Projects 33 Doll Build Page
Discussion in 'Traditional Hot Rods' started by 33Doll, Mar 20, 2020.
  1. 33Doll
    33Doll
  2. roll of the dices
    roll of the dices
  3. 33Doll
    33Doll
    Thanks!
    I know yours is flawless.
    My Motive is a little different,
    ( home built in the 60’s Look, But Slightly safer and Better)
    Like if you discovered it in the barn and hadn’t been touched for decades and then you cleaned it up kind of thing. If that makes sense?
    really what it boils down to is I’m not patient enough!!! Lol! But with this build I have learned a lot more patience than I used to have!
    Especially with all that metal work!!!
  4. roll of the dices
    roll of the dices
    It is going to look awesome once it is done.
    I am staying tune to see your progress.
    I can totally relate to learning to have more patience, lol
    Stogy and loudbang like this.
  5. Rand Man
    Rand Man
    Great thread.
  6. 33Doll
    33Doll
    upload_2021-7-23_15-7-18.jpeg upload_2021-7-23_15-7-18.jpeg upload_2021-7-23_15-7-18.jpeg upload_2021-7-23_15-7-18.jpeg upload_2021-7-23_15-7-18.jpeg upload_2021-7-23_15-7-18.jpeg Got the E-Brake All hooked up
    And working! I had to shorten and re-weld the stock handle linkage, and Cut , shorten and re-weld the Lokar Linkage. But its all working great! The only problem is…..
    I’m such a dumb ***!
    I pulled the cable out of the sheath on the driver side before I cut it. But I forgot to pull the cable out of the other sheath and I cut the cable in half!!! IDIOT! my wife had to stop me hitting myself because I was so mad at myself! I think I bruised my face!!
    I was able to re-weld the cable together, but I don’t know how long that’ll last but at least it works for now I can just get a new cable later just pull right out of the sheath!
  7. 33Doll
    33Doll
    Welp! That’s enough for Today! Its
    Few more Pics With the Driveshaft out of the way, so you Can see all my Crazy Linkage Setup! I Perfected What My Pops originally Did. Now the E-Brake Is separate from the Equalizer, and Hydraulic Brakes. LOT better!
    Plumbing is next!!!!
    you see in the Close up where I welded the Cable. Sure it will
    Be fine, until I get another Cable!
    Can’t believe I cut it!!!!
    upload_2021-7-23_17-5-3.jpeg upload_2021-7-23_17-5-3.jpeg upload_2021-7-23_17-5-3.jpeg upload_2021-7-23_17-5-3.jpeg upload_2021-7-23_17-5-3.jpeg
  8. 33Doll
    33Doll
  9. Stogy
    Stogy
    Murphy's never far away...I can relate...****! And a couple more expletives resonating into the ions of air above the garage momentarily been there done that...:oops:
    About beating oneself...Stop!!!!
    Here's a funny story...I was at work in a confined area...I was loosening a sizable nut pulling the wrench towards myself with sizable torque...it was a very low profile nut in height...
    Didn't it slip off and POW fist holding wrench right into my face...real good punch...I remember a big bump coming up near instantly...I shook it off but man I climbed out of that pit looking and feeling a bit ****er punched...:oops:
    Good thing no one saw me they would have pissed themselves laughing...:D
    Sorry about the cable 33...pinch yourself...your human...
    The blue AND the progress looks just dandy...;)
  10. 33Doll
    33Doll
    Got the rear end plumbed!
    upload_2021-7-24_11-57-38.jpeg upload_2021-7-24_11-57-38.jpeg upload_2021-7-24_11-57-38.jpeg upload_2021-7-24_11-57-38.jpeg upload_2021-7-24_11-57-38.jpeg upload_2021-7-24_11-57-38.jpeg upload_2021-7-24_11-57-38.jpeg upload_2021-7-24_11-57-38.jpeg
    Does anybody know which chamber is for the front brakes on a Chevy master cylinder? Is it the one closest to the mounting face?
