Projects 1940 ford coupe build
Discussion in 'Traditional Hot Rods' started by newredporch, Jan 9, 2019.
  1. 1-SHOT
    1-SHOT
    from Denton
    Enjoy following your build doing a good job of saving the coupe. What brand of rotisserie are you using ? Thanks Frank
  2. newredporch
    newredporch
    from pittsburgh
    Not sure on the brand. Have had it for many years.
  3. 1-SHOT
    1-SHOT
    from Denton
    I have a 40 sedan delivery that I had since high school need to redo it.
    40ragtopdown and newredporch like this.
  4. newredporch
    newredporch
    from pittsburgh
    D9DBF129-D9CB-4A0F-B648-DAE17C8D98A5.jpeg 590A4AF6-0E91-4081-99AE-BD2154E64F2B.jpeg Found the pedal covers at a swap meet. The box looks really old. Also had a friend clean up this old intake for me. Slowly piece by piece it’s coming together.
  5. arkiehotrods
    arkiehotrods
    I have really been enjoying this thread and look forward to seeing more progress! Keep up the great work!
    newredporch likes this.
  6. patman
    patman
    if that 283 had the oem front sump Nova pan in it, you have to swap the pan, oil pump/pickup, and the pump drive shaft to convert it to a generic rear sump style. The front sump Nova pump driveshaft is about 1/2” shorter than the generic one, so it won’t engage properly with the rear sump stuff.
    just fyi…easier to fix now than later…
    MO_JUNK likes this.
  7. newredporch
    newredporch
    from pittsburgh
    Yep, been there did that. Thanks!
    patman likes this.
  8. newredporch
    newredporch
    from pittsburgh
    The hard part of the exhaust is done. Need tailpipes and hangers
    CAAF883C-0FCC-45F9-B6C0-62EEE55F7322.jpeg ED008C09-359B-422D-B021-63D74AA4E466.jpeg 38BA42FE-2AD1-422F-9814-330C7C3E8F00.jpeg A20AB92D-E6BB-4CEE-A446-442F6D121C62.png The hard part of exhaust is done. Need tailpipes and hangers
  9. 1-SHOT
    1-SHOT
    from Denton
    The rest should be a cake walk
  10. newredporch
    newredporch
    from pittsburgh
    I decided to jump on to body work and get some sand blasting done before winter. That led me to addressing the p***engers side rain gutter. My theory is that someone put paint stripper on the roof many years ago and let it run into the gutter which not only caused it to rust off, but it also pitted the roof. I was shocked to find out that Dennis Carpenter wanted $350 4DBF4B2D-71BE-4E4F-B585-6496C7BDDD4F.jpeg 4E556742-E336-439D-B31A-893430022AB5.jpeg 28FE720E-0837-45BB-8034-71C1397E5548.jpeg BE72216C-0B9D-4C23-A38D-222FFF86F4FF.jpeg 9B65EDA1-7A8C-4769-A3F9-0D300E69A88E.jpeg big ones for a set (sold by set only). Grudgingly I ordered a set and luckily forgot to click “confirm”. The next day I cut one off of my 4 door parts car and with a little work on the shrinker/stretcher I was able use the one I had and keep my money. I guess that’s hot rodding.
    LOU WELLS, brEad, Woogeroo and 9 others like this.
  11. 40FORDPU
    40FORDPU
    "Hot Rodding"/recycling synonomous.
  12. joel
    joel
    That's a tough job to replace that rain gutter. Did you slip it in between the roof and the quarter?
  13. newredporch
    newredporch
    from pittsburgh
    using a used part made it interesting. Around the door was straight forward. My 1/4 panel seam was pushed apart with rust making it possible to clean out the seam with a cut off wheel and sand blast back in. I pinched the seam back together and tack welded it from the outside then I notched the used gutter around those welds and drilled holes every few inches above the seam, installed the gutter tightly and plug welded from the inside of the car. I should have taken pictures but I was flying by the seat of my pants and wasn’t sure how it was going to work out.
