Technical King pin inclination on 1953 to 1960 F100 front axle
Discussion in 'The Hokey Ass Message Board' started by winr, Jul 15, 2021.
  1. winr
    winr
    from Texas
    Any know how much a 1953 to 1960 F100 front axle weighs with or without spindles ?? ....EDITED ...Any know the king pin inclination on the above axles ??
    Ricky.
  2. greybeard360
    greybeard360
  3. winr
    winr
    from Texas
    Thanks gr360 !
    I have an F1 axle, looks like it has an 8 degree inclination with a smaller king pin
    Ricky.
  4. homey chromey
    homey chromey
    I generally go a little more. About 5 to 5.5. I set my 49 F1 just over 5 and it drives great. I set all my straight axle cars at 4 to 5 deg.
  5. Rickybop
    Rickybop
    And belaboring the obvious for most here, but the setting is relative to level, not relative to the ch***is. Due to variations in the rake of the vehicle.
    Correct?
    Tim likes this.
  6. Fordors
    Fordors
    F23CBD1F-7AB9-4FA4-B8CF-71559BCFFE8C.jpeg The OP’s question is related to camber, not caster.
    2OLD2FAST likes this.
  7. 2OLD2FAST
    2OLD2FAST
    from illinois
    Here ya go
  8. X38
    X38
    Some of you guys are confusing KPI with caster.
  9. homey chromey
    homey chromey
    Older Ford trucks like to wonder. I was referring to castor and that is king pin inclination. And that to be determined with car being level to start with. Then set castor. Obviously if you have 30" tires on the rear and 24" tires on the front and set at 5 deg. you probably only truly have 1 deg. actually. And I know that is an exaggeration.
  10. wulf powis
    wulf powis
    Maybe this will help upload_2021-7-16_17-42-59.png upload_2021-7-16_17-42-59.jpeg
  11. X38
    X38
    Sorry man, but no. Caster is how much the king pin/axle leans back or forward.
    KPI is related to camber, it is the king pin inclination as viewed from the front. @2OLD2FAST provided a diagram. It was IFS, but the principal is the same.
  12. 2OLD2FAST
    2OLD2FAST
    from illinois
    Is this a bit easier to understand ?
  13. greybeard360
    greybeard360
    The info I put up there was from another forum for these trucks. Looks like I found bad info!! I looked in one of my old shop manuals but that info wasn't there.
  14. winr
    winr
    from Texas
    Thanks guys
    My 65 F100 twin I beams have 4 degree king pin inclination
    The 53 to 60 100 axles have the same size king pin and king pin boss as my 65
    I will get a protractor and check after I find a 53 to 60 axle
    Ricky.
  15. homey chromey
    homey chromey
    Yeah sorry man but that is what I was referring to also. Forward and back. Never the less I was referring to the castor. I maybe used the wrong verbiage.
