Projects Dodge This - 1939 Dodge Southeast Gasser Build
Discussion in 'Traditional Hot Rods' started by Dog_Patch, Aug 12, 2014.
  1. Dog_Patch
    Dog_Patch
    Back from Farmington NC. Good times even though it was hot hot hot. Found some issues on the car and fixed them. Who knew 4 chickens and 3 dogs could stink up a camper?
    F6253E58-12DC-4195-AEFD-EAA1F044DDD5.jpeg C8FC3BA6-E6A4-4D55-87DD-833139F43039.jpeg 88D97D63-3DF5-4902-92F2-0A487C3D68C4.jpeg CF312B20-05B9-426D-B475-25A8BD413729.jpeg A9EF7CE9-7B6F-42D6-B3C6-54DF37AC920D.jpeg DB001E3D-E723-4715-90AD-F3D99F7B2922.jpeg 81EB144E-9DB7-484D-8726-EA64786946E4.jpeg 064C711C-7594-4D7B-8D5F-403B63B11465.jpeg 4F0C5034-7651-432C-92A1-011234C7C7A4.jpeg 786A69E0-0AF8-4CF1-B1AD-21B9AE3C17FF.jpeg 55F4AC72-B422-4ED5-A0C7-6DAC0CDDE88B.jpeg 0179793E-A338-4EFD-A29F-741329FF2587.jpeg
    NHRANUT, Hombre, saltflats and 7 others like this.
  2. Dog_Patch
    Dog_Patch
    KiWinUS, 41 coupe, NHRANUT and 4 others like this.
  3. Dog_Patch
    Dog_Patch
  4. Dog_Patch
    Dog_Patch
  5. Dog_Patch
    Dog_Patch
  6. Dog_Patch
    Dog_Patch
    Hombre, enloe, brianf31 and 5 others like this.
  7. loudbang
    NICE!! Tell your buddy he takes some great shots. :)
    Dog_Patch and enloe like this.
  8. seadog
    seadog
    Nice pictures. What's the story on the chickens?
    Dog_Patch, loudbang and enloe like this.
  9. Dog_Patch
    Dog_Patch
    Kim went to tractor supply on Mother’s Day and for some reason she thinks they’re pets. I’m hoping this wears off.
  10. milwscruffy
    milwscruffy
    Good luck with that !
  11. One year we got a bunch of chicks and kept them in the garage in a heated cage I built till they got big enough to go outside with the rest of our flock. Never again, those dirty, dusty, stinky little buzzards can stay outside like all the other of God creatures! I had this fine dust everywhere, when we moved I had to use a leaf blower to finally De-Chicken completely.
    Dog_Patch and loudbang like this.
  12. seadog
    seadog
    My first job down on the farm when I was about 10 was gathering eggs from the chicken house. Things were going fine until I stuck my hand in a nest and pulled out a black snake…
    Dog_Patch, SilverJimmy and loudbang like this.
  13. Dog_Patch
    Dog_Patch
    They are getting to be a mess now. The rooster is sounding off when the neighbor's dog barks so its just a matter of time before the ***ociation gets wind of them and then they'll be gone!
  14. There’s a reason they’re called “****s”! My neighbor was very happy to help me relocate my first rooster into my freezer, something about the bird singing at 4 AM every morning, I never heard a thing….
    We both had never done the chicken thing but we agreed it had to be done. He showed up at my house at dawn on the execution day wearing a yellow rain coat and holding a rope, it went downhill fast from there! I can barely type this now cuz I’m laughing so hard remembering that **** show! We both cry if one of us brings it up and it was almost 20 years ago!!!
  15. Dog_Patch
    Dog_Patch
    DA28B483-3401-45E5-B978-059ADD8A9A66.jpeg 1086E344-7CE9-48D3-9605-DA442AE579D1.jpeg 53C7288F-BAD7-4B46-8D28-B999F31BA667.jpeg B55DF9EE-40CC-4E9E-8F9D-FE137F9560E3.jpeg CE125086-2C4D-4E95-9967-E129E430F7A5.jpeg 044DF892-4411-4D0C-A4BD-9F4F674F1C7C.jpeg 582A76C0-965E-4621-AA48-052DBE764F34.jpeg Working on the B/G engine. The piston to valve clearance looks ok but the piston to head dome is woooo. The .062 gasket is damn tight at about .025 . Not sure how close is too close. The second clay measurement is with the .082 head gasket. It looks better so I’ll probably go with that thicker gasket. Gonna need longer pushrods.
