Projects SBC Intake To Early Caddy Adapters
Discussion in 'The Hokey Ass Message Board' started by 60elky, Jul 6, 2021.
  1. 60elky
    60elky
    I am in the process of making adapters to put a small block Chevy intake on the early Caddy V8. I have one 3D printed and I need a motor to test fit it. I have a yard nearby with motors but I have no room for another motor in my shop. Anyone near me have a block with heads that could help with the trial fit? I live in Fort Atkinson, Wisconsin. I already make a similar adapter for the SBC to a Stude V8.
  2. kadillackid
    kadillackid
    Wow :rolleyes:...so just mill/cut away the coolant and distributor mount sections of the SBC intake and bolt on with unlimited intake options....great idea !
    oldtom69, kidcampbell71 and warbird1 like this.
  3. timeflies
    timeflies
    from Guthrie OK
    Yes, great idea!
    seb fontana likes this.
  4. 60elky
    60elky
    I finally got a lab rat test motor from a local yard last weekend. It's a 1960 390 Caddy. It is crusty and froze tight but it will serve as a test bed for fit up of the adapters. I bolted the one adapter on with a Chevy intake and the alignment looks good to the head. The manifold sits level with the motor and is equidistant from the edge of each head so I do believe I am spot on for the fit. I did order another 3D printed adapter on line last night, delivery should be by next weekend. If everything still fits well I will order a set machined from 6061 aluminum. 20210807_120032_resized.jpg 20210807_120051_resized.jpg 20210807_120104_resized.jpg 20210807_120110_resized.jpg 20210807_122434_resized.jpg 20210807_122459_resized.jpg 20210807_122518_resized.jpg 20210807_122536_resized.jpg 20210807_122610_resized.jpg 20210807_122642_resized.jpg 20210807_122657_resized.jpg 20210807_123004_resized.jpg 20210807_123047_resized.jpg
  5. jimmy six
    jimmy six
    Two thumbs up. If John K***e can put a SBC manifold on a Y-Block Ford anything is possible.
  6. bchctybob
    bchctybob
    I think someone is making the same thing for Studebakers. I think Mike VV used them to build a Chevy based cross ram for his hot rod Stude. Maybe he’ll chime in. Seems like it worked out great so the Caddy version should be good also. Nice work!
    loudbang, kadillackid and jimmy six like this.
  7. 60elky
    60elky
    I make the Studebaker adapters. $420.00 a pair, includes shipping in the lower 48. In stock.
  8. pprather
    pprather
  9. kadillackid
    kadillackid
    Will the Cad adapters be around the same price if all goes to plan ?
  10. Mike VV
    Mike VV
    from SoCal
    Yes sir. Bob and I are friends. He knows most of my stuff.
    Thanks.
    And yes again the 60elky plates are a little on the high dollar side, but if you have a "hot rod" engine, they are pretty much a requirement.
    The fit is well done.
    Mike
    pprather and loudbang like this.
  11. banjeaux bob
    banjeaux bob
    from alaska
    Jack's Auto Ranch still in business?
  12. 41rodderz
    41rodderz
    from Oregon
    :cool: Love the innovation.
  13. 60elky
    60elky
    Jack's is still in business. A guy named Doug is running it now. As for the adapter cost they should be identical to the Stude as far as machine time. The cost will depend on current material costs. I am sending the 3D model to W&S Machining in New Berlin, Wisconsin tonight for quoting. As far as the cost at $420.00 I barely make enough to pay myself to install the thread inserts and box them up so there is no way I can do them cheaper. SANY1711.JPG SANY1712.JPG
  14. unforgiven
    unforgiven
    from East Tn
    Way cool. Yes the cost is a little up there but finding a good aluminum intake for these engines can’t be cheap. With the small block intake it’s endless.
  15. nrgwizard
    nrgwizard
    from Minn. uSA
    The 60elky manifold adaptor plates have nice port alignment, so no abrupt jogs to muck up airflow.
    Marcus...
  16. gimpyshotrods
    gimpyshotrods
    I would not be able to do them for less.
    The price is fair for the work involved.
  17. Mike VV
    Mike VV
    from SoCal
    Yes, the Stude side of things are basically from a stock (OEM) gasket. The Chevy side...I've forgotten the gasket number, but they are pretty normal (un ported, smaller) size.
    This way, if the heads have been ported, you can match port the plates, then back finish the plates for whatever manifold that you choose. That's a little tricker, but can be done.
    There is NO Studebaker intake manifold that will properly (fully) feed a well designed engine, with well ported heads (CFM wise) and a larger camshaft, plus the goodies that go with all of that.
