chevy ll 4 banger ?
Discussion in 'The Hokey Ass Message Board' started by lilbill, Nov 24, 2006.
  1. CNC-Dude
    CNC-Dude
  2. Six Ball
    Six Ball
    from Nevada
    Duggan/ Deppe
    $(KGrHqN,!iEFChVEHCnkBQyh4fh)sw~~60_57.jpg $(KGrHqZ,!n4FCo65Yb6YBQyh5Bi!0!~~60_57.jpg $T2eC16N,!ygE9s7HHqTEBQyh4tNU4g~~60_57.jpg $(KGrHqJ,!q!FCrzcNDbhBQyh5HcGE!~~60_57.jpg $(KGrHqN,!i8FCzKW6T+wBQyh4m8log~~60_57.jpg $T2eC16d,!zcE9s4g3hi,BQyh4zYOiQ~~60_57.jpg $(KGrHqJ,!p4FCL9z(NeRBQyh46jeBg~~60_57.jpg
    Lil'Alb likes this.
  3. WranglerRouser
    WranglerRouser
    Lil'Alb likes this.
  4. gearheadbill
    gearheadbill
    Can someone recommend spark plugs for 181, 10.2CR, ported head etc.. Thanks
    Getting close to firing it up.
  5. 29Coupe
    29Coupe
    Here’s my 1964 153 in my 1929 roadster pickup.
    -Jeremy
  6. chiliman
    chiliman
    from liberty mo
    What trarnsmiion carb and read end is it open drive thanks chili
  7. 29Coupe
    29Coupe
    Yeah it’s all open drive. I’ve got a S-10 5 speed trans. 8” Ford rear. Clifford manifold with a Weber carb.
    Tim likes this.
  8. chiliman
    chiliman
    from liberty mo
    I have a 9” going in with a four link have Clifford intake and header hot coated Rts Ford 26 percent over drive 12 bolt valve cover and side plat
  9. blowby
    blowby
    from Nicasio Ca
    I've been keeping my eyes open for one to pop into this.
    Lil'Alb, rod1, tractorguy and 3 others like this.
  10. chiliman
    chiliman
    from liberty mo
    Nice mine is a 181 Merck crusier
  11. Tim
    Tim
    from KCMO
    @29Coupe got a shot of the drivers side of the engine? Thanks :)
  12. mohr hp
    mohr hp
    from Georgia
    Do you have an Austin body, or?
  13. blowby
    blowby
    from Nicasio Ca
    Got an American Bantam, same basic thing. The ch***is came along and I grabbed it thinking I might use it in the build but now it's just sitting there. Thinking about making a go kart of some sort
    Lil'Alb and Hollywood-East like this.
  14. Six Ball
    Six Ball
    from Nevada
    I just bought a rear sump oil pan just to make sure it would would fit these. It is for an early a 2.5 from a Jeep CJ5,CJ7, CJ8 from '80-'83.
    Tim likes this.
  15. chiliman
    chiliman
    from liberty mo
    Hey guys I have a181mercruser just got rear su mp pan from early nova what oil pump do I use tha ks
  16. Six Ball
    Six Ball
    from Nevada
    I'd try to find the one that goes with the pan. I think the difference is the pickup tube. What I'm trying to figure out is the dipstick.
  17. Tim
    Tim
    from KCMO
    **** I’ll save you some time, that ****ers empty!
    Six Ball likes this.
  18. chiliman
    chiliman
    from liberty mo
    Thanks for info will see if advance auto carries a pickup tub and dip stick
  19. Six Ball
    Six Ball
    from Nevada
    I'm not really sure if there is a problem with the dipstick. It goes in a hole in the block it would be crazy to use two different pans and only have the dipstick work on one. I haven really checked it yet.
    Yeah Tim, maybe a dry sump? :rolleyes:
    OFT and Tim like this.
  20. chiliman
    chiliman
    from liberty mo
    So does any one have areas sump oil pan tube to pickup thanks
  21. chiliman
    chiliman
    from liberty mo
  22. Six Ball
    Six Ball
    from Nevada
    Just the one I'm using. I have another rear sump pan from a Jeep. I think it is from a 151. You might try a pickup tube from a Jeep. The oil pump is the same.
  23. chiliman
    chiliman
    from liberty mo
  24. Six Ball
    Six Ball
    from Nevada
  25. chiliman
    chiliman
    from liberty mo
    Went to advance auto they can get the pump and pick up tube 349 may see if a cheaper one pops up I would think that it would work though
  26. Six Ball
    Six Ball
    from Nevada
    That seems like a lot. I wish there were real wrecking yards. There were also 153s in some DJ mail Jeeps. I don't know what pans they used. I also don't know what other 151s had rear sumps, even some of the cross mount front wheel drives?
  27. Truckedup
    Truckedup
  28. Six Ball
    Six Ball
    from Nevada
    I'll have to look at them again. I got distracted. I've been tripping over them while trying to clean the shop. I'll post some pictures of the two. Yes, one is 153 and one is 151.
  29. Truckedup
    Truckedup
    I fit a rear sump 151pan on a 153….I had to m***age the pan for oil pump clearance and tweak the width slightly. Then sheet metal work the rear main seal pan lip to fit the 151. It all worked out ok…
  30. Six Ball
    Six Ball
    from Nevada
    OK, just tripped over them again but I measured the rear seal area. I just put a board across the gasket surface and measured the deepest part of the rear seal area. The 153 is 1 3/4" and the 151 is 2 1/8". So they are not the same. I think it would easy to make a spacer to fill the void.
