Technical I need help/ideas to build steel wheels ‘61 Catalina Super Stock
Discussion in 'Traditional Hot Rods' started by weim55, Jun 18, 2021.
  1. weim55
    weim55
    Period correct ‘61 Pontiac Catalina S/S track car. Want to run an era correct steel rear wheels. Because of unique axle width i’m going to have to build correct offset (custom
    ) wheels to suit. Is there a 50s 60s 5 on 5 GM wheel center compatible with any modern available hoops? Any other ideas?
    Steve weim55 Colorado
  2. Mr48chev
    There are a **** ton of 15 inch 5 on 5 wheels out there. Big Pontiac, big Olds (not all as some had 5 on 4-3/4) Big Buick Big Chevy such as a lot of Caprice. I've got a pair of 15x8 mid 70's Chevy truck wheels out back with snow tires on them that would probably work on the rear. I think Super stock was limited to 7 inch slicks in those days but may be wrong. That's what we were limited to in Stock cl***.
    Deuces and hemihotrod66 like this.
  3. weim55
    weim55
    At the moment I have a pair of 15 X 7 stock steel wheels off of probably a big late 70s Olds or Buick. The center stamping is weird and the center register hole is not round. One look at it and it is clearly out of the era that the car is intended to represent. Really want to stay with a wheel center no later than 1960s. Not sure of the final rim width just yet, probably an 8 inch. A set up not likely to ever find in old used vintage stuff.
  4. pirate
    pirate
    from Alabama
    Not exactly sure what style of centers you need but Diamond Wheels in Milwaukee Wisconsin supplies racing wheels in about any size, offset,etc. as well as builds other custom wheels.
  5. gary macdonald
    gary macdonald
    There are date codes on steel factory wheels and manufacturers code
    Deuces likes this.
  6. 1934coupe
    1934coupe
    What rear do you have in it?
    Pat
  7. Mr48chev
    These are 61/64 Pontiac 14 inch wheels off an old Ebay add. 174074672129
    To be correct you will have to run 14 inch wheels. I think that is where things got sidetracked as a lot of us tend to forget that many early 60's full size cars ran 14 inch wheels. 61 Pontiac 14 inch wheels.jpg 61 Pontiac 14 inch wheels b.jpg
  8. Mr48chev
  9. AngleDrive
    AngleDrive
    from Florida
    On the 62 Super Duty we raced we put 15 inch tempest wheels on the front. Don't remember the width, but it was pretty narrow. Rears were 15x7. Not sure if 15 inch wheels were available in 1961.
    31hotrodguy likes this.
  10. Mr48chev
    To be dead on period correct Weim55 needs the 1961 NHRA rule book to see what and what wasn't allowed in Super stock.
    Deuces and kidcampbell71 like this.
  11. saltflats
    saltflats
    from Missouri
    If racing in a ***ociation, what will they let you run?
    Deuces likes this.
  12. Junior Stock
    Junior Stock
  13. NMCarNut
    NMCarNut
    While Pontiac went to 14" wheels starting in 1957, at least in 1962 15"x6" wheels were optional and part of the HD brake package option. Forgive the tire but here is a 15" versus 14" Pontiac wheel . The centers should be the same as the earlier 50's Pontiac 15" wheels. Not sure what the ID of a modern hoop is but FWIW the 15"center is 12-5/8" diameter versus 12" for the 14" wheel.
  14. 31hotrodguy
    31hotrodguy
    I have a 60 Catalina 2dr sedan stick car that I’m working on. What I am planning is I got 1956 Pontiac 15 inch wheels and planned to have the centers welded to 15x6 rims so I can run my small caps. For my future slicks I have 15x7 5 on 5 steel wheels off of I believe a Chevy Caprice but I’m not sure of their origins.
    So far here is my set up:
    63 389
    068 cam
    Dual quads
    Factory long branch headers (repro)
    T10 4spd
    3.23 posi (would like to go lower)
    Still need to get it on the road
    Just Gary and Deuces like this.
  15. Atwater Mike
    Atwater Mike
    My '63-1/2 Galaxie will be having a 'wheel fit fiasco' later this summer.
    Years ago, I was the 'Dumped/reversed wheel guy'... a revisit will be interesting.
    Joe Travers and Deuces like this.
  16. weim55
    weim55
    Thank you for the pics and measuring the wheel centers. Is the 15" you have pictured a HD brake wheel from that era Pontiac? I've never seen one like that (rare?) Hoosier just came out with a 29x7x15 Super Stock Slick that I will be running, they only have 15", no 14".
  17. Poncho60
    Poncho60
    from N Illinois
    Looks like it. It has the 3 clips that are required to install the dog dish hubcaps.
    Deuces likes this.
  18. loveoftiki
    loveoftiki
    from Livonia,Mi
    Look into mopar wheels of the same era...believe they have a 7” that worked perfect... the offset fits those perfect..
  19. Junior Stock
    Junior Stock
    M&H has a 14’ if you wanted to go that way.
    https://www.mandhtires.com/M-H-Racemaster-Drag-Slicks/8.00-8.50-14
    Elcohaulic and Deuces like this.
  20. Deuces
    Deuces
    Love the redlines!!!!!.....:D:cool:
    Elcohaulic and Just Gary like this.
  21. A while back I was building a '62 Catalina wagon (another project I sold too soon). Just to have something on the back, I mounted a pair of 30x9.50 BFG's on a pair of Buick Riviera road wheels (Magnum 500 style). They fit...but boy, they just fit. Not that you would want to use any of that, but if you could find a wheel and tire to measure, it might give you a good starting point. Gene.
  22. weim55
    weim55
    I heard
    9 inch Ford approximately stock width with stock 5 on 5 Pontiac wheel pattern.
  23. weim55
    weim55
    Would love to run superstock with Southeast g***ers but The distance would probably never allow. They mandate running 7” Slick and worked with Hoosier to produce a 29x7x15 slick just for the cl***. I’m going to try running a pair of these but I’m doubtful they are going to hook, the Catalina is in the 10s in the 1/4.
    Basically, I want to just hit as many vintage drag events as I can. The rules can be fairly loose but some are strict about period correct appearance W/ no modern wheels or slicks over 10”. Plus it’s important to me to represent the 60s era Super Stock accurately while still maintaining performance with the car, tough to accomplish.
    loudbang and saltflats like this.
  24. weim55
    weim55
  25. weim55
    weim55
    The wheel wells have been m***aged a bit and currently has a 29x10.5x15. That’s THE largest tire that will fit.
    alphabet soup likes this.
  26. NMCarNut
    NMCarNut
    Yes, they are the correct 15" wheels. The probably easier to find mid-50s Pontiac 15" wheels have very similar if not the same centers but I believe are only 5-1/2" wide.
  27. Elcohaulic
    Elcohaulic
    The Cadillac wheels also fit..
