1966 Correct Craft
Discussion in 'The Antiquated' started by Chucky, Sep 23, 2019.
  1. Chucky
    Chucky
    Here’s the engine installed (reposting photo).
    The Magic Ratchet likes this.
  2. Chucky
    Chucky
    I brazed up the copper exhaust last summer and connected it with silicone couplers. All control cables are new and are smooth as ****er. Rebel wiring built me a custom harness which I just started to install.
    Okie Pete, Lepus, RICH B and 2 others like this.
  3. Chucky
    Chucky
    Moving right along with the harness. The back is done, as is the engine. I’m under the dash now and about half done. Things are progressing nicely. My daughter lettered my switch panel. My son hands me supplies. The hour meter is used and has 23 hours on it, everything else is new.
  4. Nice progress . Very impressed on the cleanliness of your garage and the organized way you work . I noticed a 63 Biscaine .....I'm guessing there is a tow hitch on it for a cool nostalgic pull with the boat .
    Chucky likes this.
  5. 1952henry
    1952henry
    That is looking g nice. Well done.
    Chucky likes this.
  6. Chucky
    Chucky
    I’m not using the factory fibergl*** rear bench seat. The ergonomics of it are horrible, even with cushions. I opted for these (cheap) folding low-backs. The front seats both fully rotate. The rear seats are all mounted to a 1/4” thick aluminum sheet, making them like a bench seat. The wiring is 99% done. The doghouse is mounted. Carpet is coming soon!
    FA924FE3-531F-4BD9-824B-9A429E7280C3.jpeg 6C9763A9-5420-4600-A7AC-51B1AC35B211.jpeg 05F42DCF-8822-4088-9269-6AF77581ADF1.jpeg
    Okie Pete, RMR&C and deathrowdave like this.
  7. Chucky
    Chucky
    Made a rosin paper pattern today. Transferred that to the new carpet and I’m on my way.
    FEB63B60-C5DB-49A1-A336-B546D876044E.jpeg ABFDF823-FFC3-4604-B0F0-33BBD3CB6B4C.jpeg F368EA33-E48C-4971-BFBF-F5955D854AD2.jpeg
  8. RMR&C
    RMR&C
    from NW Montana
    Nice work, should be a lot of fun!
    Chucky likes this.
  9. Chucky
    Chucky
    I hate making spark plug wires. Not a huge fan of the red, but they came with the project.
    Okie Pete, 210superair and Jeff34 like this.
  10. partsdawg
    partsdawg
    from Minnesota
    Great looking project. Should be awesome when completed.
    Chucky likes this.
  11. Chucky
    Chucky
    I also hate making interiors, but it’s coming along quite nicely. My son approves of the stereo.:)
    4BD97969-B531-452D-89FC-577BF3ED75DB.jpeg 5A77DA6C-7A8F-44ED-B24E-5D9E04CE02CE.jpeg
  12. partsdawg
    partsdawg
    from Minnesota
    I run into a lot of vintage boats in my ramblings. Never brought one home. Always have my trusty battery op sawzall and remove the steering wheel ***embly and gauges if they look cool. Yeah....I know I'll burn in Hell from the vintage boat crowd.
    Okie Pete, Chucky and Lepus like this.
  13. Chucky
    Chucky
    @partsdawg - Prior Lake looked like it was fun. I’m kinda confused about the law shutting it down, what a bunch of sissies. Either way, I finished the interior today and I bought a battery. Looking forward to warmer weather!
    Okie Pete and RMR&C like this.
  14. LBCD
    LBCD
    Nice work! Did you install a new floor too? I see the cored holes for expanding foam?
  15. Chucky
    Chucky
    The previous owner had a professional shop (ka-ching!) completely gut the floor and stringers. Structurally, it’s now a new boat. They also foam filled all the fillable cavities. Some other cool details...It has 2, 4” PVC p***ages to route things from the bow to the engine area. The ski pylon was structurally enhanced and attached to the stringers way better than it was stock. I added a tow hook to the transom and greatly reinforced the (non-stock) swim platform mounting brackets. I also installed the modern GFO packing material on the rudder and prop shaft seals.
    LBCD likes this.
