Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. Hamtown Al
    Hamtown Al
    Removed passenger seat to begin install of seat belts before taking car to upholstery shop. This shows the 5/16" bolts coming from the bottom with one nut to lock bolt to body so can remove seats without having to go under the car. A second nut is added after the seat frame is added. Since we were going to seat belts, I wanted to upgrade the rear bolts to 7/16" which would be much stronger. The alignment of the seat frame with the retaining bolts was a bit off, too, so plan is to fix that as well.
    Drilling the holes out to 7/16" went pretty quick and then I used a rat tail file to help relocate the bolts a little further outboard on each side. All went pretty well with my bolt stash giving me plenty of options. A little duct tape was substituted for a second set of hands in order to hold that inboard bolt until I could add a nut to the top side.;):D That Backyard Buddy is great... and gets better every day as I grow older!:D
    Old Murphy must have been watching as my newly reconfigured mounting bolts were still off... not as much; but still a bit off.:eek:
    Opportunities!:D
    I'll go back at it tomorrow... maybe.;):D
  2. choptop40
    choptop40
    Thread posted on fellow Hamber fatality....no seat belt in a roadster...thats what im doing next , wanting to go with 3 point , just have to weld a bung on the B pillar up high...ill get pics when i start...
  3. Lloyd's paint & glass
    Hey man, what time is the blue roof gang monthly meeting gonna be next month? Now that we have 3, I really think you should have to drive! :D I'll bring the food ;)
    sidewayzz69 and Blues4U like this.
  4. gimpyshotrods
    gimpyshotrods
    Heading down to the shop now to meet a customer, but yesterday I spent the day curled up in the dashboard of my Falcon, installing the electric wiper conversion motor, and started installing the AC evaporator/heater box.
    Joe Travers likes this.
  5. gimpyshotrods
    gimpyshotrods
    I finished that up last week. I now have 3-point retracing inertia reel belts in all four seating positions.
    I scaled the mounting positions based off of the wife's modern car. The positions turned out great.
    Here's a plug for Juliano's. They set me up with everything that I needed.
    https://www.julianos.com/Seat-Belts-s/96.htm
    They are in Ellington, CT. Not all that far from you, so shipping would be quick.
  6. Hank37
    Hank37
    Replaced the small air cleaners with 59 Pontiac Tri Power set up . This set has the 2 big end carbs and the smaller center carb. total cfm at full throttle is 1223 . My smaller air cleaners were actually choking down engine causing rich mixture . IMG_0113.JPG
  7. gimpyshotrods
    gimpyshotrods
    Today I made a sealing adapter to put a thermostat housing intended for a Chevrolet, over a thermostat for a Chrysler.
    They have the same bolt pattern, but the sealing surfaces don't match up well enough to actually seal. That, and on the Chevy, the thermostat recess is in the manifold. On the Chrysler, it is in the housing.
    209762149_4399243093441938_5383553889284179523_n.jpg 208831011_4399215290111385_5986295176972284051_n.jpg 213324791_4399215390111375_5196550518895756969_n.jpg 210956177_4399214886778092_7435175095793885457_n.jpg
    I spun the Moroso piece on the lathe to make a bevel for a smooth transition.
    This was a random piece of 7075 aluminum. I save my drop from other projects, until it is too small to be clamped.
  8. sidewayzz69
    sidewayzz69
    Thank you
  9. topher5150
    topher5150
    I was using my dad's old drill gun to make some holes bigger. The drill bit got hung up and the way I had my hand it bumped the trigger lock which sent it spinning out of control. Which of course in the time I was able to react the damn thing jumped up and cracked me right on the ankle
    rod1 likes this.
  10. LAROKE
    LAROKE
    From the BillyBob Shop log.
    July 7th 2021 At four inches, my biggest mic is too small for this job, so I ordered a five inch mic, one day delivery. Cleaned the number one rod, cap, wrist pin and bolts in an overnite Evapo-Rust submersion and fiddled with the piston some. The rings are flush and corroded. I couldn't budge any of them.
    I took the piston to the Sunday coffee cruise-in. John didn't make it but Dave****ton told me the marks on the thrust sides of the piston were from knurling and they were still pretty fresh. I took a look at all the pistons when I got back to the BillyBob Shop and they all have the knurling.
