Technical my hub caps don't fit!!!!!!!!!!!!!!!!!!!!!!!!!!!
Discussion in 'The Hokey Ass Message Board' started by nobby, Jun 25, 2021.
  1. nobby
    nobby
    should - do these wheels take an early ford hub cap?
    do you have to almost bend the cap inner part some?
    any one have that style wheel with a vintique cap
    do i wire wheel the paint off and try?
    do they 'just' take a baby moon style cap
    they are close
  2. lothiandon1940
    lothiandon1940
    What was the source of the wheels?
  3. nobby
    nobby
    used
    the caps are new and 8 and 1/8
  4. hotrodjack33
    hotrodjack33
    That looks like one of those "Chrome Smoothie" rims from 1980s/90s. They came with a "smoothie" baby moon hubcap which used inner nub mounting like a Ford, but the caps were much smaller.
    wraymen and X38 like this.
  5. Lloyd's paint & glass
    Looks like you need the caps that snap into the inside, and the caps you have go over the outside. Those are aftermarket steel smoothie wheels
  6. Dan Hay
    Dan Hay
    So, you're saying they won't snap inside the middle of the wheel? I had that problem. Here's the fix:
    Take a cutoff wheel and cut a slot at 6 and 12 oclock on the part that snaps into the wheel. That allows the inner ring to flex just a little so you can get it on the wheel. I did this on all 4 wheels and ran 80 mph wherever I went and they never came off.
  7. tiredford
    tiredford
    from Mo.
    I bought Wheel Vintiques wheels that look like that with ten holes. New caps like those. Hard the first time. Set the cap in one side and with the heel of your hand, hit it really hard. Thats on the edge so it won't bend...will pop right in. Worked for me.
  8. Dan Hay
    Dan Hay
    If you cut the slots like I suggested, you won't have to hit them so hard and risk putting a dent in them. I see dented early Ford caps all the time and I know exactly why.
    stillrunners likes this.
  9. Nitroholic
    Nitroholic
    from SoCal
    That wheel looks like a Wheel Vintique Smoothie series which takes a 7 1/2" ID cap as opposed to the Gennie series wheel which takes your standard 8 1/8" ID cap.
  10. lothiandon1940
    lothiandon1940
    .....I think you hit the nail on the head there.
  11. lothiandon1940
    lothiandon1940
    I think these are the wheels you have and they won't allow the use of your cap. 00r0r_garYjoL2kETz_0hq0d4_600x450.jpg
    37slantback, guthriesmith and X38 like this.
  12. lake_harley
    lake_harley
    I had the no hubcap fits issue with my Model A that also has the multi-pattern wheels. The only hubcap I found that is made to fit them is baby moons, and that only works if you like baby moons. :rolleyes: Maybe the slice-them-and-hit-them-hard trick suggested will work for you. I just put on chrome lug nuts and called it a day.
    Lynn
  13. guthriesmith
    guthriesmith
    They make caps that fit those wheels. But, as mentioned, they are just the smoothies that generally take the baby moons. Pretty sure they make caps similar to what you want but in the size that fit. I could be wrong, but those appear like stock hubcaps for original type wheels which won’t work.
  14. Jalopy Joker
    Jalopy Joker
    post pic of the back side of hub cap
  15. Nitroholic
    Nitroholic
    from SoCal
    Wheel Vintiques makes the same '42 Ford repro cap as the one shown in 7 1/2" ID that will fit that wheel.
  16. Doublepumper
    Doublepumper
    from WA-OR, USA
  17. i.rant
    i.rant
    Wheelsmith’s wheels only accept their hubcaps. Ask me how I know. Just might be the same for other manufacturers wheels I’m thinking.
    lothiandon1940 and Jalopy Joker like this.
  18. nobby
    nobby
    ahh........
    /\ this 'should' be common knowledge so the newbie numpties don't get caught out.
    ohh......
    lothiandon1940 likes this.
