Projects T&A Flathead Builds a '48 RagTop
Discussion in 'Traditional Customs' started by T&A Flathead, Aug 24, 2015.
  1. T&A Flathead
    T&A Flathead
    I didn’t like the way this turned out. It bothered me ever since I posted the above photos, so I cut some of it out and made a gutter. Not done yet but it’s tacked in place. Also have the drivers side metal fab 1/2 done.
    33B7BE49-A276-426B-AF05-2C63BAFAD591.jpeg 9380C502-EC75-46B4-9BC0-9111AE5C383A.jpeg
    Once I get the gutters done, I’ll trim and smooth the radius on the deck lid.
    Tim, kidcampbell71 and Dick Stevens like this.
  2. Dick Stevens
    Dick Stevens
    That's much better, I wasn't liking it the first way at all!
    Uribe and T&A Flathead like this.
  3. T&A Flathead
    T&A Flathead
    I absolutely hated it after I saw the picture, I don’t know what I was thinking. That’s what I like about metal work, cut it out if you don’t like it and start over.
    Tim, lurker mick and Dick Stevens like this.
  4. T&A Flathead
    T&A Flathead
    I got the drivers side gutter tacked in. Final weld and finish work remains on both sides. So glad I decided to redo what I did a few days ago. Thanks for not being too critical on me on my first attempt , but I can admit my own mistakes.
    86DA48BF-836F-4382-83EF-4009D5993D27.jpeg 89FA8565-F718-4949-A79E-E986B253607F.jpeg B198560E-BAF3-40C1-A567-EB5EEF6B3C5A.jpeg 8B629CFB-4CA4-495B-9525-B689DC01E1A8.jpeg
    now to fine tune and match the radius
  5. hotrod1948
    hotrod1948
    from Milton, WI
    Looking very good. Like the second fix much better. Keep going!
    T&A Flathead likes this.
  6. Kudos for your courage, man. Not many of us would have attempted the "learning as I go"
    route! Coming along nicely.
  7. T&A Flathead
    T&A Flathead
    Worked on finessing the radiused edges of the trunk lid. I used 1/8” rod to make a smooth radius in all 4 corners. Looks much better.
    B6A5ECF3-F126-459C-946F-5BA03C065B62.jpeg 13FC14EA-B23A-4977-AD29-E0F3E1A0EDC4.jpeg 9D8EEF5A-F7CF-427F-8847-36D88D1A113B.jpeg 8E842AD7-5D6B-41F3-BE99-84618CBC433D.jpeg
    Also filled the trunk handle holes. I think it is ready for blasting, rear fenders are too.
    Tim, kidcampbell71, 36 ROKIT and 2 others like this.
  8. T&A Flathead
    T&A Flathead
    Started messing around with the headlights.
    Just getting ideas.
    B3504E85-1FDD-4D8D-B612-D1A0427347B6.jpeg C810C9A6-D8F4-4EFC-8798-DB45C1FFFE19.jpeg 65C39E8C-FDBB-4CFF-9136-C1FA6DD0A360.jpeg
    Squablow, Tim, kidcampbell71 and 4 others like this.
  9. Fortunateson
    Fortunateson
  10. Please use the original grill with the top chrome bar removed and filled, the plymouth grill looks ugly and modern. And 52 Ford headlight rims for frenching.
  11. T&A Flathead
    T&A Flathead
    I’m not using the Plymouth grille anymore. Decided that was not the way I wanted to go a while ago. I fabbed up a modified original grille bar that I may go with using other crossbars. I may mold in (or radius) the exchange between the fender/fender extension and the grill bar so it doesn’t look like a bolt on grille.
    after I French the headlights, I will take another look at the grille. Using 52 ford style Headlight rings to French the headlights still requires a lot of metal work to allow the flow from the fender to the frenched ring, otherwise it looks like a nipple.
    Thanks for the input, Always open to suggestions and ideas.
    TrailerTrashToo likes this.
  12. T&A Flathead
    T&A Flathead
    Here is a photoshop rendering of the grille if I stay on the path that I am on. The headlight photoshop is not very good since all I did was color it in.
    Also, I am leaning towards smoothing the transition to the grille surround.
    louisb and kidcampbell71 like this.
  13. T&A Flathead
    T&A Flathead
    Headlights recessed. Tacked in place. A lot of work to do to flow the fender into the ring.
    663B8703-C3C9-4D4D-AB31-5EF22DF74D7F.jpeg E9237A97-0238-4A9E-97E0-6417ECAF0871.jpeg
  14. T&A Flathead
    T&A Flathead
    I am playing around with a grille change, this time a ‘49 Cadillac grille. Barris put one in a ‘48 Merc
    Early mock up pic.
