Technical Putting 59A in '31 Model A. Radiator question
Discussion in 'Traditional Hot Rods' started by FASI, Jun 14, 2021.
  1. FASI
    FASI
    I am putting a '48 Ford 59A in my '31 A. Will be putting a '32 grill shell on it. What seems to be the best radiator arrangement to go with, preferably "over the counter" type?
  2. alchemy
    alchemy
    Usta be a Walker. But since they have gone out of business, the good ones are scarce. Br***works look nice, and seem to have a lot of recommendations.
  3. verde742
    verde742
    try yer stock one modified of course.. If ya have one, have rad shop check flow.
    I used my stock '29 Ford radiator, with a 283 chevy engine, had no problems, AND NO BURP TANK, and didn't overheat when I drove to L.A. And back, in 1963 from Washington State.
    gary macdonald likes this.
  4. 2935ford
    2935ford
    I have had very good results with Superior Radiator.
  5. gary macdonald
    gary macdonald
    Im traditional all the way BUT i recently purchased an aluminum radiator , actually 2 for flathead builds . One was a stocker 41 ford the other an A with an 8 ba . Both were about $150 each and excellent. Keeps the mercury.080 over motor in the 41 cool and the A is just getting finished . Id recommend the Ebay alum deals .
  6. neds29
    neds29
    I have a pressurized Br***works radiator in my otherwise stock '29 and am happy with it.
  7. roll of the dices
    roll of the dices
    Using a Br***works on my '30 roadster project with '32 grill. '32 frame and 59AB flathead
    Best customer service and really nice product. Fits like a glove.
    They added over flow tank to it.
    thumbnail_IMG_5133.jpg thumbnail_IMG_5134.jpg thumbnail_IMG_5135.jpg thumbnail_IMG_5160.jpg thumbnail_IMG_5161.jpg thumbnail_IMG_5162.jpg thumbnail_IMG_5163.jpg
  8. Warmer 1932
    Warmer 1932
    Hello, looks good is that a 2 or 3 inch chop on the rad. Don
  9. roll of the dices
    roll of the dices
    Don,
    This is a 2" chop. Everything I found online indicated 30-31 requires a 2" chop. 28-29's need a 3" chop.
    I mocked up with 2" and very happy with outcome.
    ottoman likes this.
  10. 13clicks
    13clicks
    Br***works rules.
  11. Justin in PA
    Justin in PA
    7B7E0BC2-56B3-4635-87A9-0FFD29FD92AA.jpeg My ‘31 has a stock dimension ‘32 Br***works with the hidden fill neck. I chose not to get the built in overflow tank because you have no indication if the radiator level gets low. I use a bottle for the overflow to gauge if I’m losing water. I’m glad I did because the 21 stud that used to be in it used water very slowly and I could only tell by my overflow gradually going empty.
