Can you build a real Chevy 302?
Discussion in 'The Hokey Ass Message Board' started by Lucky Strike, Sep 27, 2005.
  1. Dean Lowe
    Dean Lowe
    The only engine we ran in my RPU, after '62 was a '57 block bored to 4" with a stock 283 crank. It set the NHRA B/SR records twice, AHRA records once, and the Standard 1320 records 3 times. Every year, at the Winternationals NHRA certified it at 301.1 with their P&G tool. I don't know about other small block configurations, but that little******** was an RPMing fool. 7000 on the last yellow, side step the clutch on the green and 6800-6900 through the lights. Not high by today's standards, but in 1962 it was the top of the game. Same block, crank, rods and pistons 6 years straight. It met a sad end at Bonneville when the crank was ejected on the salt. Rollie had run 198 with it on 50%. He wanted 200 so bad. He upped the fuel to 60% but the little SBC said enough. The block was destroyed, and the heads were ruined too. the sad part of that deal was Rollie exited the 3 mile at 202, but never made it to the 4 mile. The little Chevy ended up as scrap metal to build Toyotas. :(
  2. DDDenny
    The 64-67 ChevyII block (283) was the one that were the most sought after for boring .125 over, real hard to find reasonably priced nowadays.
    GlassThamesDoug and Deuces like this.
  3. GlassThamesDoug
    GlassThamesDoug
    Agree on that, 65 is out. Nova block might be exception. I have just****embled a 65 nova 283 block. Did not compare to my other (7) 283 blocks, I do have a 1959 which might fall into the thick wall years.
  4. GlassThamesDoug
    GlassThamesDoug
    I have the Danilla Brothers B/SR engine won Indy and Bowling Green NHRA in 80s...was 305ci a (302 bored) Arias 14:1, GM crank, 302 Alum Super rods. Enderle Bug Catcher fuel injected on tunnel ram. They then switched to destroked Hemi ... set record.
  5. 26 T Ford RPU
    26 T Ford RPU
    I used a 64 block on mine. JW
  6. When I did it, I wasn't smart enough to know it was complicated. Took a small journal 327, swapped in a 283 crank and drove the thing.
    Deuces, Bob Lowry, brigrat and 2 others like this.
  7. Marty Strode
    Marty Strode
    It must have lowered the compression a bit.
  8. Guess so, but it ran pretty well.
    Deuces and GlassThamesDoug like this.
  9. GlassThamesDoug
    GlassThamesDoug
    Which heads are you running to be vintage using early 327 block.
    461
    462 < My choice
    291
    186
    040
    041
    492
    292
    034
    Deuces likes this.
  10. 26 T Ford RPU
    26 T Ford RPU
    896's and 520's is what i have used, small valve but they work well. My 301 has 11:1 or just above. JW
  11. irunonbeer
    irunonbeer
    Another question has just come up, I could use a 3876768 or a 3735236 crank. Both are out of 283’s, small journal and both forged, I think. Does anyone know whether one would be better than the other? ‍♂️
  12. lippy
    lippy
    from Ks
    As long as it's in good shape and forged you should be good to go. Dean I remember I never saw a bad running 4 inch 283. All the ones I ever saw back when, were rpm'ing fools and damn near impossible to destroy. Hell of a combo I think. Lippy
  13. brigrat
    brigrat
    from Wa.St.
    If one is already drilled for a harmonic bolt use it, if not drill em out!
  14. Roothawg
    Roothawg
    I’ve been pondering one using the new Dart SHP block. It has a ton of improvements over the stock GM blocks. That coupled with the new Trick Flow double hump aluminum heads and a factory roller cam……shwing!
    It’s either that or a 327 using the same platform.
    Everyone will throw rocks saying I can build a 700 hp 427 for the same money, but can I utilize 700 hp on a bias ply 750-15?
    Me thinks not.
    Deuces, mad mikey and 26 T Ford RPU like this.
  15. Hmmm....
    I have stock bore 302 pistons, if anyone just HAS to build a real 302 :D
  16. Bob Lowry
    Bob Lowry
    The 1967 Z28 Camaro was the only year for a small journal 302" You can find those cranks on ebay but expect to
    pay moocho moola.....I have always used a small journal 327" block and a 283" forged crank, not the cast one.
