Hot Rods New 1932 Model A K-members
Discussion in 'The Hokey Ass Message Board' started by loudpedal, Jul 14, 2021.
  1. loudpedal
    loudpedal
    from SLC Utah
    212256621_2260315130765744_6271291170671455453_n.jpg Please Delete if not allowed.
    We are taking orders on new K-members, pedal ***emblies and master cylinder bell-crank ***emblies. There are always questions, but here are some of the frequently asked ones;
    1932 style K member for Model A ch***is.
    * Put a V8 and 3-speed in your Model A with no guesswork.
    * Right and Left hand drive.
    * Designed for use with our engine mount brackets.
    * Available Pedal ***embly or use your 32 pedals (with minor pedal box modification)
    * Available Master Cylinder Bell-crank ***embly.
    * Access your Master Cylinder through the floorboard.
    * Provisions for chatter rods.
    * Uses stock 1932 Ford pedal return springs and transmission mount.
    * Intended for WELD in installation, but can be bolted/riveted in.
    * $699.99 ‘32 style, Model A, K member.
    * $749.99 Pedal ***embly.
    * $499.99 Master Cylinder Bell-crank ***embly with clevises and linkage.
    * $89.99 Engine Mount Brackets.
    These are the first pieces to a comprehensive AV8 kit, with more parts like front wishbone, torque tube spacer and chatter rods coming soon. Also, we have a open drive T5 version of this K-member for the Model A that will be in production soon.
    These parts have not been put on our website yet, so until then, Email SaltCitySpeedShop1@gmail.com or call the shop during business hours 385-777-1934 to Pre-order.
    Thanks,
    Kris
    214542368_548207129926289_7929139110926270850_n.jpg 213775010_548207133259622_5751775831733315091_n.jpg 216503791_548207136592955_3208434135591080906_n.jpg 214319816_548207106592958_4264626573913442424_n.jpg 214782833_548207123259623_6256437781276526406_n.jpg 215005008_548207126592956_8863079802849005916_n.jpg
    29EHV8, vtx1800, clem and 30 others like this.
  2. gnichols
    gnichols
    from Tampa, FL
  3. 51 mercules
    51 mercules
  4. Super nice work! I hope I get to use them sometime!
    loudpedal likes this.
  5. thommoina33
    thommoina33
    Alliance Member
    from australia
    Kris, will you be doing a K member for stock dimension 32 frames, both open drive, ie: T5 and closed drive?
  6. loudpedal
    loudpedal
    from SLC Utah
    Yes I have the open drive T5 Prototype for the 32 frame in my hands I just have to put it together and put it in the frame to check everything. The closed Drive 3 speed version for the stock 32 frame is done, I'm just waiting for a batch to show up from the laser cutter for those. I'm also making master cylinder Bell cranks that will fit the stock 32 K-members both left and right hand drive.
    UGOTBIT, dirt t, unforgiven and 5 others like this.
  7. clem
    clem
    Looks like a great product and well designed and well made ! - bttt……
  8. brading
    brading
    Nice work there. Can see that is going to save a lot of guys a lot of pain in the ****.
  9. partsdawg
    partsdawg
    from Minnesota
    Eye candy.
  10. Tim
    Tim
    from KCMO
    Slick!
  11. WiredSpider
    WiredSpider
    So the pedal ***y and the master cyl bellcrank is $1250?
    Wow
  12. dirt car
    dirt car
    from nebraska
    Nice work ! While I happen to be one of those who wouldn't even consider chopping an original 32 'K' member ... to each his own. I personally would probably opt. for an F-1 modified drop out cross member or what you so skillfully offer, I can only imagine what a pain those originals were when it came time for transmission service, perhaps your version bolted in could resolve that issue as well.
  13. loudpedal
    loudpedal
    from SLC Utah
    I don't know if you've noticed, but the cost of materials right now is Sky High. I don't work for free and I would bet you don't either.
