Technical Hole above oil filter on SBC
Discussion in 'The Hokey Ass Message Board' started by Greasyman, Jun 23, 2021.
  1. Greasyman
    Greasyman
    I bought a Chevy crate engine and I noticed there is a threaded hole just above the oil filter. What is this for?
  2. Belle53
    Belle53
    i believe clutch linkage
    Deuces and Lloyd's paint & glass like this.
  3. Could be for oil sender. Maybe show us a picture.
    Deuces likes this.
  4. trollst
    trollst
    Oil sender, oil with come out if you fire it.
    Deuces likes this.
  5. Jmountainjr
    Jmountainjr
    A pic would help. Many blocks had one or two locations for the clutch pivot ball, one of which is above the oil filter boss. A clutch pivot ball hole would be a SAE course thread and an oil hole would typically be 1/8" NPT, so pretty easy to tell them apart.
  6. Fordors
    Fordors
    If the hole is threaded 7/16-14 it's for a clutch linkage ball, but if you are referring to a hole centered in line with the oil filter that should have a 1/4' NPT plug in it. That horizontal hole gets oil from the filter and feeds the main bearings and the top end of the engine.
    Deuces and squirrel like this.
  7. squirrel
    and what the oil hole is for, depends on what you're installing the engine in. In some Chevys, it's for an oil pressure switch or sending unit. In others, it's to be plugged.
  8. Mr48chev
    I am thinking that they are in every small block (except early engines that had bypass filters) and that that was the access point to drill the cross gallery between the gallery from the oil pump and the oil filter. SBC oil gallary.jpg
    427 sleeper and squirrel like this.
  9. Greasyman
    Greasyman
    Thanks for the help. It seems it is for the clutch mechanism, which I didn't realize because I'm using an auto. It's "B" in this photo.
    Desoto291Hemi likes this.
  10. Yep, looks like the hole for the Z-bar stud. There is a matching hole in your pic, on the bell housing itself to be used for different applications.
  11. MARKDTN
    MARKDTN
    Pretty sure "B" is also oil pressure.
  12. Dennis D
    Dennis D
    If it is for the clutch ball stud, It should go all the way through into the housing. Should be able to see the torque converter through it. Don't think I have seen one with a blind hole. D
  13. silent rick
    silent rick
    i intend to use that hole and the one in the bellhousing to mount a bracket for a hydraulic slave cylinder to push on the fork
  14. Dennis D
    Dennis D
  15. silent rick
    silent rick
    this is a bracket brian bass made for the wade coupe.
  16. That is one good looking bracket,,,,,I also like the anti rattle spring bracket mounted outboard as well .
    Looks very good ,,,,,,,although I would have doubled the thickness of the base metal.
    That cylinder is under quite a load,,,,pressure wise,,,,,,should work fine though.
    Tommy
  17. silent rick
    silent rick
    it is neat. i asked brian if he would mind if i copied it. i have given thought to using 1/4 inch material for the base.
