Projects 1963.5-1964 Ford galaxie 500xl
Discussion in 'The Hokey Ass Message Board' started by Brodbeckh, Jul 13, 2021.
  1. Brodbeckh
    Brodbeckh
    564496CC-1C84-4E8E-8F3A-6525D778C7A9.jpeg 9B466B45-D835-433F-8BD2-3ADAAEED5279.jpeg E4E14F97-8828-49EE-9908-B959CB8152A9.jpeg 2A842092-243A-4E70-8FAC-5C0CEA8A63FB.jpeg 50452A24-7A68-4C4A-A652-1ACC43567281.jpeg How much should I pay and does anyone know what engine it is? More of a gm guy
    quick85 likes this.
  2. warhorseracing
    warhorseracing
    from cameron wv
    FE engine, possibly a 352. Interior looks serviceable albeit dirty and would probably clean up to be acceptable. Body appears solid but no real pictures of the rockers and missing rear end trim. Underneath what about the floors and frame for rust. Also an AC car and automatic transmission. Does it even run? Maybe $300 depending on where you live.
  3. Bucket seats and console. In our world it would be 400 bucks for s****. Would likely be listed for 4500 on our equivalent of craigs list if it had an ownership. Looks like a big project.
  4. 1964 Galaxie, not a 63-1/2. Probably a 352, but if the original engine the fender emblems or the VIN # will tell. A clean ***le would be a major factor of price.
  5. greybeard360
    greybeard360
    352 or 390.... A/C compressor is missing. Looks Like add on anyway.
  6. Joe Travers
    Joe Travers
    from Louisiana
    Later model FE air breather. New paint. Stock displacement on badge on front fender, likely 390. Hard to tell displacement on a rebuild by codes. Have to measure stroke. It's worth what a person is willing to pay. Take into account of current value and falling trends. A positive factor, many parts are available.
    Joe
  7. It was originally a 390FE car if the fender emblems are original. But someone has been at the motor as it has newer-model valve covers, maybe a swap to replace a failed one? And how rusty is it? Major rust repair drives down the price. It is a desirable model and looks reasonably complete. ***uming the motor is non-running but rebuildable, I'd say...
    Major rust (floors/trunk, rockers, doors, hood and trunk lid) $2K max.
    Less serious rust, $3500 max.
    Prices do vary by location, around here that would probably be a $1500-2000 car.
  8. ahshoe
    ahshoe
    Does it have a clear ***le current and in your name?Where you located?
  9. egads
    egads
    Looks like factory ac. Like @Crazy Steve posted above, late model valve cover's and blue block. Does it turn over? 64 rear bumper's are crazy expensive. Look's like a fun project though. As stated- no ***le- run away.
    warhorseracing likes this.
  10. jaracer
    jaracer
    It looks like a newer engine since it appears to have the newer emissions vacuum advance and it looks like a module for Ford electronic ignition. Even the air cleaner is quite a bit newer than 1964. I'm not completely sure it is an FE engine. The intake manifold on an FE is part of the head and this one looks the intake/head attachment point is different. It might be a 429/460.
  11. greybeard360
    greybeard360
    It is an FE , obvious by the valve covers and surge tank .... That is a voltage regulator on the right fender apron... A replacement transistor type Ford started using in the late 70's.
  12. Brodbeckh
    Brodbeckh
    North Arkansas and is at a failed used car lot
  13. Brodbeckh
    Brodbeckh
    I haven’t checked I was sorta tresp***ing when looking at it
  14. Brodbeckh
    Brodbeckh
    rpm56 and stillrunners like this.
  15. Brodbeckh
    Brodbeckh
    My friend said 2k also which is money I easily have
  16. Brodbeckh
    Brodbeckh
  17. evintho
    evintho
  18. BamaMav
    BamaMav
    from Berry, AL
    Depends on your money and your skills level. These cars are notorious for rust in several places, can you do the repair yourself or will you have to pay someone to do it? Is AR a ***le state? If so, can you get it with a clean ***le? The bucket seats and console are desirable, harder to find items. Most were bench seat cars.
    I wouldn't give over $1000 for it, but I'm cheap. But then again, I wouldn't have to worry about a ***le where I live, so there is that.
  19. What's the plan for the car? A correct restoration will be expensive; there's a bunch of cobbled junk under the hood and the sun-baked aluminum trim won't be cheap to restore. The upholstery may look 'ok' but will probably come apart in use. But as a basis for a nice cruiser, it has possibilities. Clear ***le is another issue; I don't know how Arkansas is about that, but no ***le where I live means it's a parts car unless it's really valuable. But that car will be a fairly serious project, if you're new to the hobby it may prove cheaper in the long run to buy a better car to start with. If you're paying somebody else to do some or most of the heavy lifting that will be particularly true.
    egads and lothiandon1940 like this.
  20. williebill
    williebill
    You are getting some very good advice from HAMBers, and you have a lot to think about. I love those Galaxies, probably cause I was 11-12 years old when they came out, and there were a couple in my neighborhood that I thought were cool as Hell. But the question is how much do you love these cars? I'm half blind, but can see a couple of areas on the body that would concern me.
    lothiandon1940 likes this.
  21. stillrunners
    stillrunners
    from dallas
    Not for 2 grand - that's my in put and I've owned and drove both a 63 1/2 FE with 4sp and a 64 with a 352 3 on the tree. That car needs a lot of luv - $750 would be a good offer - and like was said - and I'm sure this one doesn't have a ***le - turn away from it.
    rpm56, lothiandon1940 and flatford39 like this.
  22. RmK57
    RmK57
    The worst way to ever park a car up is on dirt or gr***. I'd be surprised if it had any floors left in it.
  23. Mr48chev
    My neighbor gal in Texas way back in 1969 had what was probably the nicest example of one of those in Texas and maybe the US at the time.
    She was the office gal at the local Ford Dealer and the car was a special order as far as I know.
    I'd say that you have to be a real fan of mid 60's Full size Fords (that's the best looking body style of the batch) and willing to go to the effort to do it right and are not settling for the first old car that might be in your price range you find.
    Still the ***le means a lot. Clear transferable ***le is worth quite a bit.
    If it isn't you dream car I'd leave it for the guy who is dreaming of that exact model though.
    Settled for very often doesn't end up near as well as you thought it might.
  24. Brodbeckh
    Brodbeckh
    Mostly not a top down but just basic restoration then clapp it out to look like a g***er or hotrod with some nice slicks in back
  25. 6sally6
    6sally6
    $1500 .........part it out (bite-my-tongue) and get your money back EZ. Engine and ****** (4-speed?!) buckets and console and a few other goodies are pretty hard to find for guys looking for that stuff.
    Nice parting out project OR......you might get lucky........not much rust.........engine fires......got yourself a nice ridding performance barge for a little money and some TLC!!
    Do it!
    6sally6
  26. Brodbeckh
    Brodbeckh
    I’m a big fan of falcons and this is like the better version of that
    most likely the wheels are dry rotted so most likely take the tires to a plant and sell rims and get sum custom ones I’ll mail the guy and do a more in depth look at it and will do a better field ***esment
  27. Brodbeckh
    Brodbeckh
    I want to full send on car also is a automatic which I’ll swap to a 4 speed if lucky 3 speed when ready
  28. Brodbeckh
    Brodbeckh
    It was from a shut down used car dealer so there’s a high chance of ***le
    egads likes this.
  29. Brodbeckh
    Brodbeckh
    Really love the body style unlike the 65s version and maybe a bigger engine which I like and what should I look out for on rust
  30. Brodbeckh
    Brodbeckh
    Where are the trouble spots I should look at? And i would to the body myself
