Looking to Get Started...
Discussion in 'The Hokey Ass Message Board' started by Tribalmonkey, Dec 14, 2020.
  1. ^^^^^^^^^^^^^^^^^^^^^^^
    You forgot #3- Drive whatever you've got on the road
    as often as you can!
    Keep up with your plans, they seem to work very well!
  2. Tribalmonkey
    Tribalmonkey
    Tony - Exactly! I should have added #3.
  3. Tribalmonkey
    Tribalmonkey
    Any recommendations where to source a good radiator? (besides Bratton’s $530). I had mine checked out and the shop said they couldn’t fix it.
    I looked on line and saw a lot of options but not sure which ones actually fit.
  4. '30 &'31 are the same.
    Your shell on the roadster is a '30.
    Put a wanted ad on here.
    Lots of guys take good radiators out
    of Model As when changing to V-8s.
  5. Tribalmonkey
    Tribalmonkey
    Thanks Tony. I picked up a 31 grill shell from Mantua John.
    Tony Martino and lothiandon1940 like this.
  6. lothiandon1940
    lothiandon1940
    ....Did they give you a reason why they couldn't re-core your old radiator?...Just curious. It might even cost as much as a new one, but still curious as to why.
  7. Tribalmonkey
    Tribalmonkey
    Yeah. Stines Radiator in Hagerstown just said they couldn’t fix it and a new one would be cheaper than the cost of a re-core.
    I really don’t want a new one. I’d like to find a good used one. I think that would go better with the original barn find look.
    lothiandon1940 likes this.
  8. vtwhead
    vtwhead
  9. Tribalmonkey
    Tribalmonkey
  10. Dustyp489
    Dustyp489
    Mike Gross did mine radiator years ago Hanover pa . He is still in business ,if you want a 2nd look at it 717 637 4669.
    Address is 572 Carlisle street
  11. Tribalmonkey
    Tribalmonkey
    Thanks Dustyp489!
    loudbang and lothiandon1940 like this.
  12. chevy57dude
    chevy57dude
    Mine, too. But he's shut down now. Tried to contact him a couple of years ago.
  13. lothiandon1940
    lothiandon1940
    It's getting more and more difficult to find a radiator shop.
  14. Tribalmonkey
    Tribalmonkey
    Found a used radiator that looks to be in good shape. I guess I’ll know when I try to use it. Thanks for all of your recommendations.
  15. Tribalmonkey
    Tribalmonkey
    Dannerr, 302GMC, J.Ukrop and 13 others like this.
  16. lothiandon1940
    lothiandon1940
  17. chevy57dude
    chevy57dude
    Tribal - Zimmerman Radiator in Abbottstown PA did a quality repair in a reasonable amount of time for me.
    rbrewer, loudbang, Dustyp489 and 2 others like this.
  18. Tribalmonkey
    Tribalmonkey
    Started working on the front end today. 4ADFF7E7-4DCF-45EE-BD38-7A5A1F0B04D9.jpeg B0BD68BC-A4DE-432B-9960-584F3A484DC8.jpeg 7423EF6E-525F-4F16-B831-AED49DEA2EE8.jpeg E463D590-34A2-40A8-B4E2-67E05613CA11.jpeg
  19. Tribalmonkey
    Tribalmonkey
    I know it’s hard to make out what I am doing in this pic. I had to heat and ‘re-bend’ my 32 spindles on my drop axle to get them to line up for my tie rod and drag link. D85E26B1-C0C4-4AEF-9DF0-375AB9DABF80.jpeg
  20. Tribalmonkey
    Tribalmonkey
    During drop axle ***embly/mock up I discovered that my brake actuator arms wouldn’t line up with the cup on my king pins and the spring perch tabs I had. I ended up cutting the tabs off, grinding them a little shorter and tacking them in place once I bolted the arm in place and aligned it with the cup. Then I did my normal weld the $hit out of them technique. I think they are good now. BD7FBD41-818A-47FF-9053-6D608BBD71CD.jpeg
    Dannerr, rbrewer, loudbang and 3 others like this.
  21. Tribalmonkey
    Tribalmonkey
  22. Tribalmonkey
    Tribalmonkey
    Anyone know the trick to getting new dust caps on the backing plate brake adjusting wedge?
    I somehow managed to get them on my coupe backing plates but not without a lot of cussing and random attempts with every tool I own. Now I’m rebuilding the backing plates for the roadster and I am dreading this step.
  23. Tribalmonkey
    Tribalmonkey
    I’m getting better at rebuilding backing plates for model a mechanical brakes.
    1E9D2E25-4C4C-4633-84D4-98CB314FAE6B.jpeg 1340B708-D953-4D0C-8BF4-7C22FA5456BF.jpeg
  24. Tribalmonkey
    Tribalmonkey
    Excited to get my new tires on the 16” rims. B9E2104B-B521-4A27-A5F6-4088B1AFE969.jpeg
  25. Tribalmonkey
    Tribalmonkey
    Each of my 16” rims were different colors. Or were… they are very rusty.
    I talked my artist wife into making them all one color but not perfect. They need to look the part. I chose to go with the one that was almond color.
    8ED8CD4F-5818-4F79-9402-6AF1EF48B94A.jpeg 82CDB268-85F3-4ED3-9BD1-2F6BABD78371.jpeg
    Dannerr, Dustyp489, 302GMC and 7 others like this.
  26. Tribalmonkey
    Tribalmonkey
    You guys know how impatient I am. I finished the backing plates while the wheels were drying in the sun. As soon as they were dry enough I stuck the front ‘dirt track’ tires on my ‘new’ rims. I couldn’t wait to see the stance with the drop axle. I’m very happy with how it turned out. 71BC6677-9BBB-4767-8A40-5FA824617D95.jpeg DE493E8D-76E5-4E57-B2F8-BD8F05A5184E.jpeg
  27. Tribalmonkey
    Tribalmonkey
    Sadly, the only work I’ve done related to the roadster today. 415EFC99-EBAF-4B23-8369-9C4D9923A59F.jpeg
    Dustyp489, F-ONE, tb33anda3rd and 2 others like this.
  28. Tribalmonkey
    Tribalmonkey
    Got all four wheels and tires on the car.
    4D96362F-017A-4167-B9CB-B2829F9C3B02.jpeg A14D88AF-5B6E-4CAD-A6F3-48BF312D0C96.jpeg
    Dannerr, drdave, Dustyp489 and 5 others like this.
  29. Tribalmonkey
    Tribalmonkey
    Worked on brake linkage and initial adjustments. Long way to go with that. Discovered I still need one brake rod. I thought I had four good ones but it turns out one has the clevis welded in place.
  30. Tribalmonkey
    Tribalmonkey
    Finally started working on the body. Began removing the rusted out floor pans. Found the sub rails are in worse shape than I expected.
    353FE5C5-95BA-4631-B4F9-372049AA8887.jpeg 0368499F-DB55-443B-9BBC-B6C48072F944.jpeg
