Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. TA DAD
    TA DAD
    from NC
    Well boy's it is all at a standstill now, I just got out of the Hospital from having my 4th stent placed. For now all I can do is look at the pictures to ! hey but at least I am not dead.
  2. j hansen
    j hansen
  3. guthriesmith
    guthriesmith
    Sounds like you have a lot to be thankful for, but can also understand wanting to get back to work. Praying for a quick recovery so you can get back at it. But, rest is good advice for now. :)
  4. TA DAD
    TA DAD
    from NC
    Thanks J HANSEN , guthriesmith , This thread is my escape seeing what others are doing. I will add I am 62 and started this journey at 38 . I have been stented twice in the widow maker So I am somewhat used to it. Now back to our regular programing !
  5. My machinist called today to tell me my 351W block is sound and he will begin machining. He's going with a .030 overbore. That's the go-ahead for me to buy the cam, roller rockers, timing set, oil pump and sump, and lots of other stuff so that parts will be ready when he begins ***embly. This is a huge step for me, since I began working on this project in 1974. If the budget allows, next step will be to get the transmission rebuilt. I had a health scare a year ago, now recovered, that has convinced me to do this NOW! There's no guarantee that there will be a "later."
  6. HotRod33
    HotRod33
    Mounted the body and the bed today
  7. WB69
    WB69
    from Kansas
    Nothing, sorry to say. But, I did seriously think about it while waiting for a Life Screening Test today. Glad to say however that I'm good to go.
  8. gimpyshotrods
    gimpyshotrods
    I got some jewelery for the Hemi.
    Tossed it on to see how it looks.
  9. RICH B
    RICH B
    Started grinding the welding and sheet metal so it is clean enough for the filler to stick. Have to pick up some cartridge rolls to get into radius around the headlight rings. Even remembered to finish welding the grille supports I added to the splash apron. Started making some sill plates for my friend's '33. Shrinking that .063 aluminum gave my already sore arm a workout. IMG_20210722_152502.jpg IMG_20210722_152418.jpg IMG_20210722_154204.jpg
  10. Sky Six
    Sky Six
    from Arizona
    Wiring is done, wheel bearings are done, complete tune up and service is done, new tires are done...
    nothing left to do except to experiment to see if Hankook tires can go up in smoke, if you get my drift. ;):D
    blowby, LAROKE, j hansen and 3 others like this.
  11. blowby
    blowby
    from Nicasio Ca
    Installed my new '70s Mod Brady Bunch Designer $14 a pair seat covers, after some generous foam and taping underneath. Not sure what the long term plan is but the wife wasn't thrilled with seat spring enemas.
  12. 20210724_192415.jpg Drove it to the ticktown show yesterday to advertise the upholstery shop :eek: 20210724_192514.jpg
  13. sidewayzz69
    sidewayzz69
  14. gimpyshotrods
    gimpyshotrods
    Spent today at the lathe, spinning up all the spacers to get the belts aligned.
    Still waiting on my 321 stainless tight mandrel bends, to finish the headers.
    At least now, with the drive complete, I can move on to placing the rear coil overs, and anti-sway-bar.
    61Cruiser, LAROKE, Blues4U and 7 others like this.
  15. High test 63
    High test 63
    Wow! Blown hemi with quickchange...im having a very pleasant reaction to seeing all that cast aluminum! Lol
  16. gimpyshotrods
    gimpyshotrods
    I am half-wishing that I built the reverse-rotation quickchange out of aluminum instead of magnesium.
    It holds the polish better.
    I am actually quite surprised that I have not been banned from the board for putting the engine in backwards.
  17. chromedRAT
    chromedRAT
    New shocks, finished mirror mounts, put mirrors on the T.
    Lil32 likes this.
  18. TA DAD
    TA DAD
    from NC
    All I can do right now is lite work, so I have been cleaning up some parts and made a couple brackets to repair the oil pump sump. And one nice surprise was the rockers arms are made in the USA ! studebaker build 001.JPG studebaker build 002.JPG studebaker build 005.JPG
    LAROKE, Blues4U, Lil32 and 5 others like this.
  19. LOU WELLS
    LOU WELLS
    from IDAHO
    stanlow69, Hamtown Al, Lil32 and 6 others like this.
  20. Not what I did to my car but I had to clean up after someone else decided to run their car into my building. After heavy drinking he figured it was "drive through" auto supply and machine at 11:30 at night. :mad:
    car through window july 2021 (4).jpg car through window july 2021 (3).jpg car through window july 2021 (5).jpg
    Thanks to Service Master for coming out at 2 am to plug the hole.
    car through window july 2021 (13).jpg car through window july 2021 (15).jpg car through window july 2021 (16).jpg
    nosford, shortypu, charleyw and 8 others like this.
  21. TrailerTrashToo
    TrailerTrashToo
    We need a "HOLEE-CHIT!!!" ****on
  22. Atwater Mike
    Atwater Mike
    Wow, Tim... Hard act to follow! A friend works for Service Master here in town, they are 'Johnny-On-the-Spot!'
    I finished up the sub-ch***is on wife Joey's O-T BMW E46 and installed it...Whew! (to think I used to do that full-time, it's worse than deja vu'!)
    NOW I can 'hot rod'. (continue builds)
    Blues4U likes this.
  23. mgtstumpy
    mgtstumpy
    Time to upgrade from 3.5 to 4.56, replace bearings & seal, inspect locker. This is the last improvement in a long list of upgrades I've undertaken over time. 222067328_339888680959168_4584122012931317723_n.jpg
    Stock Racer, LAROKE, Blues4U and 5 others like this.
  24. High test 63
    High test 63
    IMG_20210724_152217552.jpg IMG_20210724_152200986.jpg i always hated this dopey gap between my cab and pick-up bed . I finally decided to take the time to finish it off better. Looking at all the great builds on The HAMB has me embarr***ed of my heap and i gotta turn it up several notches!
    I got panels cut out and bent up for it. Gotta weld it up now and make some supports/gussets to finish them up.
    LAROKE, simplestone, Blues4U and 8 others like this.
  25. gimpyshotrods
    gimpyshotrods
    The blower belt came in, so I put that on. That's about it.
    Everything else is stuck in the supply chain.
    *Long bolts and spacers are temporary. The real bolts will be here tomorrow.
  26. gimpyshotrods
    gimpyshotrods
    That ain't gonna buff out.
    j hansen and 57 Fargo like this.
  27. Flathead Freddie
    Flathead Freddie
    Hi
    Got the last of Freddie's valve guides out , took off the rear cam cover to see frozen gear say and broke the frozen oil pump . Saw the cam just rusted solid to the lifters . Progress is good
    j hansen likes this.
  28. Wiped it down, cleaned it out, sprayed a little shiny on the tires..... there's a guy coming from WVa today that seems very interested ;) 20210727_102148.jpg
  29. blowby
    blowby
    from Nicasio Ca
    Nice. Do you have a build thread going? Curious the overall plan: street, race, wheelbase, cooling, body?
  30. Blues4U
    Blues4U
    from So Cal
    Lot's of period correct show cars & race cars were built with alternative engine locations. I was wishing there was a build thread so we could see the whole thing instead of bits and pieces. If not here, maybe on another site, with a link to it so those of us who were interested (and I think there are more than a few) could check it out.
    SEAAIRE354 and j hansen like this.
