there is nothing pointy about them. They should be called flats.
  23. 57 Fargo
    57 Fargo
    They were emergency brakes when we had single reservoir masters. When we got tandem master cylinders the emergency brake was no longer necessary so it became a parking brake.
    Don’t get me started on “frost” plugs or if you want to be correct “core” plugs.;)
    gimpyshotrods and Fortunateson like this.
  24. Garpo
    Garpo
    Working in a parts department teaches you a new name for something just about every day. Most polite.
    Does not really matter when the customer says "they are all the same"
  25. Mimilan
    Mimilan
    "Kick it in the guts" mate [start it!]
    Or the engine "threw a leg out of bed" [threw a rod out the side]
    keeping on the subject of equipment
    Shock Absorbers which is wrong [springs absorb shocks]
    Shocks dampen oscillations [so the Poms got it correct with "Dampers"]
    and
    Crescent Wrench or Crescent Spanner [portable lathe]
    VANDENPLAS, Ned Ludd and Fortunateson like this.
  26. -Unless it's from a Torana or Cadillac (and probably a few more), then you use your "foot" to operate your "hand" brake!
    302GMC likes this.
  27. brando1956
    brando1956
    In my shop it's called the BFH or if you're talking about the real BFH it's "The Howitzer."
    Flathead Dave likes this.
  28. "Percussion adjuster"
    We called them "blindicators" since I was a kid.
    yep, Usually known as a "bonnet bird"
    I still use the famous "Start You *******", when that fails, you can then apply the percussion adjuster.
    Sky Six likes this.
  29. X38
    X38
  30. X38
    X38
    Shifter.