  14. joel
    joel
    I would have liked to see some pictures, however when you're in the process and hoping for the best outcome, everything else is a distraction. I'd say ..mission accomplished!
  15. Jacksmith
    Jacksmith
    from Aridzona
    Good idea... It's good you replaced the gutter. Aside from being a pain when you get rain, it looks better than when they're shaved.
  16. newredporch
    newredporch
    from pittsburgh
    And the mud work begins 0E5FE8F7-5F80-458D-848C-BC1F93BC070E.jpeg 6EC6C095-A5EF-4D91-B3A8-90FC21C78ACC.jpeg
    The 39 guy, 50flathead, brEad and 8 others like this.
  17. newredporch
    newredporch
    from pittsburgh
    Almost ready to spray the polyester primer from Eastwood. Anybody tried it on a build? 1446E1FD-095F-41E0-80CA-8601C251C1E9.jpeg 2EAF2336-DBC8-4468-9BA8-9CA344F2F8EB.jpeg
  18. joel
    joel
    Should be OK; just use a sealer on top of it.
    40ragtopdown likes this.
  19. newredporch
    newredporch
    from pittsburgh
    The can says it has excellent bonding characteristics over metal. And I agree, a good sealer is important
  20. newredporch
    newredporch
    from pittsburgh
    Because this is going to be a driver and also because I welded in a used floor That wasn’t really that pretty, I decided to use a bed liner coating on the bottom side. This will help preserve the bottom as well as make things look a little more legitimate 83AF57E1-360F-461D-8153-150259D0A4B5.jpeg 6894576A-B173-49A9-AD62-C14A4BD7EA10.jpeg
  21. 40FORDPU
    40FORDPU
    [​IMG]Are you using a remote oil filter?..looks pretty tight there.
    LOU WELLS, kidcampbell71 and joel like this.
  22. newredporch
    newredporch
    from pittsburgh
    The engine is out of a 1966-67 nova. The recessed oil filter area gives me a little more room and with a short filter it all works out. Thanks for checking my work.
    40FORDPU likes this.
  23. newredporch
    newredporch
    from pittsburgh
    7705744D-C19B-4267-B475-59FAA391043F.jpeg 0DA8436E-8706-4A3A-8E73-F92C7C7E616D.jpeg 375C81CC-58B1-436F-9A48-4E996E157B8B.jpeg The underside is finished, the body is finally in sealer and the firewall is painted. I’m going to seam seal the rain gutters and put her back on the ch***is soon.
  24. joel
    joel
    It looks really good.
    hotrodA likes this.
  25. newredporch
    newredporch
    from pittsburgh
    It always feels like a turning point when you take the body off of the rotisserie and put it back on the ch***is. Things seem to fit nicely. I have a new head of steam BEC46EB6-A466-4F95-82FF-FE564F7A41F2.jpeg 7B3AC215-C409-4A44-964C-2353F1F5F085.jpeg B829A41F-0E34-4FA7-8B6B-5752186BECA1.jpeg
  26. newredporch
    newredporch
    from pittsburgh
  27. joel
    joel
    The door alignment looks like it is pretty close. This is the time when I used some shims between the body and frame to get the best door fit. I also painted the body on the frame (my avatar).
    The 39 guy likes this.
  28. 1940rpu
    1940rpu
    The coupe is looking good. Its always a big moment when the body and ch***is are married back together. It suddenly becomes a car again. I have used that Raptor bed-liner under a couple cars and been VERY happy with the results, I'm sure you will be too. It works great inside the fenders as well and prevents 'stars' in the outside paint from rocks impacting the underside. Thanks for keeping the updates coming.
  29. newredporch
    newredporch
    from pittsburgh
    I’m trying to shim things for good results but there seems to be only so much you can do outside of shaving edges or welding on to edges to achieve perfection. I think I’m going with the Henry fit lol.
    brEad and belair like this.
  30. joel
    joel
    Good choice in my opinion. That's what I did. On my car the right side door opening was approx. 1/16 " wider than the left; however the right door was approx. 1/16" narrower than the left. Thanks, Henry.:)
