Technical 327 connecting rods
Discussion in 'The Hokey Ass Message Board' started by Mario p herrera, Jun 25, 2021.
  1. Mario p herrera
    Mario p herrera
    Mainly just a thought exercise I'm building a 327 sbc for my 41 Willy's . Since the 327 uses 5.7 connecting rod just like the 350 would using a 6 inch rod have the same benefits on a 327 as it would on a 350 higher compression and removal of piston slap
  2. jimmy six
    jimmy six
    Yep, get the right pistons for a 3.25” stroke and 6”rod. I believe **** lists them. The pin needs to be .300” higher in the piston.
    Mario p herrera likes this.
  3. 1934coupe
    1934coupe
    Unless you have a LG 327 the 6" rods are pricey. I believe that the rod length does not change the CR you have to use pistons made for a 6" rod and can get any CR you want.
    Pat
    Deuces and Mario p herrera like this.
  4. 1934coupe
    1934coupe
    Well Mario what do you think?
    Pat
  5. Truckedup
    Truckedup
    There's a lot of technical discussions on longer rods an their effect on performance. On a street engine, the slight advantages are not worth the cost of new rods and pistons...
  6. sdluck
    sdluck
    Look at Richard Holdener ytube videos,he just ran this test recently.
  7. Mario p herrera
    Mario p herrera
    I'm building a 331 for Willy's I have a choice between a small journal and large probably go with the small I find the 6 inch rod interesting because I think it should help with stability on the top end
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
  9. Mario p herrera
    Mario p herrera
    Going with the small journal because you can rev to 8 grand no problem the Willy's might see some light drag racing.ive built quite a bit of 355 over my life time and there is difference between the 5.7 and 6 inch rod it does seem to help keep the harmonics down on the top end
  10. Roothawg
    Roothawg
    loudbang and Mario p herrera like this.
  11. Mario p herrera
    Mario p herrera
  12. Oilguy
    Oilguy
    Engine Masters TV show (Motortrend) recently ran dyno tests comparing std and long rods. You can probably find it on You Tube. I can't even remember the results but there were minimal differences through the RPM curve.
  13. Roothawg
    Roothawg
    The advantage of the long rods is minimal, however it opens up off the shelf pistons. A lot of the stroker combinations, like the 383, use a piston that works perfect with a 3.25" stroke.
    If my old man memory serves, the compression height is 1.260"
    Mario p herrera and jimmy six like this.
  14. Mario p herrera
    Mario p herrera
    Thank you did not no that that information will come in handyUOTE="Roothawg, post: 14116500, member: 160"]The advantage of the long rods is minimal, however it opens up off the shelf pistons. A lot of the stroker combinations, like the 383, use a piston that works perfect with a 3.25" stroke.
    If my old man memory serves, the compression height is 1.260"[/QUOTE]
