Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. LAROKE
    LAROKE
    From the BillyBob Shop Log.
    June 23rd 2021 Went over the block with scotchbrite cookies in the air powered angle grinder to remove all the loose paint remnants, blew it off with the air hose, then applied the PRE Paint Prep again. This time, the surface remained stable and I followed up with two coats of the Bill Hirsch Engine Enamel spray bomb. The Buick nailhead green is an acquired taste. Some have nicknamed it puke green. They put these engines in medium duty Chevy trucks from 1956 to 1959 when the Chevy 348 was introduced. I didn't research Chevy's color for the 322 because I like the green. Beer of the day was Free State Brewing Company's Oatmeal Stout.
    charleyw, OzMerc39, mgtstumpy and 7 others like this.
  2. orange52
    orange52
    Lowered the nose 3.25 inches using dropped uprights and one coil cut off. I love the stance :) Lowered1.jpg Lowered3.jpg
  3. FRANK GRELLE
    FRANK GRELLE
    Did i just see this Chevy on the 49-54 face book page? man that thing is sharp!my 150 was the same color when it was new.
  4. orange52
    orange52
    Yeah, but this morning I changed out the hubcaps :)
  5. LAROKE
    LAROKE
    From the BillyBob Shop log.
    June 24th 2021 Flipped the block right side up again and finished trimming the masking tape around the head and valley cover gaskets by running a sharpie line around the gaskets and trimming just inside the line with X-Acto knife.
    The paint is still tacky. The weather, here in South Florida, is muggy this week. After the top of the nailhead is painted and the masking comes off, touch ups can be made at any time by spraying a few blasts of paint in a cup and dabbing it on with a Q-Tip. Background music was the Rolling Stones It's only Rock and Roll.
  6. 57 HEAP
    57 HEAP
    I put some sealer around an area that the rear windshield gasket was leaking when I went to a very wet Jalopyrama. Replaced two rotted out license plate light sockets. Then decided to drive the ol' heap to work.
    Lil32 likes this.
  7. j hansen
    j hansen
    To all of you!
    When you tell us about the changes,repaires or constructions you made whith the car.
    Show a pic of the car,if you dont have a pic of the what you just done with it.:)
  8. TA DAD
    TA DAD
    from NC
    I removed the mock up drive train and getting the motor mounts ready to weld in place for the second time ( the first time they were to low ) worked on some boxing where I had to cut out for the fuel pump to clear and adding some plate for some rigidity. Hopefully I will get the block to the machine shop next week. studebaker build 004.JPG studebaker build 003.JPG
  9. Fabulous50's
    Fabulous50's
    from Maine
    Took some measurements of the camshaft for wear and overall lameness..... 20210616_134621.jpg
    Mocked up the cam gear on the cam to determine machine work to make the double roller work with my origional lame cam. Gotta take 0.064" off and itll be golden. 20210619_102013.jpg
  10. FRANK GRELLE
    FRANK GRELLE
    LOOKING GOOD! :)
  11. FRANK GRELLE
    FRANK GRELLE
    Getting the old gal cleaned up and ready for Rumble in the Country! this Sat! after i got done a bird flew in to the shop and pooped on the roof! 20210623_140607.jpg
  12. 57 HEAP
    57 HEAP
    Guilty! If there aren't any pictures, it didn't happen.
    My car and my boss's truck.
  13. Elcohaulic
    Elcohaulic
    I'm putting miles on it today. I'll use it to look at jobs, go food shopping then to the car cruise up in Cranberry tonight...
    High test 63 likes this.
  14. Elcohaulic
    Elcohaulic
    My father had a dark blue 54 Bel Air it was the best car he ever owned. He put a 300 six in it with three on the tree. Some****hole stole it one night and it was never seen again.. He like the way it handled and took bumps on these old Pittsburgh streets.
    High test 63, Lil32 and Hamtown Al like this.
  15. j hansen
    j hansen
    Good looking car.
    57 HEAP likes this.
  16. Fabulous50's
    Fabulous50's
    from Maine
    Those look fantastic! I have to ask how did you do it? Just mask and polish off the overspray?
  17. sidewayzz69
    sidewayzz69
  18. Lloyd's paint & glass
    sidewayzz69 likes this.
  19. sidewayzz69
    sidewayzz69
    Thanks
    Lloyd's paint & glass likes this.
  20. topher5150
    topher5150
    I forget is ten year anniversary leather and stainless
    sidewayzz69, OzMerc39, LAROKE and 2 others like this.
  21. gimpyshotrods
    gimpyshotrods
    Got an early start, put the Falcon up on the tall stands. I cleaned bare the underside all the remaining original floor, and re-sealed the seams (rust free California car).
    Tomorrow I will prime and paint. Next week will be undercoat.
    After that, I put two for the four 3-point inertial reel seat belts in.
    Lil32 likes this.
  22. LAROKE
    LAROKE
    June 28th 2021 Plugged some more holes, PRE Paint Prepped and painted the upper nailhead block surfaces with two coats. Let the paint cure for a couple of days and mounted the block back on the engine stand. Removed the masking, cleaned the machined surfaces and wiped them with Marvel Mystery Oil.
    Matt Martin, of Centerville Auto Repair, commented about the block drain petcocks and I decided to go with his practice of using plugs. The petcocks will go in the parts box for radiator spares. I got 1/4" NPT brass plugs for the nailhead and installed them with Threadlocker blue. Beer of the day is Hanger 24 Craft Brewing's Orange Wheat American Wheat Ale.
  23. Drove it to work !!!
    64 on 64
    :cool::cool::cool: :D
  24. Very interested !!!
  25. ERguitar
    ERguitar
    My son and I put the motor back in his truck after some overhauling and painting. KIMG0656.JPG
    charleyw, High test 63, Lil32 and 8 others like this.
  26. 57 HEAP
    57 HEAP
    Had lunch with my brother "57Trucker" and John "El Jefe" Mullen at the Lakeside Restaurant.
  27. blowby
    blowby
    from Nicasio Ca
    On the road after rebuilding the 3 speed. Put it in reverse by mistake a couple of times, as both my daily and work truck are 'up for 1st'. Luckily no one behind me or would have done a Toad. 3sp reverse lockout?
  28. hotrodjack33
    hotrodjack33
    Made some more progress on the '36 Cabriolet over the weekend...headlights, bumpers, whitewalls, skirts (well, one of them anyway) etc...it's gettin' close:)
    Last week.
    Today:)
  29. Sky Six
    Sky Six
    from Arizona
  30. Sky Six
    Sky Six
    from Arizona
