Technical Where did you mount your horn on your hot rod or custom?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Jul 6, 2021.
  1. Almostdone
    Almostdone
  2. goldmountain
    goldmountain
    Mounted on the frame rail where most guys would mount a Vega steering box. Doesn't matter how loud the horn is anyway. By the time I figure I need to use it, the other car is long gone.
    Stogy and HOTRODPRIMER like this.
  3. chevy57dude
    chevy57dude
    Since the fender ducts are removed, I mounted a pair of GM hi/low note horns behind the headlight screen.
    bchctybob, Stogy, rbrewer and 6 others like this.
  4. 3W JOHN
    3W JOHN
    I used a old pair of trumpet horns under the floor of my T and they were so loud you could feel a vibration in the steering wheel.
  5. 3W JOHN
    3W JOHN
    Before I got the seat upholstered I sat on a piece of foam, those dual trumpet horn tickled my**** when I laid down on the horn. :cool:
  6. Dan Hay
    Dan Hay
    I kinda want to put one under the tail pan for the tailgaters. Happens way more often than someone needing a toot from the front.
  7. HOTRODPRIMER
    HOTRODPRIMER
    Might be a good idea Dan. HRP
    Stogy, Lil32 and Dan Hay like this.
  8. ct1932ford
    ct1932ford
  9. HOTRODPRIMER
    HOTRODPRIMER
  10. ct1932ford
    ct1932ford
    Yep!
  11. HOTRODPRIMER
    HOTRODPRIMER
    What did you use on the recent 5 window, and after owning a car with some notoriety ( Coleman Coupe) have you dreamed up a name for your current car? HRP
  12. 40Standard
    40Standard
    from Indy
    I don't have a horn in my 40. would like something loud, maybe like a locomotive, if that's legal
  13. HOTRODPRIMER
    HOTRODPRIMER
    You are in luck, there is a train horn that is small but big sound at 300DB Super Loud Electric horn that is 12 volt, and less than 15 bucks. HRP
    300DB horn
    Stogy likes this.
  14. Lil32
    Lil32
    under coupe floor
  15. ct1932ford
    ct1932ford
    Stock 32 horn on the coupe. :cool: No name yet for the coupe although I used plenty of four letter words on it this past Winter.
    Especially when I broke my finger on the rear spring.:eek:
    Open to ideas:rolleyes:
    Stogy, Lil32 and HOTRODPRIMER like this.
  16. willys36
    willys36
    On the Mysterion I put an AOOOGA horn in the nose piece. This is what I imagine Ed would have done.
    bchctybob, Stogy, Tim and 2 others like this.
  17. HOTRODPRIMER
    HOTRODPRIMER
    "Sunny Beach" :D HRP
    ct1932ford and Stogy like this.
  18. Fogger
    Fogger
    When I built my '32 Roadster I mounted a Ford trumpet horn on the radiator support rods above the engine. Seemed like a great place and is quite loud. IMG_0235.jpg
    Stogy, HOTRODPRIMER and Lil32 like this.
  19. 40Standard
    40Standard
    from Indy
    thank you Danny for the loud horn advice
  20. HOTRODPRIMER
    HOTRODPRIMER
    You are most welcome. HRP
  21. winr
    winr
    from Texas
    On under side of hood
    Ricky.
  22. Tim
    Tim
    from KCMO
    a six volt 53 Ford horn with twelve volts going threw it is my personal favorite. You’d think a barge was coming your way haha
  23. Rand Man
    Rand Man
    I mount my horns right on the front of the hood, just like Boss Hog.
    Stogy, HOTRODPRIMER and Bandit Billy like this.
  24. Bandit Billy
    Bandit Billy
    I mounted a loud decibel horn inside the grille area on my 34 and used a 36 horn cover to, well, cover it.
    Mounted it from the back side
    Liked it so much I did a similar thing to my 41 PU.
    Peaking through the grille
    bchctybob, Stogy, Rand Man and 3 others like this.
  25. LOU WELLS
    LOU WELLS
    from IDAHO
    I Put It Under The Seat So I Could Wake Up The Driver Before We Get Home... 414KVUBEGyL__AC_.jpg
    UNCLECHET, bchctybob, Stogy and 2 others like this.
  26. Rramjet1
    Rramjet1
    Put a couple of 50’s 6volt Spartan horns on our 50 Chevy. Really loud on 12 volts. Had to increase the fuse size after the first try. Trying to find something louder for my avatar car right now.
    Stogy, Just Gary and HOTRODPRIMER like this.
  27. Stogy
    Stogy
    The Squeaker or Meeper...:D...is just under the Driver Side floor near the Master Cylinder...to to boxed frame...
    I think someday a Caddy or Locomotive tone Baritone might be fitting...
    Horns were an under hood orchestra of Outta My Way with a musical note...
    Let's see...
    :rolleyes:...installed on inside of frame near directly below the down pipe flange...
    I period this Hotrod 1963 and that sound is worthy of a bigger notable sound...
  28. Rand Man
    Rand Man
    Hey, I like the roof of your sport coupe. Do you have a build thread on that roof?
    Lil32, Stogy and HOTRODPRIMER like this.
  29. WB69
    WB69
    from Kansas
    I have an 89 Caddy setting in the shed that has a very loud factory horn! Sounds like you are about to meet a tugboat when it's hooked.
  30. WB69
    WB69
    from Kansas
    All mine are stock in the stock location. I guess not much imagination on my part.
