Technical 1940 Ford Coupe Front Shock Towers
Discussion in 'Traditional Hot Rods' started by Ray Nelson, Jun 18, 2021.
  1. Ray Nelson
    Ray Nelson
    I have 2 sets of front shock towers that came with my ‘40 Ford Business Coupe. One pair measures around 13” total length and the other pair about 14 1/2”. Which one would be correct for my car? And why are there 2 different lengths? Could one set be for a truck? New to this Forum and appreciate any help I can get.
  2. olscrounger
    olscrounger
    picture will help--used a lot on my 40's
    lothiandon1940 likes this.
  3. Doublepumper
    Doublepumper
    from OR-WA, USA
    The shorter mounts are most likely correct for your car....?
    I know the '41-'48 mounts are 14-1/2" long.
    stillrunners likes this.
  4. olscrounger
    olscrounger
    When using those in a 40 be aware that they may hit the inner fender wells messing up the front sheet metal alignment. Have to make a spacer or tweak a bit to clear-have done many
  5. Ray Nelson
    Ray Nelson
    I posted a pic of the shock towers
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    you do know that these parts are aftermarket or from later model Fords. 40 Fords came from the factory with lever action shocks not tube shocks. The real issue here is which ones fit the car better? use those and get shocks that are the correct length for them
  7. olscrounger
    olscrounger
    Yep--later Ford but bolt to same holes--as mentioned may hit inner fender panels-easy fix--try the short ones--last ones I used were the longer ones and cut them down even a bit shorter than the short ones
    Moriarity likes this.
  8. olscrounger
    olscrounger
    They require perch pins with an attachment on top -superior to aftermarket kits in my opinion.
  9. tub1
    tub1
    from tasmania
    For the lower shock mount just drill a hole in the axle between the perch pin and the kingpin at 90 degrees to them in the web of the axle , this is the way Aussie 40 Ford's had tube shocks from the factory if you want picks of the Aussie 40 set up send me yr email
    olscrounger likes this.
  10. olscrounger
    olscrounger
    Yep--have done that as well
  11. tub1
    tub1
    from tasmania
    Have you seen the Aussie 40 upper mounts old scrounger I'm going to use some on my 39 sloper I've cut and joined some 48 ones on my 35 ,also WW2 jeep shocks correct length and fittings