    Continued to measure the pistons with micrometer and cylinder bores with dial bore gauge and telescoping bore gauge until I had confidence in my measurements. Have decided to stay with the pistons I have.
    Got the corroded, stuck rings out of piston one with MAP torch, Kroil penetrating oil, small pick and needlenose pliers hand-to-hand combat technique. Background music was Jimmy Buffet's Banana Wind.
  11. topher5150
    topher5150
    I bought a spotlight a while back thinking I needed a left and a right so I only grabbed the one. Last night I was farting around with it then it dawned on me that if I just spin the light around 180 degrees that I can use it on the other side. Hopefully, the other one is still there
  12. Almostdone
    Almostdone
    Charged the Model A’s AC for the first time. It was 116 F here a week ago.
    John
  13. sidewayzz69
    sidewayzz69
    You coming down for tri fives?
  14. LOU WELLS
    LOU WELLS
    from IDAHO
    DSCN5388.JPG I Painted The Floor Where It Sleeps...
  15. impala4speed
    impala4speed
    Any particular type of paint you used Lou?
    LOU WELLS likes this.
  16. Lloyd's paint & glass
    I wish :rolleyes: my car is sitting in the same spot i parked it when i came back from the reunion. Gotta put the 283 together and swap them out, but the 10 customer cars at the shop come first.
    Blues4U likes this.
  17. sidewayzz69
    sidewayzz69
    I get that. But if you get down here,holler at me
  18. Lloyd's paint & glass
    You bet your**** man, i have your phone number :D
    sidewayzz69 likes this.
  19. e1956v
    e1956v
    Alliance Vendor
    The Defasio brothers came to the shop and got the new carpet installed, they did a great job on the seats. Hopefully I’ll get the rest of the interior back in this weekend. D26DE362-3C60-4621-B514-C020D0CA1155.jpeg 685E1B29-316E-4238-A8A7-20889148C66B.jpeg
    rod1, 40two, High test 63 and 8 others like this.
  20. I just took my Ford small block, rods and crank to the machinist, a major step for me after working on my '29AA for the past 47 years. Once I get the bill and figure out what I've got left in the budget, I'll decide when I can get the transmission sorted out. What's motivated me to take these big steps forward this summer? A year ago I was on death's doorstep, undergoing an esophagectomy to remove cancer. Two CT scans later show no recurrence so far. My next scan is in late August. By then I'm hoping to get my engine back and hear good news from my oncologist. Either way, I won't set deadlines, but I will keep pushing toward the goal of getting my dream truck together and driving it.
  21. Good luck to you, Sir. My youngest brother beat that beast. FIGHT
    Ben
    osage orange likes this.
  22. High test 63
    High test 63
    Blues4U, chevyfordman, LAROKE and 5 others like this.
  23. Thanks, guys, for having my back! High Test, that AA is right on, color, stance, utilitarian purpose. Can anyone tell me what gauge the express beds were? I'll be making my own and am hoping to bend up 16-gauge into a low, long bed, but would use 18-gauge if that's the correct thickness.
    High test 63 likes this.
  24. HSF
    HSF
    from Lodi CA
    rod1, LAROKE, j hansen and 3 others like this.
  25. wvenfield
    wvenfield
    Got my car aligned. He had me come over to****ist. It was interesting as I've never done this before. 56 Pontiac with 51 Chevy straight axle. We didn't have it far off but he had to adjust the toe in and camber. Noticeable difference on the road.
    LAROKE, j hansen, Lil32 and 3 others like this.
  26. Hank37
    Hank37
    Bought a old stock car 36 3 window GM body , it ran at the Reading Fairgrounds when I was a kid . IMG_3493.JPG
  27. LOU WELLS
    LOU WELLS
    from IDAHO
    The Rust-oleum Product b64897f5-e8d2-4775-810f-5fdcd0069e4d.jpg Worked Excellent And Dried Very Nicely.....Thanks...
  28. impala4speed
    impala4speed
    Thank you!
  29. topher5150
    topher5150
    I wonder if that works on old rusty cars
  30. saltflats
    saltflats
    from Missouri
    Running a big block, must be tough crowd. :D
