Hot Rods Let's Chop 50FRAUD
Discussion in 'The Hokey Ass Message Board' started by DRD57, Jul 8, 2021.
  1. DRD57
    DRD57
    Some of y’all are straight up going to have a heart attack at the mere mention of this but, I ***ure you if you remain calm and follow along everything will be OK in the end. Remember when you said that a 40 Ford could not be improved upon? We did that and it worked out OK so, you’re going to have to trust us on this one.
    54delray, chryslerfan55, Stu and 25 others like this.
  2. DRD57
    DRD57
    Tony called a while back and said he wanted to build another car, a hot rod shoebox coupe. We spec’d the whole thing out, established a budget and he started looking for a car. He soon realized he didn’t want an additional car so, one would have to be sold. Not wanting to sell the 40 convertible or 50FRAUD. The plan changed to update 50FRAUD with some of the things that he wished he had done when it was first built as well as a few repairs that it needed.
    The biggest update was to chop the top about 2 ½ inches, much like this car he had seen years ago.
    Before cutting in to the car we enlisted the design ***istance of Rik Hoving who provided several quality Photoshop renderings. Tony selected one that was quite striking in that the quarter windows are actually longer front to back than they were stock. Normally, they would have become shorter when chopping a top and sliding it forward a few inches. This one change along with a few others that are more subtle make this more of a custom roof than merely a top chop.
    54delray, OzMerc39, Silva and 27 others like this.
  3. DRD57
    DRD57
    First step: strip it down. Remove the interior, all the gl*** and the trim around the roof.
    Next up, tack some tubing in the car to maintain the structural integrity. This may not have been all that necessary since this model was built on a convertible ch***is but, better safe than sorry.
    Start cutting. Scaling Rik’s rendering gave us a 2 ½ inch vertical difference. Converting that to the linear cut down the A pillar was 3 ¼ inches.
    54delray, OzMerc39, 2Blue2 and 23 others like this.
  4. DRD57
    DRD57
    Obligatory “roof on floor” and ‘car with no roof” shots. I believe it is required by law to do***ent these two images whenever chopping a top.
    54delray, OzMerc39, brEad and 31 others like this.
  5. DRD57
    DRD57
    At first we just set the top back on to see how everything lined up. At this point you can decide to tilt the A & C pillars to get everything to line up or quarter the roof. The former option is typically easier but the latter offers several benefits in our case. Not tilting the pillars makes for easier fitment of garnish moldings, also hard top window will align more easily and most importantly, since we’re lengthening the quarter windows and using a 53 station wagon rear window which has a bit less curve than we would like, we want as much length and width in the roof as we can get.
    IMG_7498.jpg IMG_7502.jpg IMG_7604.jpg IMG_7605.jpg IMG_7606.jpg IMG_7610.jpg IMG_7611.jpg
    54delray, drdave, OzMerc39 and 32 others like this.
  6. DRD57
    DRD57
    Scaling the renderings again gave us a template for the quarter window shape and size.
  7. DRD57
    DRD57
    The rain gutters were completely remove and new ones fabricated from 3 pieces of 22 gauge steel. The original style stainless trim will attach to the edge just as it did before.
    IMG_7628.jpg IMG_7629.jpg IMG_7630.jpg IMG_7633.jpg IMG_7634.jpg IMG_7635.jpg
  8. DRD57
    DRD57
    Speaking of rain gutters, the piece that went around the front of the roof has been removed. 51 Victorias have a lot of sheet metal above the windshield. Chopping the top somewhat upsets the balance between this sheet metal m*** and the gl***. So, to minimize the “giant forehead” look we opted to remove the rain gutter above the windshield and move top of the windshield up into the roof.
    IMG_7302.jpg IMG_7698.jpg IMG_7700.jpg IMG_7703.jpg IMG_7727.jpg IMG_7728.jpg IMG_7734.jpg
    Next up we did some preliminary modification and fitment of interior and exterior trim, and quarter window mechanisms before finish welding the top. We’ll get back to that later.
  9. DRD57
    DRD57
    Patching those 1”+ gaps that now run the length and width of the top would surely be disastrous from the heat induced from that much welding. A much better approach is to re-skin the roof. We could make a new skin with a new sheet of metal and several hours on the E-wheel but, we decided to try to find another roof skin first.
  10. DRD57
    DRD57
    We made some profile gauges out of OSB and headed to Turner’s Auto Wrecking in Fresno to see what we could find. After scrounging around an area full of 50’s FOMOCO relics, we decided a 56 Mercury roof was close enough to do the job so we started our trek across the 100 acre yard back to the office. On the way we happened upon a 55 Chrysler Windsor and on a whim threw the profile gauges up on the roof. Dead nuts match in both directions. It’s a little longer than we need but, that’s OK. We have to do a bunch of t******* and fitting anyway.
