Hot Rods Best 1932 ford radiator for small block chevy
Discussion in 'The Hokey Ass Message Board' started by vintagekart2, Jul 18, 2021.
  1. vintagekart2
    vintagekart2
    What’s the best radiator to use in a 1932 Ford deuce coupe build with small block chevy? I’ve tried 2 aluminum radiators, 1 medium price, one upper price, both fit ****py, too tight at top on one, 1 tight all over and both ****py mounting tabs, both didn’t seem to work well adjusting grill shell to hood. Would use a Walker but they are no longer and can’t find one.
  2. woodiewagon46
    woodiewagon46
    from New York
    I know Walker Radiator has closed their doors, but I have been using a Walker for over 20 years on my Deuce roadster with no problems. Alan Johnson's Rod Shop has purchased all of Walkers inventory, but it's going to take time for them to tool up. You might be able to find a '32 Walker radiator on some vendors shelf somewhere.
  3. krylon32
    krylon32
    from Nebraska
    Always used Walker on dozens of deuce builds, but with the new Johnson's Radiator Works not up and running I would turn to Br***works. I have also used several of their radiators in deuces and they fit good. I currently have a Br***works German silver radiator in my Henry deuce roadster with a Henry shell and it fits really good.
  4. jimmy six
    jimmy six
    One for a BBC…..
  5. Canuck
    Canuck
    Model A with a 425 Buick Nailhead. Used a "US Radiator" with internal trans cooler. Size and shape was a exact match for original Ford rad. Never got around to installing a shroud, used a 17" six blade manual fan. Cooled great and held 180 degrees in slow traffic at 85 degrees out, with or without hood sides, highways were no problem. Side frame was a slightly lighter gauge of metal, but did not appear to give any problem, even on Manitoba roads. I would recommend them as a quality product.
  6. 19Eddy30
    19Eddy30
    from VA
    walker was purchased by Johnson Family down south , Alabama Mississippi ? Cooper /Br*** cools better then Aluminum, most people use a aluminum radiator for the wrong reasons , it's for weight saving,
    They are making copper Rads Same tooling , A friend of mine just received his about a month ago and he has had over 25 1932 fords , He said Radiator is the same quality when walker was making them , you all so have Br***works in Cal & US radiators which is also located in the south
  7. Deuce Lover
    Deuce Lover
    Don't know if they are still in business but I got mine from US Radiators in Los Angeles 25 yrs ago.
  8. MCPO
    MCPO
  9. A Boner
    A Boner
    Too bad you don’t live closer…have a SBC Walker, never used and still in the box!
  10. Dino 64
    Dino 64
    from Virginia
  11. DDDenny
    Too bad Steve Long (Indy) is no longer in business, he made an extremely high quality radiator, I don't know about the best but this was the heaviest radiator I've ever handled.
  12. Johnson’s bought Walkers tooling
    CG&J heat transfer/Brice Thomas bought US Radiator.
    Both in a Gadsden Al.
    I toured the aluminum radiator plant at Brice Thomas on Wednesday. Impressive hand built process.
    Visited Johnson’s Rod Shop the same day. But didn’t get the check out the radiator division.
  13. 325w
    325w
    Seen one from Brice Thomas in a 39 Ford and was a super nice fit. It was aluminum
  14. HOTRODPRIMER
    HOTRODPRIMER
    Hope Johnson's can start shipping soon, I prefer copper/br*** radiators, plus they are traditional!:D HRP