  11. 33Doll
    33Doll
    One More Fitting at the residual valve, and Rear Brakes are done! ( that’s if the fittings hooked to the right chamber)couple guys said it was a manual brake Drum/Drum that are the same size chambers it doesn’t matter which way….. but the Corvette guys say that the one furthest away from the mount is the front, and the one closest is the rear, which is how it is. So I should be fine????
    upload_2021-7-24_19-8-47.jpeg upload_2021-7-24_19-8-47.jpeg upload_2021-7-24_19-8-47.jpeg upload_2021-7-24_19-8-47.jpeg upload_2021-7-24_19-8-47.jpeg
  12. 33Doll
    33Doll
    Almost done Plumbing!
    Just the cross over to
    F-P***enger
    Then take lines off and polish the Ni-Copp. It will look Br***y!
    anchor it all. Then Bleed the system! EXCITED!
    upload_2021-7-25_17-44-12.jpeg upload_2021-7-25_17-44-12.jpeg upload_2021-7-25_17-44-12.jpeg upload_2021-7-25_17-44-12.jpeg upload_2021-7-25_17-44-12.jpeg upload_2021-7-25_17-44-12.jpeg upload_2021-7-25_17-44-12.jpeg upload_2021-7-25_17-44-12.jpeg upload_2021-7-25_17-44-12.jpeg
  13. Johnboy34
    Johnboy34
    from Seattle,Wa
    Looks good! Getting closer for the body to be back on. What are your hose anchor brackets off of?
  14. 33Doll
    33Doll
    Thanks! I can’t wait to get the body back on!
    I’m trying to do as much as I can on the ch***is with the body off so it’s a lot easier and I don’t have to crawl underneath.
    Those mounting tabs they look familiar to me I can’t remember what they’re off of maybe like a Mustang or a 60s Ford, my dad had them on there before and I just reused them, I didn’t like the weld on ones that I bought from Speedway. I would’ve had to strip some of the paint off the frame and weld them on which is an a big deal but I’m impatient. LOL!
  15. 33Doll
    33Doll
    THE BRAKES ARE DONE! And working Great!
    None of my Flares leaked!!
    Just had to tighten the Banjo tee to seat the copper washers!
    Yaay!!! have a nice E-Brake, Hydraulic dual Rez
    And Residual Valves! A lot safer than before!
    Just have to anchor down the lines, and it’s
    Fuel lines next!!
    (Kinda of proud of myself!)
    upload_2021-7-31_23-13-14.jpeg upload_2021-7-31_23-13-14.jpeg upload_2021-7-31_23-13-14.jpeg upload_2021-7-31_23-13-14.jpeg upload_2021-7-31_23-13-14.jpeg upload_2021-7-31_23-13-14.jpeg upload_2021-7-31_23-13-14.jpeg upload_2021-7-31_23-13-14.jpeg upload_2021-7-31_23-13-14.jpeg upload_2021-7-31_23-13-14.jpeg upload_2021-7-31_23-13-14.jpeg
    Jim Bouchard, brEad, AHotRod and 2 others like this.
  16. dumprat
    dumprat
    from b.c.
    How can you stand not putting the engine and trans in first? It would be killing me...
    Stogy, loudbang and 33Doll like this.
  17. 33Doll
    33Doll
    Patience Gr*** hopper… patience…
    I was sitting in the engine bay to install all the plumbing. Soon as I am done with the fuel lines, I will Temporarily set it in there.
    Want to see header clearance, and height, and see how low the front will sit. Etc.
    Soon….very Soon.
  18. Stogy
    Stogy
    :rolleyes:...I recall such speaking in another episode of many years prior...:p
    Jim Bouchard, brady1929 and loudbang like this.
  19. RodStRace
    RodStRace
    Check the brake switch continuity before body on!
  20. 33Doll
    33Doll
    Oh, I want the motor in!
    Especially since it’s just sitting there on the engine stand!!!
    I have a few things I need to do to it first.
    One is do that trick that Bonnie 34 dude with drilling and tapping the transmission pin that holds the two pins in place.
    Because it always leaks right there.
    Basically he just cut the rod a little short and tapped The hole on each side and put a set screw in there. No more leaks!!
    Then I need to make an adapter to go to the trans mount to keep it from torsional twist.
    My pops just had it so ****** snout just sat there in the hole. More as a cradle instead of actually keeping it from twisting. That explains how one of the motor mounts got broken last time. I have a good idea how to keep it from doing that. Going to utilize the rear bolts on the ****** housing and then make a bolt to that plate. Hard to explain but you’ll see!!
    and I want to take the motor back out before I put the body on because I have to modify the firewall a little bit.