    JalopyJimbo, Baumi, 54delray and 28 others like this.
  11. DRD57
    DRD57
    Rob spent the next few days t******* on the Windsor & Victoria roofs to get a near perfect fit, then TIG welding them together and sanding the old finishes off in preparation for epoxy primer and a skim coat of filler. The toughest part of this proved to be getting the Windsor top down to bare metal. Whatever was under that original finish was tougher than 36 grit sanding disks.
    IMG_8199.jpg IMG_8200.jpg IMG_8201.jpg IMG_8202.jpg IMG_8203.jpg IMG_8204.jpg IMG_8205.jpg
    54delray, lucky ink, brEad and 21 others like this.
  12. DRD57
    DRD57
  13. DRD57
    DRD57
  14. SEAAIRE354
    SEAAIRE354
    Outstanding. I haven’t personally seen a chop on theses cars and as far as I’m concerned you nailed it. Can’t wait to see it with paint and the trim back on.
    54delray, loudbang, 50Fraud and 2 others like this.
  15. The only pisser with chopping one of these is you always lose the signature wrap-around rear window. With that gone they look like a hardtopped coupe. Isn't there a suitable windshield that could be cut down to fit?
    Good call on the windshield opening.
  16. I actually think that wagon rear gl*** is genious compared to how most are handled. looks factory.
  17. X38
    X38
    Completely re frauded. Nice.
    There's no work like a ton of work!
  18. I'll agree that rear gl*** looks better than most, but that wrap around is my favorite styling cue on these and is what sets them apart from the more mundane models.
  19. IMO, this is the only chopped 1952 ford Victoria that I have seen that looks good.
  20. 56MercMan
    56MercMan
    I agree with Crazy Steve. When looking over the pictures I saw the beautiful rear window and trim. I saw him chop and was interested in seeing them handle it. Then saw it was all gone. Bummer.
    The work and outcome is way better then anything I could do so just my 2 cents.
  21. Stogy
    Stogy
    Stellar, well do***ented and executed Custom work @DRD57...and congrats @50Fraud with your latest Period Custom coming together seemingly overnight...at this rate you'll be driving in 2 more weeks... ;)
  22. 57 Fargo
    57 Fargo
    Bad ***.
    Stogy likes this.
  23. Gangrene
    Gangrene
    **** yes!
    loudbang and Stogy like this.
  24. DRD57
    DRD57
    A windshield could possibly be used for a wrap around rear window but, it would take a lot of junk yard searching with templates to find one that would work. Gl*** doesn't bend so, it would have to be perfect.
    A more doable way to achieve that look would be to sink the bottom of the gl*** into the package tray. The rear gl*** is tempered and I've been told by several experienced gl*** guys that it cannot be cut.
    Tony's selection of the wagon rear gl*** had a lot to do with recreating the vibe of the car in **** Page's photo at the top of this thread.
    54delray, OzMerc39, Blues4U and 7 others like this.
  25. evintho
    evintho
    Absolutely outstanding work! That's the first '50 Ford I've seen that looks right with a chop. You guys nailed it!
    OzMerc39, loudbang, 50Fraud and 2 others like this.
  26. 50Fraud
    50Fraud
    The Victoria that **** Page built for Tim Smith years ago (shown in Don's 2nd post in this thread) was clearly the influence that had me decide to cut up my car. **** also used a wagon liftgate window, and I really like its appearance, so I chose to copy it. I've had this Victoria for 30+ years, and realize that I'll be giving up some peripheral vision with the smaller window, but I really like the looks of the solid, windowless roof behind the quarter windows.
    Great thread, Don!
  27. 50Fraud
    50Fraud
    The car is actually a '51 (first year for the Victoria body style), disguised as a '50 by using the trim from the earlier shoebox. Hence my handle, "50Fraud".
  28. Russ B
    Russ B
    Tony, I loved the car before, but I know I will love this version even more. The Chrysler roof piece looks like a perfect choice. Headlights, grill? Any hints?
  29. drtrcrV-8
    drtrcrV-8
    If you have a video of this chop, it would /should be the instructional video for a cl*** about "How to chop a top properly"!! OUTSTANDING WORK!! We know it's not nearly as easy as you just made it look, so thank you again!!
  30. Ken Smith
    Ken Smith
    Alliance Vendor
    I think it’s beautiful. Great lines! Good job Tony and Don and the HW99 team.
    54delray, OzMerc39, Bob Lowry and 3 others like this.
