Projects And So It Begins
Discussion in 'Traditional Hot Rods' started by Piewagn, Jul 14, 2019.
  1. Piewagn
    Piewagn
    And here it is in action! Minor tweaks and tighten the jam nuts.....They said I couldn't do it!!
  2. Big mike 1968
    Big mike 1968
    Thank you sir, and I am thankful because I feel like I have a bunch of new friends and we are all taking a hot rod correspondence course.
    loudbang and Piewagn like this.
  3. Piewagn
    Piewagn
    The HRCC......I like it! :D:D
  4. Nice job on the linkage, but it looks like larger diameter clevis pins would take out a lot of play. JMHO, YMMV
  5. loudbang
    It's not just shift linkage it's also an "anti-theft" device. Think about how many of us left that has ever used a column shifter LOL.
  6. Piewagn
    Piewagn
    I actually had to make the diameter smaller to fit the factory replacement bushings. What I need is longer pins so I can get washers on the back side. The clevis was actually too narrow to fit so I cut one side off. I'm going to make longer pins and weld the other half of the clevis back on at the proper width and use more girthy cotter pins. But, concept proven....I knew I was gonna hafta tweak it. Appreciate the input!
    Big mike 1968 and loudbang like this.
  7. Piewagn
    Piewagn
    My boss actually became more confused as I tried to explain it to him.....it was entertain seeing his expressions while he was trying to gather it all in.....:D:D
  8. Piewagn
    Piewagn
    Seat frame done! I’m gonna stain it to match the floors.... Hope everyone had a relaxing Saturday!
    FF92D870-0930-4C1E-ACA3-472C0774CBC9.jpeg A650F446-BB4A-4C2A-AF96-19FB65B66C58.jpeg CA0FE5FB-8759-4CCD-B66D-D4C3503D3DAF.jpeg 8ADC497E-F9F9-48B5-891E-18CB2FEEE81C.jpeg 94E7071F-2AEA-46C4-8BF8-F3B80E943EB7.jpeg 00809D62-6B73-4313-A5C2-A16001A91F9F.jpeg
  9. Big mike 1968
    Big mike 1968
    Nicholas Coe, Piewagn and loudbang like this.
  10. Piewagn
    Piewagn
    Thanks Mike! I just keep checking stuff off the list!
    Nicholas Coe and loudbang like this.
  11. Piewagn
    Piewagn
    Frame stained and ready to go in....but I’m finishing some things up before I put the floor in for the last time.
    I also dodged a major bullet! Until I get the filter I want, I wanted to block off the outlet port only to find it was damaged and I couldn’t screw in the flared block off fitting that I made....so it had to come out. Wasted the entire evening trying to remove this *****....with visions of it breaking off in the block... Perseverance got it.....whew!
    E3E7E1BF-80DA-45A0-8EDB-14A86BA6AEF2.jpeg A5E32ADD-36D2-4DD1-B29B-017987D642E9.jpeg E2505BCB-736B-42B8-9C90-4A7F511AE350.jpeg
  12. Cliff Ramsdell
    Cliff Ramsdell
    The plate reflector is great. I can see mine as clear as day when swinging into the garage at times.
    Cliff Ramsdell
    Tim, sko_ford, Nicholas Coe and 2 others like this.
  13. Piewagn
    Piewagn
    I’m kinda fond of the reflector too....some guys don’t like it, but I think I’m gonna keep it! Thanks Cliff!
  14. Big mike 1968
    Big mike 1968
    Seat looks great and good save on the br*** fitting. That could have gotten real fun if it had broken in that position
    Nicholas Coe, loudbang and Piewagn like this.
  15. Piewagn
    Piewagn
    The nightmare scenario was playing out in my head! I was imagining having to remove the engine after that thing broke off in the block! Then it moved ever so slightly.....then came the back and forth and more WD-40....and I gradually walked it out.....whew!
  16. Big mike 1968
    Big mike 1968
    yes Sir, I've spent many nervous hours fixing those type of problems for me and my fellow coworkers. That is a bad position to work from.
  17. Piewagn
    Piewagn
    Took a couple days vacation to spend with the coupe....Electrical progress ....I’m hoping to at least pop it of and make a little noise by the end of tomorrow.... B2AE3629-F99D-4D4E-B5DA-B3BF752A1133.jpeg 540CF83E-3EF2-4275-A287-5A8C52C83608.jpeg 33964E10-AE0A-4829-AAFA-90FD714DBCBD.jpeg 6EF02D78-46BA-4F61-BA23-32346CBC513C.jpeg
  18. loudbang
    Big mike 1968 and Piewagn like this.
  19. Piewagn
    Piewagn
    Gotta be prepared LB! Making sure I had what I needed before I started hss made things so much easier!
  20. Big mike 1968
    Big mike 1968
    Your looking pretty tidy there sir. Coming together nicely.
  21. Piewagn
    Piewagn
    Thanks Mike! I'm not a big fan of chaotic wiring.....I'm even using a sharpie to add tracers. I'm do***enting it in my notebook, because I'll NEVER remember all this stuff!!
  22. Piewagn
    Piewagn
    Well......here ya go....
  23. loudbang
  24. Piewagn
    Piewagn
    All you guys are the greatest! Thanks for hangin’ in there with me!
  25. brEad
    brEad
    Wiring looks great! Awesome to hear it firing off!
    Nicholas Coe and Piewagn like this.
  26. Tim
    Tim
    from KCMO
    Oh that’s the best!
  27. Piewagn
    Piewagn
    You guys are the best! You've hung with me throughout and your motivation is greatly appreciated!!
  28. Big mike 1968
    Big mike 1968
    Listen to that... Awesome job Sir! Now you've motivated me to get back out in the heat.
