Technical 53 Merc in a 33 Coupe Trans question
Discussion in 'Traditional Hot Rods' started by Dave Huelke, Jun 29, 2021.
  1. Dave Huelke
    Dave Huelke
    So I found my dream forever ever car a 1933 5 window. Been looking for years only to find one less than .5 miles away from my house. Last plated in 1966 been in storage ever since. WOW what a find. The coupe didn't have a motor or trans but I have a 53 Merc a T5 and 40 pedals.
    Now for the question.
    HOW DOES THE PEDALS HOOK UP TO THE THROW OUT ARM?
    Pictures would be great.
  2. alchemy
    alchemy
    What bellhousing are you using with the T5? There are different kinds available. Ford-style arms rotating a shaft like pre 39, or an idler shaft like 40 and up, or a late bellhousing like a 53 Ford with a side-push arm, or a Chevy style arm in your Offy bellhousing.
    Hnstray likes this.
  3. Dave Huelke
    Dave Huelke
    I haven't
    picked out the bell housing and may go with a hydraulic clutch
  4. Atwater Mike
    Atwater Mike
    cat skinnin' choices...
  5. alchemy
    alchemy
    I suggest you ask the guys who have RnR'ed their hydraulic throwouts how fun it was.
    Hnstray likes this.
  6. Nailhead Jason
    Nailhead Jason
    do not go hydraulic. Go with a set up that uses the clutch shaft and rotating fork, 39 pedals and a 39 lever on the clutch shaft. way easy to hook up and is very light with smooth action/engagement. Hydraulic clutches are problem some. If you hace to go with a hydraulic, use and external slave cylinder, not a hydraulic throw out bearing.
    Hnstray likes this.
  7. 19Fordy
    19Fordy
  8. alchemy
    alchemy
  9. Dave Huelke
    Dave Huelke
    Anybody got a set of pedals? I got a set of 40 and a set of F1
  10. Ron Plumlee
    Ron Plumlee
    I have a flatty to S10 trans, used a plain ol standard master cyl and lined it over to a slave from Krylon/Cornhusker.....works great, and a LOT easier than dealing with rods and bellcranks imo.
  11. Dave Huelke
    Dave Huelke
    any pictures on how to mount ? do you know what stroke you need to disengage the clutch?