    537B7658-28B0-483C-AFEF-5CA2DAC29663.jpeg B7945C74-72D7-4562-B019-E94CFD39F0B3.jpeg 4987E10C-44FC-4E05-AF46-90C8A225442E.jpeg
    If I decide to use this grille, I’ll detail all the modifications I made to the grille. It’s narrowed 4.5” and I recessed the lower horizontal grille bar 1.5”so it doesn’t protrude past the center bar.
    To make the grille look like is belongs in the car I want it to fit right with the fender extensions and hood without it looking like it has a fat upper lip. I also shortened and re-radiused the nose of the hood. A lot of work left to do, but I am liking the look of the Cadillac grille.
    0C328E58-BF38-448F-B5D8-1AC569CAF258.jpeg D9599191-85E6-408E-951A-2CFBBB66FE5C.jpeg 15F7B616-892D-49F1-A01A-C1905D2838C5.jpeg DCE9D1E3-90F8-4046-907B-E83CA97AF54F.jpeg
    Squablow, Tim, lodaddyo and 11 others like this.
  15. Outback
    Outback
    from NE Vic
    Looking good!
  16. Imho, I've seen a lot of custom grilles on the 46-48 Fords and it's hard to beat Henry's original work. The Olds option does have a certain eye appeal though.
    I've been following your build with a lot of interest.
  17. patterg2003
    patterg2003
    Nice work on the lights. Not a fan of the frenched headlights that stick a mile out past the fender. They look wrong no matter how well done.
  18. T&A Flathead
    T&A Flathead
    Thanks and agreed. The lights aren’t done yet. I have pieces made to make the fender flow into the French light ring better.
  19. 47 ford
    47 ford
    you cant go wrong with the Caddy grille, but your first grill was certainly Kool
    Outback likes this.
  20. T&A Flathead
    T&A Flathead
    It’s been a while since I had any shop time, but I got some in today. Still working on the hood and latch but made some good progress.
    375C3558-26FF-4706-B757-BE711A93B325.jpeg 877508A7-64BB-411E-A274-3641F725D526.jpeg 68F57003-817D-4B63-9C5E-AABF243C16F0.jpeg D8AF25E1-2D82-4255-BEAB-60E4E65DFC15.jpeg
  21. louisb
    louisb
    What about the center section of that grill in the ford outer section?
  22. James D
    James D
    Love the Caddy grille. Great to lose that odd surround that the Ford had originally.
  23. hotrod1948
    hotrod1948
    from Milton, WI
  24. T&A Flathead
    T&A Flathead
    that is an interesting idea. Will have to think on that a bit.
  25. T&A Flathead
    T&A Flathead
    Thanks @hotrod1948 and @James D , progress is slow but at least it’s progress. Building hotrods is faster than building customs.
  26. T&A Flathead
    T&A Flathead
    Spent a couple of minutes at the shop on my way home from work. Did a little fitting and trimming in the grille. I have a plan, I think it’s working. A lot more to go, but the grill is coming along.
    D946E507-823C-45AA-92EA-B8064467E39C.jpeg FDD7ECC7-10F5-4926-A1D9-F31C884703A0.jpeg
  27. louisb
    louisb
    That is looking on target. The only thing is the ends of the center bar. Wonder if you could make some glass spear tip shaped lights to use as running lights.
  28. T&A Flathead
    T&A Flathead
    Was thinking about the same thing. I’m saving those for last. My idea to explore is using a ‘49 ford park light.
    Squablow, Uribe, louisb and 1 other person like this.
  29. A Boner
    A Boner
    Inspirational pic...keep up the great work, Tim!
    Squablow, Tim, T&A Flathead and 2 others like this.
  30. T&A Flathead
    T&A Flathead
    A little work on smoothing the transition to the frenched headlight rings. It flows much better.
    68CDB03D-20A5-4621-9BE9-6D6060A611CC.jpeg 302C3C88-ADB7-4F21-9B8C-C2DE0806D0D2.jpeg CFC0CCA9-CCED-43B5-A565-46332881B05B.jpeg 98AD567B-1679-41FB-9267-CF1F6670292D.jpeg B58ABE54-1284-4E20-B3A2-A29903AF743E.jpeg 47C4B336-780B-4D84-A35F-16BB40B174C2.jpeg
    I’ll work them a little more and will lead them later.
    Back to work on the grille.
