I am listing this 1929 Model A Sport Coupe, new build with 500 miles since new for John's Hot Rod Shop and Museum, 1-405-396-2055 after 2PM. Coupe is chopped 2.5 inches, all new wood, new tinted gl***, all steel (no fibergl***), mitchell overdrive, Antique engine rebuild with balanced crank, inserted bearings, larger valves, New highest performance cam, lightened flywheel with V8 clutch, Miller high compression aluminum head, FS electronic centrifical distributor, new gears and bearings in transmission, Model T rear spring, all new bearings in rear axel, frame double plated and cross braced, dropped front axel with all bearings and bushings new, 12 volt system with alternator, aluminum radiator with electric fan, 16 inch 1935 ford wire wheels with new tires front and rear, also a pair if 1934 ford 17 inch wire wheels go with car for front, custom auto sound radio, Tack, GPS system, Model A sedan seats with seat adjuster, rear mount 11 gallon fuel tank with electric pump with regulator, Weber 2 barrel carb, Reds headers, gl*** pack muffler. Those of you who know John know he does all the work himself, paint, bodywork, interior. He sends nothing out. Every inch of this A has been messaged, the under side looks as good as the exterior. This car can't be built for $22,000.00. Call John after 2PM at 1-405-396-2055, if he does not answer please leave a message and he will call you back. Thanks, Fred
Well, we thought it was sold but fell through. Back up with a lowered price of $19000.00. Thanks Fred
John has 2 new projects coming in so he wants to lower the price for a quick sale. NEW PRICE is $15,000.00. Thanks Fred
John says he will sell the whole running gear on this Model A for $7000.00. This includes the Antique Engines motor (inserted rod bearings, fully balanced, weber carb, reds headers, over 100 HP and Thomas head, FI distributor, largest new street cam they put in them, bigger valves. etc.) Model A Trans has all new gears, driveshaft and Mitchell overdrive and model A rear end with new brakes and all new bearings, every one. Thanks, Fred
Up one more time! John says he will sell just the motor and trans for $5000.00. This includes the Antiques Engine (100hp plus) motor. Inserted rod bearing and counterbalanced crank, big valves with brand new camshaft (not a regrind) this is the largest street cam they put in their motors. Weber carb and air cleaner, reds headers, Thomas head, FI distributor, lightened flywheel, all new gears in transmission with V8 clutch. In short everything that's under the hood, motor mounts, exhaust, muffler, tailpipe all the way to the back. This coupe cruse's at 70 mph, this is not your Great grandpa's Model A motor. Come and drive the car before you buy the motor and ******. If you have a Model A project, drop this motor and ****** in it and go! John said he would pull the motor and ****** while you wait. PS if you want the re-built steering column and steering box John will put this in the deal. Call John at 1-405-396-2055. Thanks, Fred
