Projects Not Another 41 Pickup Project!! (Update: 12/06)
Discussion in 'The Hokey Ass Message Board' started by hotrodA, Aug 7, 2020.
  1. hotrodA
    hotrodA
    Got the front wheels and rear backing plates back, freshly blasted and epoxy primed.
    Traded some NOS Mallory pieces to Mike B for the Y-Block in his 32 coupe for getting this stuff done so I didn’t have to screw with it. Win-Win.
    Mike also milled off a spot on the valley cover for the addition of an oil filler. I layed out the mounting holes, drilled and tapped for 6-32 screws and cut the fill hole without screwing up!! WHEW!!
    I had saved this mil-spec. cap for years and finally put it to good use!
    It will tuck under and clears the intake runner and water neck.
  2. TomT
    TomT
    Nice!
  3. loudbang
    Cap is an inspired touch :)
    brady1929 and TomT like this.
  4. hotrodA
    hotrodA
    Thanks!
    A solution to a problem: how ya gonna put earl in this thing?
    Stock tin cover had a big *** tube and breather. FUGLY.
    HHH has a finned cover with a fill plug, but I’m a tight ***.:rolleyes: And already had this one.
    Bandit Billy put a cool (but rare) Donovan fill elbow on his valve cover. Hero.
    Bandit Billy, loudbang and TomT like this.
  5. Bandit Billy
    Bandit Billy
    Love the oil filler! Looks totally at home on the valley cover. The leash is cool too.
    hotrodA and loudbang like this.
  6. hotrodA
    hotrodA
    And you thought I had thrown in the towel! Or thrown in jail!
    Nope.
    We took an 5700 mile "Last Hurrah" driving trip out West. Grandson is in USAF at Malmstrom AFB, Great Falls, MT.
    Went to 5 National Parks in SD, WY, and MT. Absolutely stunning scenery!
    Got home to no water and a fence falling down. It's never ending!
    I had just about forgotten where I left off on the pile-o-parts pickup.
    Oil pan was next up on the engine, but I was worried about sufficient break-in lube on the cam. You just can't call Summit and get a new cam for a big D..
    Necessity being the mother of invention, I used a narrow artist's brush with a "custom machined" brake line handle extension. Piece of cake to reach the lobes from the bottom with the journal at BDC. A couple of rotations and everything is slathered with the Melling lube.
    Peace of mind, if nothing else.
    Also got the rough cast valley cover fins sanded down and polished some.
    Next the pan.
    Hope that these are the "Best".
    Stay tooned!
  7. hotrodA
    hotrodA
    Slow day today.
    Started on the pan after the cam lube job. Decided on studs and nuts instead of stock bolts.
    Finished with the oil filler after a little more polish. Ready to bolt on when I upright the engine.
  8. Bandit Billy
    Bandit Billy
    I hit the ****on but I had to comment as well, I love that valley cover.
    Big mike 1968, hotrodA and loudbang like this.
  9. hotrodA
    hotrodA
    Thanks, BB!
  10. hotrodA
    hotrodA
    Slow progress. Wife has had vertigo for a week, so no Nats, and not much outside time.
    I did manage to bend up a one piece front brake line while I had room with the engine out.
    One to go, past the box to the m/cyl.
    Also got the pan cinched down for good.
    Time to roll her over!:D
    (Not that, you pervs!):eek::rolleyes:
  11. hotrodA
    hotrodA
    Couple more pieces going on for the last time (hopefully!)
  12. Bandit Billy
    Bandit Billy
    Coming along nicely! Keep up the good work
  13. Roothawg
    Roothawg
    Yep, screw patina.
    loudbang and Big mike 1968 like this.
  14. hotrodA
    hotrodA
    Not much to report after dealing with two shop window sill replacements, a wife with vertigo for a month and me having cataract surgery! Enough already.
    But a few things got done to the pile-o-parts pickup in spite of life’s toe stubbers.
    Got the HH modified harmonic balancer on for the third (!) and final time, along with their bottom pulleys. Also took @dave g in Gansevoort’s advice and sent the water pump off to Howard Stewart for their rebuild. Dial indicated TDC and set the timing mark and glued the tape on.
    Found out that the Mallory flat top I had was the wrong rotation, but after checking in some other Mallory stash, found the one with the correct part number and rotation. The first one was for a BB wedge motor, but fit perfectly.
    Quite the difference in height also.
    The correct one also has the vacuum advance/retard setup, so that will be a plus.
    I also stole @BanditBilly’s idea and moved the HH bottom mount alternator bracket to the top, but
    since it’s for a GM, and I wanted to use this early finned Mopar unit, it was fork in the road time.
    Do I go with the GM or fab a bracket for the Mopar? It’s been totally rebuilt and bumped to 90A.
    We shall see.
    Maybe a little more progress next month.
    brEad, alfin32, Hotrodmyk and 8 others like this.
  15. Bandit Billy
    Bandit Billy
    I prefer the look of the mopar alt too!
    Sorry about the wife's vertigo. I lost the hearing in my left ear suddenly years ago and in return I was blessed with vertigo that I had to deal with for a long time. I still get bouts of it, bad enough I had to sell my Harley. I hope your wife's p***es., no fun.
    kidcampbell71 and loudbang like this.