  16. LBCD
    LBCD
    I’m in the middle of a 16’ Lone Star restoration and it’s a pain in the **** because I just keep uncovering stuff that’s needs attention. One other question for you are about the side interior carpeted panels...did you fab those? And how are they attached? Thanks your boat is beautiful!
  17. rustydusty
    rustydusty
    About 15 years ago, I restored a 14' Alumacraft that my dad won in a "sales" contest in 1961. It's not an inboard V8 powered ski boat, but I spent hours skiing behind it as a kid, and more recently, pulled my boys and their friends on tubes...
    Your Correct Craft is gorgeous! I've always wanted one of those or a Master Craft. 810.jpeg 885.jpeg 809.jpeg 813.jpeg 878.jpeg
  18. Chucky
    Chucky
    @LBCD - I did fab the panels using regular plywood in the 11/32 thickness. I’m hoping that thickness will resist warping. It’s not like they get soaked, unless something goes really wrong. And, the carpet has a rubbery backing that provides some protection too. I learned the plywood grain matters when making a curved panel. It would also help to glue the carpet to the panel, if the panel is curved. I used an Arrow brand pneumatic stapler and a box of 1/4” staples from Home Depot (under $50 total). My boat had existing holes through the fibergl*** lip that surrounds the majority of the interior. I used the rounded head, stainless steel screws along with the stamped, domed stainless washers to attach the panels. The panels are not attached at the bottom, however, because it’s carpet on carpet, they are quite secure. Keep in mind the panels get larger in all dimensions after attaching the carpet and that fact can affect hole alignment if you’ve pre-drilled.
    greg32 and LBCD like this.
  19. 210superair
    210superair
    from Michigan
    Looks great man! I've got that same stereo in my superair and love it btw....
    Chucky likes this.
  20. Chucky
    Chucky
    I made some progress on the non-stock swim platform. New wheels and tires for the trailer showed up today...can you say “hit it!”:p
    73B83768-3A4F-4049-A1EF-4CCE4A4FB4C7.jpeg 99529109-BC6A-4B27-A0F1-E7AC25C82E7D.jpeg
    Okie Pete, 210superair and RMR&C like this.
  21. rustydusty
    rustydusty
    If you want, you could pressure wash that teak swim platform then let it dry and sand it. It will end up looking new. As a retired "yacht carpenter",I know what I am talking about...
    Okie Pete, 210superair and Chucky like this.
  22. 210superair
    210superair
    from Michigan
    My two brothers and I were all skiers, and grade c hillbillies. We skied at tournaments almost every weekend and went to ski down in Florida during the winters to keep in shape.
    We never said 'hit it'. Ya gotta yell: "LET IT HAPPEN CAP'N!", let the whole lake know you're an idiot, lol...
    Okie Pete likes this.
  23. 210superair
    210superair
    from Michigan
    Agreed, you gotta sand those gray spots out of the wood, then drench it in oil. Never poly or paint...
    It also may behoove you to back it off the transom some, it looks like it is touching. I'd personally round those sharp corners while I was at it, but not totally needed.
  24. Chucky
    Chucky
    I guess I’ve been too busy to update this thread. Well...The engine runs great, but the trans was stuck in reverse. Turns out, I had too many clutches in the reverse pack. I finally had time tonight to yank the trans and correct the problem. I’m hoping to re-install tomorrow night and get it on the water this coming weekend. 35EF02DC-9046-4E94-B279-558DFD6B28A6.jpeg 3416927A-82E0-4297-B700-B6EC992E15EC.jpeg
  25. Chucky
    Chucky
    Here it is in my driveway. Like I said, it runs freekin’ awesome, it just had a little issue inside the trans / now corrected. New tires and wheels too!
    B3341B1E-2F89-4F0B-838D-234F4A72CFAB.jpeg D8897A9B-4113-44EA-9C3C-00AB2FE6758C.jpeg
    Okie Pete, LBCD, greg32 and 5 others like this.
  26. ROADSTER1927
    ROADSTER1927
    Looks Great!:D
    Chucky likes this.
  27. Chucky
    Chucky
  28. Chucky
    Chucky
    I hauled it up north to our new lake place and pulled the kids on a tube. It runs great. Now I’m switching over to cabin building. Always looking for the next project…
  29. ROADSTER1927
    ROADSTER1927
  30. Chucky
    Chucky
    I STILL OWN THE BOAT - 2024
    210superair likes this.
