Technical Early East Coast Hot Rod Parts Find
Discussion in 'Traditional Hot Rods' started by Boxcar's 1928, Jul 14, 2021.
  1. Boxcar's 1928
    Boxcar's 1928
    I just picked up this front-end from a buddy that is from the PA area. Allegedly the 36 Ford it came off of drag raced there in the 50s/60s. This front-end was on the car prior to the 70s.
    It's a little mix of good, bad, and ugly... Thought it was interesting enough to share.
    The good: Dropped and filled I beam.... The filled area is so flat that....as this is the first one I've ever touched/owned.... I'd have suspected something that would show it had been filled. But it's pretty perfect in the area. Anyone know if there was an east coast shop doing these??? Roughly measured kingpin and perches....believe it's width is typical to 28's to 3's6 .....perch width seems to be 36 but king pins seem to be less than 50in width. I'll take a better look at it this weekend...And here's the car it was on... a cool Cabrolet with a 3 deuce Merc with all the t*******s. I suspect the car now has a 350 and auto...Oh yea, it's been bagged too (much to the disgust of the present owner)
    bchctybob, kidcampbell71 and dwollam like this.
  2. Boxcar's 1928
    Boxcar's 1928
    Equipped with juice brakes...notice the air holes and the scalloped vents riveted on the backer plate... I really like those. And they have screens inside one...the other is missing.
  3. Boxcar's 1928
    Boxcar's 1928
    Some of the ugly is what they did with the spindles....geesh.
    They will be replaced...but you gotta respect the ingenuity. Ha ha. There's two cuts that have been made on the cross steering arm and welded to change the direction 'crafting'. I got some replacements to choose from. My intent is to keep this front end nostalgic and only fix what's gonna kill me.
  4. Boxcar's 1928
    Boxcar's 1928
    And here's the poor wishbones... And the spring pack...it's got some non matching additions.... but what I think is cool is that the primary group of leaves are tapered at the ends both ways to a very thin point. Believe this too was a trick mod...but not sure.
    I'll re-do the ends of the bones...very poor execution on them as it is.
    dwollam likes this.
  5. Boxcar's 1928
    Boxcar's 1928
    More pics... oh....and the steering...yowsa!! There's a lot to take in with this little time capsule of cool. Hope yall enjoy it. They "clearance" the bones with a BFH...not sure I got a good enough pick of that....both under sides too....of course. I probably leave that alone...it's not viewable unless your under the car and staring at it.
    Big Al and dwollam like this.
  6. xlr8
    xlr8
    from Idaho
    I'm pretty sure that for at least a year or two the ends of the leaves were tapered like that from the factory, I have a spring that looks just like that.
  7. Boxcar's 1928
    Boxcar's 1928
    What year is your car?
  8. J. A. Miller
    J. A. Miller
    from Central NY
    The brake scoops (vents) are kitchen drawer pulls from the 40s. Very cool!
  9. xlr8
    xlr8
    from Idaho
    I don't have the car, just the spring, the axle it was on I believe to be a '35 or '36.
  10. Boxcar's 1928
    Boxcar's 1928
    Drawer pulls...well I'll be!!!
  11. J. A. Miller
    J. A. Miller
    from Central NY
  12. Boxcar's 1928
    Boxcar's 1928
  13. general gow
    general gow
    MODERATOR
    yup. those leaves are stock. i love the drawer pull vents. might have to put that trick to use...
    bchctybob and Boxcar's 1928 like this.
  14. ChuckleHead_Al
    ChuckleHead_Al
    Man I'm digging those vents.
    Boxcar's 1928 and olscrounger like this.
  15. Atwater Mike
    Atwater Mike
    I found some 'pulls' in the kitchen section of Home Depot. (whole drawer full of different sizes, some plated, some not...)
    I have some stashed away for my tub, roadster, and 'coupester'...
    Boxcar's 1928 likes this.
  16. hotrodA
    hotrodA
    I put a dropped and filled axle like yours under my roadster. Bought it at a swap meet back in the mid 70's for $35. It was a nicely done piece, and I've never seen another one.
  17. Boxcar's 1928
    Boxcar's 1928