    But in a week or two put the motor in there and roll it outside and take some pictures for you guys!
    upload_2021-8-1_10-33-13.jpeg upload_2021-8-1_10-33-13.jpeg upload_2021-8-1_10-33-13.jpeg upload_2021-8-1_10-33-13.jpeg upload_2021-8-1_10-33-13.jpeg upload_2021-8-1_10-33-13.jpeg upload_2021-8-1_10-33-13.jpeg upload_2021-8-1_10-33-13.jpeg upload_2021-8-1_10-33-13.jpeg
  21. 33Doll
    33Doll
    I was thinking about that, use a battery and my tester light with an alligator clip and then push the brake? Right?
    loudbang and RodStRace like this.
  22. RodStRace
    RodStRace
    That will work, or if you have a multimeter, just spin it to ohms and connect the meter across the terminals. Brake off = open, infinite resistance. Brake on = closed, zero resistance.
    You can see how much pressure closes the switch too. Those had a tendency to leak after a short time, so really lean on the pedal when checking for leaks. Brake lights are important in today's traffic.
    loudbang, Jim Bouchard, brEad and 2 others like this.
  23. 33Doll
    33Doll
    1- is no pressure
    2- 000 is medium with hand
    3- is about an inch of movement
    upload_2021-8-1_12-40-14.jpeg upload_2021-8-1_12-40-14.jpeg upload_2021-8-1_12-40-14.jpeg
    brEad, loudbang, Jim Bouchard and 2 others like this.
  24. 33Doll
    33Doll
    Kicking ****!!
    Made my own modified sending unit to match the old Modified one my Pops Did.
    Except I hardlined it, and as much of the lines I could! Put the fuel pump and filter in an easy to get to place an easy to replace short hoses which is marine grade by the way!!!
    Loving the one sided sticky Body cushion!
    Need to get some more for the crossmember!
    Put a connector on the end of the fuel line so I can run a short one to a bulk head on the fire wall once the body is on Permanent, then just a short hose to the carburetor!
    upload_2021-8-6_17-36-45.jpeg upload_2021-8-6_17-36-45.jpeg upload_2021-8-6_17-36-45.jpeg upload_2021-8-6_17-36-45.jpeg upload_2021-8-6_17-36-45.jpeg upload_2021-8-6_17-36-45.jpeg upload_2021-8-6_17-36-45.jpeg upload_2021-8-6_17-36-45.jpeg upload_2021-8-6_17-36-45.jpeg upload_2021-8-6_17-36-45.jpeg upload_2021-8-6_17-36-45.jpeg upload_2021-8-6_17-36-45.jpeg upload_2021-8-6_17-36-45.jpeg upload_2021-8-6_17-36-45.jpeg
    kidcampbell71, dumprat, brEad and 4 others like this.
  25. 33Doll
    33Doll
    Well my speedway shocks work on the rear the front I'm gonna have to use the original small ones for now the bodies too fat on the speedway even if I modified the bracket and everything it's going to hit the The hairpin.
    I'm just gonna clean up and paint the front ones for now silver and worry about it once the engine and everything is on it.
    At least the *** end looks good!
    Oh, and for the guys that were wondering about the clearance for the shocks here’s some pics show you how it worked out!
    upload_2021-8-7_10-48-37.jpeg upload_2021-8-7_10-48-37.jpeg upload_2021-8-7_10-48-37.jpeg upload_2021-8-7_10-48-37.jpeg upload_2021-8-7_10-48-37.jpeg upload_2021-8-7_10-48-37.jpeg
  26. brEad
    brEad
    loudbang, Stogy, 33Doll and 1 other person like this.
  27. 33Doll
    33Doll
  28. 33Doll
    33Doll
  29. Jim Bouchard
    Jim Bouchard
    OMG!!! Exciting times at you place!!!
    I love this!!! It looks soooooo good.
    Your hard work is really coming together and looking great!!! I’d never get any sleep tonight, every ten minutes sneaking off into the garage to see it one more time!
    loudbang, 33Doll and Stogy like this.
  30. loudbang
    Pops would be proud of her. :)
