Technical Will the Industrial Chassis Legs Work?
Discussion in 'The Hokey Ass Message Board' started by Duke, Jun 26, 2021.
  1. Duke
    Duke
    Just picked up this original ch***is and want to add the industrial ch***is legs. Will they clear the master cylinder?
    DCB7EC6C-22D2-447C-8681-35BEE3A1BFC7.jpeg 0C306532-201B-405F-AF9F-679062511E35.jpeg image.jpg
    Thanks
  2. I wish I knew what industrial ch***is legs are.......
    ottoman, j hansen and partssaloon like this.
  3. Duke
    Duke
    Phoenix hotrods makes them now.
    kidcampbell71 likes this.
  4. Kiwi 4d
    Kiwi 4d
    I struggled to find any useful info on their website , were they originally made in the UK by the pinstriper ? I can’t remember exactly . D5712BD1-19CA-4584-BAF8-4CC57B706EDE.jpeg F43B6CEB-94F9-481F-AE1B-3E331E219990.jpeg
  5. Duke
    Duke
    I think Pinstriper made them after Steve. Thank you for the pictures.
  6. 19Fordy
    19Fordy
  7. lake_harley
    lake_harley
    I know nothing about the ch***is legs you're talking about, but based on your first photo, and the photo of a pair being installed in post #4, I'd say they'll run right through your current master cylinder location. It appears your string that's in the photo confirmed that?
    Lynn
  8. Duke
    Duke
    I wonder how the master cylinder is located with the legs. It does look like it might hit. Or maybe I could open the holes up where the master hits?
  9. Speed Gems
    Speed Gems
    I'm thinking that's the name of the company he bought them from.
  10. WiredSpider
    WiredSpider
    You are thinking of Industrial Ch***is in Arizona.
    I have the industrial ch***is legs for my ch***is
    they do not clear a dual master cylinder even using his pedal setup.
    They are also 1/2 short from the bolts lining up on the rails in front of the rear tires
    Not impressed
  11. Now I understand..:)
    Speed Gems likes this.
  12. I take it that the "legs" are to triangulate the ch***is so it's less of a wet noodle. (?) .......and relocating the M/C is out of the question. (?)
    Maybe shortening the legs and/or tweaking the angle to reposition where they mount is a possibility. I'd mockup with a couple of 2x6's first before hacking the legs though.
  13. Duke
    Duke
    Yes, the legs are to add some strength. I don’t have them. It looks like I should fab my own or run as is. Plan is for a 283 to the stock driveline.
  14. 5window
    5window
    Maybe you could add another cross member, parallel but a couple inches ahead of your strap but aft of the MC? Shorten the legs and bolt up as shown just further back.?
  15. Mr48chev
    Phoenix hot rods and Industrial ch***is are a combined effort now. They merged and moved into one larger building in Tempe last year.
    Industrial Ch***is Inc. – Hot Rods and Customs Fabrication
    Phoenix Hot Rods may be doing some of Steve's marketing in the process.
    Tim likes this.
  16. krylon32
    krylon32
    from Nebraska
    The pinstriper is still offering the 32 leg kit on the HAMB
  17. Duke
    Duke
    I like that idea!
    5window likes this.
  18. uncle buck
    uncle buck
    What about floor pan clearance In areas that the floor drops below the top of the frame?
  19. ELpolacko
    ELpolacko
    First I have heard of anyone having an issue like this. Been producing these without complaint for years, even some great testimonials about how these accessory "legs" made their original cars feel more solid and almost eliminate the "roadster pinch" for open cars.
    The pedal set was redesigned after the R&C article came out to accommodate the dual masters.
    Tim likes this.
  20. ELpolacko
    ELpolacko
    Correct!
    The deal was made last January, and because of the insanity of last year we have been slow to get our product back online.
    I still own IC and operate within www.phoenixhotrods.com as a house brand product. I still own and operate www.industrialch***isinc.com and have a forum there called Bench Racing if you care to discuss any of this further. I don't want to be accused of benefiting from the HAMB unjustly.
  21. WiredSpider
    WiredSpider
    The legs and pedal setup was one of the last sets you made before you stopped making them (the receipt date is 2/26/2018)so they should be the redesigned ones but the master cyl still doesn,t fit
  22. EVERYTHING Steve produces is top notch. I own more than one of his pieces.
    5window likes this.
  23. ELpolacko
    ELpolacko
    If you email me pictures of your situation at steve@phoenixhotrods.com I may be able to help you with the solution. Just saying "it doesn't fit" doesn't really clarify what the situation is.
  24. Here is a shot of my frame that Elpolack helped me with. You can get the legs straight if you have a flat floor or you can get the legs with a drop in them for a stock floor. My center cross member is one that he produces as well. AE1E127D-8AA2-485C-AEEC-B0A50A93DD55_1_105_c.jpeg 49BA221C-B951-4224-BAC2-3558A215154D_1_105_c.jpeg 06A14A13-C384-49E5-A916-96933DE01841_1_105_c.jpeg 0055D412-C260-40D9-BFA3-9666567F9531_1_105_c.jpeg
    ottoman, ELpolacko and Tman like this.
  25. brading
    brading
    Must say Steve nice to see you your offer, I have heard of a lot of places just do not want to know when you start asking if it will. or will not fit with no offer of help.