  16. saltflats
    saltflats
    from Missouri
    Piston to head around .035 is what I shoot for.
    rod1, Dog_Patch and loudbang like this.
  17. Dog_Patch
    Dog_Patch
    This is the tightest I've ever had them get to the dome. This is just a straight up 392 engine so the dome is attempting to get to 15:1 - which wasn't as much dome on the 5/8" stroker.
    I talked to Rob Waldon and he said to take out the gasket and see if it hits or won't rotate, that's one more data point I'll try tonight.
  18. oldiron 440
    oldiron 440
    What fuel do you use for 15:1?
  19. Dog_Patch
    Dog_Patch
    X16 is the choice right now. There is no power difference between C16 and X16 but X is like $30 cheaper per pale.
    oldiron 440, ottoman and loudbang like this.
  20. AmishMike
    AmishMike
    Do not know C16 or X16; but are u allowed to run E85?
    oldiron 440 and loudbang like this.
  21. Dog_Patch
    Dog_Patch
    The C16 and X16 are VP brand fuels. I think some guys are running Sunoco brand also. You can only run E85 in the AFX cl***. And then there is Q16 which is illegal to run - it's worth 50HP. But it's real expensive, so the thinking is just don't allow it and save people the money.
    ottoman, AmishMike, jim snow and 2 others like this.
  22. Dog_Patch
    Dog_Patch
    The CC check shows 14.6:1 compression so gonna go with the 0.082 gasket. E1A68024-D318-4D66-AA16-C43B8C985EBA.jpeg 2966FD49-72F4-422C-9937-BD8C5331381C.jpeg 17BCF5C3-6CF5-4926-B7FD-CCAB01E0E439.jpeg B19E439C-CA96-4AD0-9DEA-8F2060C3A165.jpeg
    mad mikey, loudbang and Hombre like this.
  23. slayer
    slayer
  24. saltflats
    saltflats
    from Missouri
    Where does the quench effect come into play in a hemi engine?
  25. Dog_Patch
    Dog_Patch
    The intakes are 2.20" . If you set a head down on a flat surface, the head doesn't lay flat because of the valve overhang,
    I have no idea o_O maybe @402BOSSMAN can answer that.
    loudbang and saltflats like this.
  26. DDDenny
    Tony
    You're gonna need to give Nick a call and tell him he's working too hard, he hasn't posted on the HAMB since April.
    Dog_Patch likes this.
  27. Dog_Patch
    Dog_Patch
    We’re working on some secret stuff for 2022 …..
  28. Dog_Patch
    Dog_Patch
  29. Dog_Patch
    Dog_Patch
    Gabe won A/G this year. There were a ton of hours involved in swapping engines and transmissions in the heat and it paid off for a top shelf driver.
    Really happy for him!
    3EAD3C36-8BCF-4E43-B06F-3EAB0308085B.jpeg 2A9375BD-CA74-4A99-856F-05655C2EE1DC.jpeg 384DCD7C-33A4-43F9-8AA5-F212FD19D89F.jpeg 97C86561-E60D-4C30-A6DF-94FD3D3061B8.jpeg 9955E335-A233-4E8E-8DA9-4A3DA4E3C460.jpeg 6F25EB20-A7B7-42BB-8B1A-39A2035B8C13.jpeg FB6AFEE3-8666-42D8-B0C1-B6030E17949F.jpeg 5C78DF3B-E6CD-4BF2-9ADA-989A9C46CB65.jpeg BD2D1A99-0262-4E05-9FED-7A59FDC084E8.jpeg A57C49AA-AA1E-44E2-ABEA-EA4F1A1CEFA8.jpeg
    enloe, GreenMtnBoy, catdad49 and 11 others like this.
  30. Higgy's Henry
    Higgy's Henry
    Now that the border is open, I might have to come down and jazz the place up a little!!!!!!
    catdad49, Dog_Patch, loudbang and 2 others like this.
