Technical Painting Around Front and Rear Windows 1950 Ford
Discussion in 'Traditional Customs' started by Chop50, Jul 13, 2021.
  1. Chop50
    Chop50
    Hi All,
    I have been told that there is a technique or a product that will raise the windshield and rear window gasket so that you can paint under them thus letting paint flow under the gasket rather than right up to the edge of the gasket. How are folks doing that?
    Thanks, Steve
  2. stillrunners
    stillrunners
    from dallas
    Large paper clips - fold them over.....or....
  3. HSF
    HSF
    from Lodi CA
    3m lifting tape. Half of it is hard plastic, the other half is pliable adhesive. Slide the hard half under the rubber and fold the adhesive half onto and over the top . I prefer to pull the gl*** though.
    lothiandon1940 likes this.
  4. evintho
    evintho
    Pull the gl***, not hard to do. Gives you an excuse to replace the front and rear gaskets.
  5. dalesnyder
    dalesnyder
    I lifted the rubber and stuffed rope under it. That 3m stuff sounds good though,
  6. Chop50
    Chop50
    I put wire under there but rope probably better.
    Windshield is chopped so dont want to get into replacing gasket..
    Thanks Steve
    Tman likes this.
  7. warhorseracing
    warhorseracing
    from cameron wv
    If the rubber is pliable then careful removal will not require replacing it. Patience is your friend.
  8. bobd1976
    bobd1976
    from Illinois
    We always pull the gl***. IMHO the right way to do it.
