Technical Where did you mount your horn on your hot rod or custom?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Jul 6, 2021.
  1. HOTRODPRIMER
    HOTRODPRIMER
    ***uming you actually have a horn.:D
    I bought a aftermarket Harley Davidson horn that resembles the type that was originally mounted on the front forks, I didn't like the chrome so I sandblasted the cover and painted it black, I mounted it on the firewall. HRP
  2. pprather
    pprather
    Mine is down low on the front of the right side motor mount.
    It is also a motorcycle horn. I was having trouble finding something loud enough to get respect, especially at highway speed.
    So, I Googled 'loud motorcycle horn'. They had a high tone and low tone horn. I only had space for one, so I think I chose the low tone.
    Yes, it is loud enough to get the attention of other drivers.
  3. 2935ford
    2935ford
    Yup, ahooga style mounted on the firewall.
    Stogy and HOTRODPRIMER like this.
  4. Jokester
    Jokester
    1932 Chevy - motorcycle horn mounted in the hole where the hand crank went in.
    1933 Chevy - car horn mounted under the angled part of the floor board.
    1934 Chevy - aftermarket small horns mounted behind and below the grill shell.
    .bjb
    chryslerfan55, Stogy and HOTRODPRIMER like this.
  5. BamaMav
    BamaMav
    from Berry, AL
    Stock 47 Lincoln horns in stock location, mounted to bottom of hood.
  6. HOTRODPRIMER
    HOTRODPRIMER
    Yeah Phil, I mounted a aftermarket motorcycle on the motor mount on my old pickup. HRP
    chryslerfan55, Stogy and pprather like this.
  7. Tim
    Tim
    from KCMO
    Any one notice any difference in noise inside the vehicle depending on where the horn is mounted? Seems under the tie board and under the radiator would have pretty different noise levels?
    been thinking about this on our model A project so I’m Curious
  8. 51 mercules
    51 mercules
    I have the same horn on my merc. I mounted it on the bracket that goes from the drivers side fender to cowl/ firewall.
  9. kabinenroller
    kabinenroller
    Left front wheel well area, mounted to a fabricated bracket on the radiator saddle.
  10. hemihotrod66
    hemihotrod66
    piture 1.jpg Mine is where Henry put it on my 34 Ford...
  11. 41rodderz
    41rodderz
    from Oregon
    219B7AD7-D4FF-47B1-8B2B-5635B84852E6.jpeg 5F38DDF2-9B2A-4B21-B0EE-87A37CB82502.jpeg Probably this one mounted off behind the grill or radiator cross support . D5331246-279A-48DD-8642-BBDEEF5A0022.jpeg
    chryslerfan55, Stogy, Hnstray and 2 others like this.
  12. themoose
    themoose
    I put them where Chevy put them 89 years ago...Trumpet horns are loud as hell(something you need these days) and I think they look cool.
  13. 56don
    56don
  14. Joe Blow
    Joe Blow
  15. tomcat11
    tomcat11
    I guess I can't say you have a herd mentality, or can I? Those horns are a statement for sure!
    HOTRODPRIMER likes this.
  16. vtx1800
    vtx1800
    I had four Studes for parts, not one of the horns worked, a trip to You Pull It in Omaha netted horns from a Chevy Pickup, mounted them in the org horn location, works fine, the 38 uses the horns (and ignition switch) from a 60's Merc Comet I parted out 50 years ago, it was a two hardtop bucket seat car four speed with a 302, transmission was broke.....it would be a $2K car for someone to build:( Sorry I got distracted with my story:) Edit....a few days after I wrote the preceeding.the wife and I went out for supper (ice cream:) in the Studebaker and on the way a deer appeared off to the left so I "tooted" at him, my wife said "that's a terrible sounding horn" she likes the one in grandpa's 64 Ford Fairlane much better:)
  17. '49 Ford Coupe
    '49 Ford Coupe
    Mid-80's Cadillac 4 tones. Over 100 db. Just behind the grill pointed forward. Gets attention.
  18. blue 49
    blue 49
    from Iowa
    My '36 Ford pickup has just enough room between the grille and the radiator for a Stewart-Warner aooga horn pointed straight down. My henry J has a disc horn pointed down right behind the front crossmember sort of under the radiator.
    Gary
  19. Garpo
    Garpo
    Just been through that exercise. I had a nice pair of "sea shell" wind tone horns that were jus too big for the engine bay of my AV8. Mounted under the p***enger side foot well just in front of the battery box. Sounds like the noise gets out OK.
  20. 1971BB427
    1971BB427
    from Oregon
    Since I'm cheap, I bought a twin horn setup from a newer ford car at the junkyard. I mounted it on the radiator support for my '39 Chev, and pointed them down to avoid any water or moisture from being forced into them. Really loud, and I like that, as it gets attention when needed.
    vtx1800, HOTRODPRIMER and Tim like this.
  21. Tim
    Tim
    from KCMO
    @Joe Blow and others running the disc shaped motorcycle horns. Do they sound like the higher pitch beep/buzz from a late 80’s Honda? Everything I can find online to hear them they all sound like that.
    I always like the deeper tone of a horn from the 50’s but like the looks of the bike horns. Wondering if there’s a happy middle ground
  22. 1934coupe
    1934coupe
    It was on my Willys when I got the car in pieces.
    Pat
  23. Joe Blow
    Joe Blow
    Tim, it's not a real high pitched horn but not a real deep tone either......somewhere in between. Originally had 12 volts on it and it was ear splitting. I gutted a Blue Streak horn relay and put a voltage reducer in it.....now it's about right. Mine sounds similar to this tone wise....but quite a bit louder.
  24. Russ B
    Russ B
    With a dropped headlight bar on my Model A’s, I needed to mount the horn under the floorboards.
    Stogy, HOTRODPRIMER and Tim like this.
  25. OLSKOOL57
    OLSKOOL57
    Replaced these with dual trumpet horn’s and bracket on my 38 Coupe pointing down to keep moisture out. Installed behind lower grill valance, loud as hell…….but I like it. 932DA7BD-3DAF-43C5-B3B8-AB81A357668C.jpeg EEF99589-D8FD-4311-AED2-4459A966A2BD.jpeg
  26. alchemy
    alchemy
    Firewall. It's a 6V horn with 12V power. Makes a lot of noise.
  27. A Boner
    A Boner
    Have a couple hot rods with the horn mounted on the right front of the engine block using a factory tapped hole...high & dry...works great!
  28. rockable
    rockable
  29. Blues4U
    Blues4U
    from So Cal
    Picked up this ahhooga horn locally and took it apart to clean it up and add some paint:
    Then mounted it on the lower right hand side of the engine. It sounds great!
  30. denis4x4
    denis4x4
    from Colorado