  16. hotrodA
    hotrodA
    Thanks, BB.
    She’s out of it now. Finally, a friend recommended physical therapy for it, and sure enough there is a series of exercises they put you through. The first day after PT she had serious nausea, second day almost no vertigo!
    Miracle! Who knew?
  17. Bandit Billy
    Bandit Billy
    Yep, build her a balance board out of a 24"X 24" plywood and a ball in the center so it pivots on all axis. She should only do this in a door way, hanging on at first and less as she masters it. Then with eyes closed. I learned that from a book Michael Jordan co-wrote about balance. It can be learned, or re-learned and even made better than before. Jordan had perfect balance but that wasn't enough for him, he wanted superhuman balance. He achieved it.
    Build on brother! We got trucks to finish!
    Hamtown Al, Algoma56 and loudbang like this.
  18. hotrodA
    hotrodA
    Looks like the alternator's penthouse, or ba*****t, home will have to wait until the Desoto is back in the frame. Mocked up as intended by HH, and it looks like it won't clear the stock 40 crossmember.
    I thought I could adapt the Mopar piece to the HH bracket but it's a larger diameter.
    We shall see.
  19. hotrodA
    hotrodA
    Wow!! Talk about GREAT SERVICE! (And pitiful service!)
    Stewart Components received my Howard Stewart water pump on Monday.
    On Tuesday Meghan called and said it was totally rebuilt, Stage 3, and shipped back! For $92 total!:D
    BUT it was delivered Friday by FedEx Ground to somebody who lives 3 miles (!) away, even with MY address on the label! WTF?:mad:
    The folks who live there were kind enough to drop it off today instead of returning it to FedEx.:D
    Just a small town courtesy. Thank you!
    So KUDOS and THANK YOU! to Stewart Components (Jeff, Meghan, Kevin) for a great job!
    And to @Dave G in Gansevoort for the tip!
    And a YOU ****! to FedEx Ground for complete inep***ude, including the inability to read.
    Oh wait, they did find Rogersville, small as it is.
    Thank God they didn’t get it back.:rolleyes:o_O
  20. hotrodA
    hotrodA
    After burning limbs and trash all day, I was whipped, and went out to the shop for a breather.
    Got the pump mocked up (again) because the new fan hub was pressed on way too far, so I got that pulled out to line up the pulley sheaves.
    HHH pulley comes 5/8”, so I had to bore it out to 3/4”.
    Easy enough to do, thanks to the antique Craftsman lathe.
    If I can find some pump gaskets (not included):rolleyes:, I’ll put it on for good tomorrow.
    Another piece to the puzzle.
  21. hotrodA
    hotrodA
    Well.......no progress. For several reasons.
    Shut down, cleaned up the 40, and went to Shades of the Past run in Pigeon Forge for four days
    Got home and had my second cataract surgery.
    And now my wife’s brother died suddenly yesterday from a heart attack.
    Rest In Peace, Richard “Bones” Keough, you were a good guy.
    Be going to a funeral, I’m sure.
    Hopefully back at it in a week or so.
    Stay tooned!
  22. Sorry to hear of your loss.
    Car will be there, when you're ready.
    loudbang, hotrodA and Hamtown Al like this.
  23. Grandadeo
    Grandadeo
    Sorry to hear Bill. We'll be up for the F100 meet in Sevierville next Thursday and Friday but sounds like you've got a lot on your plate.
    Lee
  24. hotrodA
    hotrodA
    Yeah, we will probably be at the funeral. Could be Nashville or College Station, TX where he lived.
    Sorry to miss you!
  25. Grandadeo
    Grandadeo
    Family First Bill.
  26. Bandit Billy
    Bandit Billy
    Sorry for your families loss sir. There seems to be a lot of that sort of thing going around. Take care.
  27. hotrodA
    hotrodA
    Thanks, guys.
    Looks like we’re going to have an old fashioned Irish wake/celebration of life in Nashville, so no long trip to Texas.
    Grandadeo, loudbang and Bandit Billy like this.
  28. hotrodA
    hotrodA
    Well, we got back from a long, tiring weekend and have been having some decompression time with the wife before I can get back at it.
    I've found out, unfortunately, that as you get older it takes a whole lot longer than it used to to recover from hard physical work, long trips and emotionally draining events.
    All I've gotten done is run some more brake line and found out that it’s virtually impossible to get to the master cylinder with the cab on. Those last bits may have to wait.
    I did manage to change out the stock 350 trans pan for this shiney ribbed aluminum number. At least the wayward chicken, possum or squirrel can check his appearance one last time.
    Got other STUFF to do this weekend so I'll see ya when I can.
  29. brEad
    brEad
    Welcome back!
  30. hotrodA
    hotrodA
    Thanks!
    Finally got a little time in the shop today after a week of recovery and honey-do’s.
    Couldn’t run the brake lines when the cab was off since the brakes weren’t on, and now I paid the penalty.
    It was a REAL PITA getting underneath and connecting the m/cyl. to the line and residual I had run back from the left front. Tube crossmembers and no room made it worse.
    A coat hanger helped to make up one out of some s**** tubing (don’t throw anything away), then the final piece which fit perfectly. Front system is DONE!
