Technical Best exterior gasket material
Discussion in 'The Hokey Ass Message Board' started by txcr13, Jul 17, 2021.
  1. txcr13
    txcr13
    I made some hard to find flat gaskets out of sheet rubber for my wiper bezels and external hood latches. After a few years, they are cracked and gummy around the edges. I thought it was EDPM that I bought, but beginning to wonder. The rubber has not been exposed to harsh chemicals, gasoline, oil etc. Actually the car has been in a garage.
    What type material has worked best for making flay gaskets that weather well for you? Weathering is really my main concern.
    TIA
    Sporty45 likes this.
  2. Sporty45
    Sporty45
    I think old inner tube material would hold up pretty good. I have a bit of it if you want a piece to try. Hell, I'll even spring for the stamp!
    txcr13 and egads like this.
  3. Elcohaulic
    Elcohaulic
    I got a roll of this heavy duty matt that they use on horse stable floors. This makes excellent gasket material. But it is thick..
    loudbang and txcr13 like this.
  4. rockable
    rockable
    Go to a nearby rubber and seal house. You can buy sheets of neoprene in different thiroughshod. A yard will last a long time.. I keep 1/16 & 1/8 on hand all the time and it holds up well.
    Wipe the sheet clean with some thinner or solvent, trace out your pattern on the sheet with a ball point pen. Get in some good light and it will show up kind of reddish. Use a pair of sharp surgical scissors and take your time. You can cut really smooth lines with practice and you can use sand paper to clean up any roughspots.
  5. squirrel
    Mopars used a thin white foam type material starting in the 1960s...I sometimes find this material used as packing material. That would be a good one to try.
    I just installed a new set of door handles on my Chevy II, they came with the thin rubber gaskets. I did not use them, as I don't recall Chevy ever having used a material like that on those parts. Probably for the reasons that you started this thread....they don't work.
    I'd use a paper or plastic material, if I had to use a gasket. Mostly, if there is not something like that available, I use nothing at all.
  6. indyjps
    indyjps
    Rubber roofing, used on flat roofs. It sits in the sun all day without breaking down.
    Excellent to have a partial roll around the shop, find a local roofer and ask for a drop or end of a roll.
    loudbang and little red 50 like this.
  7. 2OLD2FAST
    2OLD2FAST
    from illinois
  8. 2OLD2FAST
    2OLD2FAST
    from illinois
    My 1965 impala had gaskets under the exterior door handles & the locks ,also the trunk lock...I remember one way that you could tell a repaint is if there was paint on the gaskets..
    loudbang and VANDENPLAS like this.
  9. squirrel
    What material were they? It wasn't a soft rubber, was it?
  10. txcr13
    txcr13
    Well, I thought the rubber sheet I cut them from was EDPM material, but the gasket poor performance now has me wondering if it really was. I bought the sheet based on EDPM quality for weathering, but it has been disappointing.
  11. txcr13
    txcr13
    Ugh! I jut threw away a big s**** of it! Tks for the tip.
    indyjps likes this.
  12. 325w
    325w
    GM didn’t use paint gaskets under the door handles. But they did under the doors and trunk lock.
    Probably more of a gasket than paint protection.
  13. squirrel
    I've seen a thin plastic gasket under the locks....I don't know if they're properly reproduced?
  14. 2OLD2FAST
    2OLD2FAST
    from illinois
  15. 64 DODGE 440
    64 DODGE 440
    from so cal
    You could probably use old plastic milk jugs or oil bottles.
    loudbang and squirrel like this.
  16. 2OLD2FAST
    2OLD2FAST
    from illinois
    This doesn't mention what material , but they are available here & numerous other sources. There's a felpro sheet gasket material mentioned often when searching " exterior automotive door handle gaskets". Or "1965 Chevy Impala door handle & lock gaskets".
  17. squirrel
    that's an OER part number, which is what I got, and they're soft rubber, quite a bit thicker than they ought to be.
  18. 2OLD2FAST
    2OLD2FAST
    from illinois
    I remember bicycle inner tube thin but quite a bit stiffer ...
  19. squirrel
    I've seen inner tubes crumble just sitting on a shelf in my shed....
  20. deathrowdave
    deathrowdave
    from NKy
    In my trade , I would get old gas regulator diaphragms . They were thin stuff , rubber cord between the 2 layers . That stuff will last forever and a day .
    txcr13, loudbang and indyjps like this.
  21. 2OLD2FAST
    2OLD2FAST
    from illinois
    I wasn't suggesting using inner tube , just using that material as a reference for thickness & feel , something many could relate to . ..
  22. 1940Willys
    1940Willys
    McMaster Carr has rubber sheet Material
    rockable likes this.
