Technical THE ONE PIECE THAT ELUDES YOU
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Jul 25, 2021.
  1. Chainsaw chipper
    Chainsaw chipper
    from Illinois
    I have not been able to locate a good or restorable or any for that matter pair of Fulton (feathers)1936 ford hood trim at the front that makes the grill appear to continue into the top of the hood.I ve seen them on others cars ,ran wanted adds but so far nothing.
    HOTRODPRIMER likes this.
  2. Taboo56Chevy
    Taboo56Chevy
    A primary chevy wcfb for a 57 Corvette dual quad setup that does not cost an arm and a leg. Scored a intake and secondary carb a couple years ago, but missing the primary. Cannot find a suitable carb to put the setup together to put in my 33 pickup.
  3. alanp561
    alanp561
    Back when I was dirt tracking and was much younger and dumber, that was about the first thing that got thrown in the s**** metal pile. When I was looking for one for for my 55 Sedan Delivery, I found out just exactly how much money I'd thrown away over the years. Good luck with your search and if I find one, I'll snag it for you.
    chryslerfan55 and HOTRODPRIMER like this.
  4. LOU WELLS
    LOU WELLS
    from IDAHO
    The 1940/41 Ford Sedan Delivery Spare Tire Retaining Shoe Took 51 Years To Own... 41%20ford%20panel%20388315%20032_zpszxyuhayf.jpg
  5. Is the primary different than a single WCFB?
  6. Taboo56Chevy
    Taboo56Chevy
    technically yes they are different, but you can make a single 4 carb work with the duals, I am being a little picky to have at least the same year carb to go with the secondary carb. Big thing is that its a Chevy carb, I bought a wcfb off a desoto and yeah not the same at all.
  7. How close is this one
  8. Taboo56Chevy
    Taboo56Chevy
    thats a later carb, the fuel inlet is larger on the later carbs with the fitting screwed in,
    this is the correct fuel inlet for a 57
  9. Ok.
    i was looking for a wcfb or 4 jet for an early intake I had and that carb popped up.
  10. hemihotrod66
    hemihotrod66
    Years ago when I was restoring a 34 Ford I never found the hot air factory heater for it...
  11. Taboo56Chevy
    Taboo56Chevy
    yeah the inlets changed around 59/60 on Chevy carbs I believe
  12. Rickybop
    Rickybop
    1920s/early 1930s
    Chrysler/Dodge/Plymouth
    roadster body.
    Oh... the elusive part.
    ... that I can afford.
    That narrows it down.
  13. 36cab
    36cab
    I bought my 1948 Austin A40 Dorset back in 1977. I started working on it but put it in storage after a couple of years. About 4 years ago I took it out of storage and started working on it again. In 1978 I had taken the driver's chrome door trim off as I was planning on sanding the door and primer it. That door trim has been missing since 1978. The Dorset is a 2-door and much rarer than a Devon 4-door and I have been looking for a replacement door trim for 42 years with no luck. Last summer I was looking for something in my dad's garage and I found the missing door trim under a pile of unrelated parts on a shelf!
  14. jetnow1
    jetnow1
    from CT
    my youthful energy level!
  15. buzz4041
    buzz4041
    from Texas
    A 427SOHC for a deuce build
  16. jll34
    jll34
    from USA
    Heater delete plate for 57 Ford Custom dash.
  17. cfmvw
    cfmvw
    Any part that I happen to need.
    milwscruffy, vtx1800 and HOTRODPRIMER like this.
  18. topher5150
    topher5150
    I bought this cool piece of1942 Ford trunk bezel trim for my 47, but apparently, there is a size and shape difference between the standard trunk lever bezel and the one that fits this trim.
  19. HOTRODPRIMER
    HOTRODPRIMER
    Have you ever checked these guy's out?, I know it's a reproduction but hard to bet the price and have one that is cast from the original piece. HRP
    https://www.redvenomrepros.com/ford
    1957 FAIRLANE, CUSTOM, COURIER and RANCHERO RADIO DELETE PLATE = $40.00
    Cast from an extremely rare original factory part.
  20. 1971BB427
    1971BB427
    from Oregon
    No problem finding the elusive parts I'd love to have for a couple builds. The problem is coughing up the money needed to pay for them!
  21. A set of mickey thompson super scavanger headers. They were orange with a long square collector. I need them for a big block chevy for a serious day two build.
  22. Everyone wants to buy reasonable, but do you sell the unattainable parts you have reasonable ?
  23. Turbo26T
    Turbo26T
    A Fordomatic shift column with shift detent thats not worn completely out... ..I've bought five and not one of them is useable..
  24. Budget36
    Budget36
    I think most of us are looking to be in the right place at the right time. But to answer your question, I never knew I had an unattainable part until after I sold it or gave it away. Lol.
  25. The little clips that holds the rubber that shields the rear license plate light on a 53 Mainline. Have two, need 5.
  26. rob-redm
    rob-redm
    Fulton Feathers for my 36 Ford hood... two years and striking out so far
  27. I would give up both kidneys and go on dialysis to get my mickey thompson headers.
    57 Fargo and Speed Gems like this.
  28. HOTRODPRIMER
    HOTRODPRIMER
    Man, don't say things like that even in jest, I've lost several friends on dialysis in the last few years. HRP
    chryslerfan55, WalkerMD and Papas32 like this.
  29. Guy Patterson
    Guy Patterson
    I agree with HRP just got a call from my Dr that didn't make my day or year
  30. jll34
    jll34
    from USA
    Thanks, Hrp for response. I have seen that piece but not sure how to make it blend in with the rest of original pieces