    We are working on a few things that could be bringing the cost down but I WILL NOT resort to inferior Chinese parts or labor to do so.
  14. loudpedal
    loudpedal
    from SLC Utah
    I can pull the engine and transmission out of one of these cars in under an hour. It really isn't that big of a deal.
    clem, 97, sodbuster and 1 other person like this.
  15. Ken Smith
    Ken Smith
    Alliance Vendor
    Very nice.
  16. Tim
    Tim
    from KCMO
    If you haven’t bought any metal in the last year and a half I don’t think you’d believe how much higher it is. Absolutely effects product price
    gimpyshotrods and loudpedal like this.
  17. tjm73
    tjm73
    If you can get material. Work in the commercial door and hardware business and what took 4-6 weeks is now an easy 8-12. Some aluminum suppliers have told me they have orders on the books that won't ship until 2023.
    sodbuster, loudpedal and Tim like this.
  18. glennpm
    glennpm
    Beautiful pieces!
    kidcampbell71 and loudpedal like this.
  19. I was just saying the other day how cool it would be if someone with the know how and equipment could build an AV8 kit. YOU DID IT! VERY NICE! Now if only someone could fab new "A" rails and rear dog legs, there could be an AV8 complete ch***is kit to use with Brookville bodies. Brand new period hot rods with out sacrificing old irreplaceable iron. The price point is not bad considering. I may order one. Very cool! Thanks for filling that gap were Tardel left off.
  20. glennpm
    glennpm
    Hey Kris,
    "I can pull the engine and transmission out of one of these cars in under an hour. It really isn't that big of a deal."
    Not if you have a full fendered car. Hood off, exhaust disconnects, wiring, radiator drain and pull it and shell, torque tube clam shell, blocking torque tube, etc. equals lots of work. A bolt on, drop down for transmission only removal would be a good thing :)
    HemiDeuce likes this.
  21. loudpedal
    loudpedal
    from SLC Utah
    Wanna bet?$? I've done it many times in the past ...as a matter of fact I did it two weeks ago (full fenders and all). It's not much work, if you are smart going about it. The 32 may as well have a zipper.
    On second thought, I have over 25 years of working flat rate jobs in a car dealership. I don't F-around. It may take others an hour and twenty minutes if they are trying hard enough.
    clem, Nominal, kidcampbell71 and 2 others like this.
  22. glennpm
    glennpm
    "It may take others an hour and twenty minutes if they are trying hard enough."
    Tim likes this.
  23. Tim
    Tim
    from KCMO
    I’ve seen new unboxed A rails available, not sure where it was. I know that Rjays sells boxed A rails
  24. I've seen the boxed rails with the square tube Z'd rear cross member, but I haven't seen true unboxed "A" frame rails. I have seen new front crossmembers, but never the rears. Maybe one shop could get with another shop and list this stuff in one spot to ease the search. The old stuff is cool, don't get me wrong, but new solutions are very cool too. They all have there place when it comes to skill level and style of the builders. Really neat stuff!
  25. Very cool. Will the prices be the same for 32 rails? Super nice quality right there. I love the comment about flat rate as most people have no idea how that works and how hard you have to work to make it successful as a paycheck.
  26. sodbuster
    sodbuster
    from Kansas
  27. loudpedal
    loudpedal
    from SLC Utah
    It should be close to the same.
    kidcampbell71 likes this.
  28. Budget36
    Budget36
    Dang, I don’t and probably never will have an A, but I want one! Lol. Nice looking piece you have made
  29. loudpedal
    loudpedal
    from SLC Utah
    Thanks for the compliment!
    Budget36 likes this.
  30. dirt car
    dirt car
    from nebraska
    Sorry if my previous posting created a storm of less than favorable comments, I've always supported talent such as yours that provides the pieces & or parts for those without the knowledge or tools to do so, thusly enabling the most novice builder to move forward over-coming a potential stalled project. Rally-on !