    Works great, revs to 9k. Have another on the stand in the garage waiting for a project. Bob
  17. Bob Lowry
    Bob Lowry
    Take another look at post # 296, which is copies of the article that Car Craft did in 1969 giving all the details
    on how to build your own 302" with a 327" block and 283" forged crank....
    Deuces, loudbang and GlassThamesDoug like this.
  18. GlassThamesDoug
    GlassThamesDoug
    I just built one in 283 config. Very nice casting, cleaner than most. Fits tri five real nice. Clutch linkage clears raised oil filter.
    I'm using 67 302 sj crank, camaro pan and windage tray.
    Houchins did machine work. Zero deck, Line bored, balanced.
  19. GlassThamesDoug
    GlassThamesDoug
    327 blocks are very affordable. I have several, if you use Alum camel humps, you need to study the TFS 60cc .. almost in flat top region.
  20. Roothawg
    Roothawg
  21. irunonbeer
    irunonbeer
    Not sure where to post this but if there is a better place please let me know, thanks! Good morning all! I have a set of stock bore TRW L2210 pistons for a 302. I know this is a long shot but does anyone have the same pistons in .030 or .060 over they would trade for these? I am building a 302, turns out the small journal 327 block I have had already been bored .030. I need to sell or trade these to buy the correct ones for it. I was told these are large journal rods with new ARP rod bolts.
    Torkwrench and Deuces like this.
  22. Brian Penrod
    Brian Penrod
    If I had an original Z Camaro I would go the 302 route, but I would go your way if not. I would also go with a bigger stroke also, probably the 3.48. They will rev just like the the 3" stroke but make more hp and torque. Valve train control is where rpm comes into play, love hearing all of the old stories about 7 to 8 k launches in the old days but I think most of them were just stories. You can hook 700 horses on really small tires it just takes money, lol.
    Deuces likes this.
  23. Taboo56Chevy
    Taboo56Chevy
    yeah I have been eyeing those heads for a 68 327 block I have on the floor. I have a factory forged 327 crank for it as well, but was looking at like a***** or eagle 283 crank to shove it it. I have both L79 and Z/28 intakes for it so it would be a screamer, but with its ultimate destination in my C10, probably not the best idea.
    You just need them tires the F.A.S.T guys are using on their race cars, lol.
    Roothawg and Deuces like this.
  24. DDDenny
    Sure, there were "stories" but that was the beauty of bench racing when car guys got together but the first gen 302 cars got a reputation for a reason, they could back up the story if challenged.
  25. Deuces
    Deuces
    And how!!!!!.....:cool:;):cool:
    mad mikey likes this.
  26. Brian Penrod
    Brian Penrod
    Bob Lowry likes this.
  27. Larry T
    Larry T
    I watched a YouTube video about dynoing 302/327/350. Basically a Z-28, a 365 hp 327, and a LT-1. They all made a little over 350 horsepower, the heads were the limiting factor in horsepower. Naturally, the 302 had to turn more rpms than the others. And the more cubic inches you have, the more torque you had at lower rpms.
  28. Andy
    Andy
    I have some parts to build a 302. I have a nos 327 corvette block. Cast date 3153 780 casting. Has the windage tray. I also have some early 283 short blocks. Put them together. PM me
    Deuces likes this.
  29. Roothawg
    Roothawg
    More like 9-10k launches. I hear em on the hamb once a week…..
    Brian Penrod likes this.
  30. Bob Lowry
    Bob Lowry
    I can tell you first hand that the Z28 302" were just awesome. Here is a picture of the back end of my
    buddy's Z28, snuck into my '40 street racer photo from 1968. Here is a picture of the engine that was in it
    back in 1968. He ran 4.56 gears on the street and never lost a race. For the first two years no one really
    knew what a 302" Chevy was...they always thought it was an economical, de-tuned 327". Fun times.
    Have built many 302" using 327" small journal blocks with forged 283" cranks, and have one more on
    the stand waiting for my next project...love 'em... pumpkin 4.png powers 4 z28.jpg