    So if you've spent a big chunk of money on ported heads, putting on a Studebaker intake manifold, will be like tossing all that porting money out an open car window...at speed..!
    And other than very expensive, Extrude Hone porting a Stude manifold, there's no other way of making one work.
    Mike
    Desoto291Hemi, bchctybob and loudbang like this.
  18. 60elky
    60elky
    To be able to port the intake to the adapters you add the small notch added to the edge of the intake. This allows you to mount the adapters to the heads using only the four outboard corners, add the intake and then by using a "wobble" type Allen you can remove the adapters with the intake still in place. These are the Stude version, The Caddy would need the notch a bit farther to the right.
  19. Smart people are fun to watch.
    I usually never have an audience
    nochop, hotrodA, brando1956 and 20 others like this.
  20. Deuces
    Deuces
  21. Dick Stevens
    Dick Stevens
    I know the feeling, I work alone most of the time!
  22. blue 49
    blue 49
    from Iowa
    An "air gap" manifold trimmed up would look like it was made for that.
    Gary
    Deuces, loudbang and Desoto291Hemi like this.
  23. 60elky
    60elky
    The SBC options are plentiful. You can go old school, say a 1956 Corvette aluminum dual quad. I picked one up for $125.00 because the water p***ages are really corroded but who care as you're cutting them off! A DCOE crossram, mine is shown on a Stude. A modern Tri-power, TPI, an old Martin turbo set up. It goes on and on.
    rod1, Hnstray, Rolleiflex and 4 others like this.
  24. lippy
    lippy
    from Ks
    Kinda like the 302 ford tunnel ram on a 351 windsor. Lippy
    Deuces and loudbang like this.
  25. Mike VV
    Mike VV
    from SoCal
    Here's my Small Chevy manifold to Studebaker, since we're showing off...
    This is a shot from the front. The thermostat "used" to be in this location.
    This is an aftermarket replacement for the mid-80's Corvette manifold, the Renegade,
    The shot below, the left side is where the thermostat used to be, on the right is where the distributor location used to be. The odd shaped hole is the remnant of where the EGR port used to be.
    What it used to look like.
    Mike
  26. 60elky
    60elky
    Mike,
    Thanks for posting more possibilities for the use of the SBC on a Stude or a Caddy.
    Jon
    Hnstray likes this.
  27. Mike,
    Great work there,,,,,,that Stude should really come alive with that !
    And for the Caddy or Studebaker,,,,,,,there are a blue million SBC intakes available .
    Man,,,,,makes me want to find an old Caddy engine now !
    Tommy
  28. 60elky
    60elky
    I got the second 3D printed adapter today. It fit well. Tomorrow I need to take it all off, re***emble it using only the end bolts to hold the adapters to the heads. That way I can remove the intake with adapters attached to the intake and verify the Chevy to adapter alignment. I will also need to bolt the adapters to the heads without gaskets and lay the intake on, (also without gaskets), to verify that everything is in fact parallel. It is difficult to see any taper between the surfaces with the gaskets in place. If the SBC alignment is good and we are parallel I'll start to push the machine shop to get me the quote. I try not to be too much of a pest as they have always treated me well and it is hard to find a quality shop that will do short runs. The bonus is that they are only 40 minutes away.
    20210819_192508_resized_1.jpg 20210819_192526_resized_1.jpg 20210819_192606_resized_1.jpg 20210819_192454_resized_1.jpg 20210807_123113_resized.jpg
  29. Mr48chev
    I'm thinking that those may get real popular with the Cadillac engine brigade. There may be a run on older style SBC aluminum intakes with bad cooling p***ages . boogered up thermostat mounting surfaces or broken bolts in the distributor hold downs though .
    gimpyshotrods likes this.
  30. 60elky
    60elky
    I tried some additional manifolds early this morning and found that a small adjustment is needed on the Chevy side. The intake from Thursday being an inexpensive aftermarket item has oversized bolt holes so it bolts up but the port alignment is not perfect. I put on two different GM aluminum manifolds and it appears I need to shift the Chevy pattern about 0.020" towards one end and down about 0.062. I had to make similar adjustments to the Studebaker version twice to get it right so I am not worried. I will get the 3D model tweaked this week, re-print and refit. I also tried an offshore Weber cross ram and observed the same adjustment are required. The last pictures are with the adapters bolted to the heads with no gaskets and the intake resting on top also with no gaskets. This shows we are spot on for parallel so that's good. 20210821_072420_resized.jpg 20210821_072439_resized.jpg 20210821_072503_resized.jpg 20210821_072933.jpg 20210821_074150_resized.jpg 20210821_074239_resized.jpg 20210821_075459_resized.jpg 20210821_075513_resized.jpg
