Projects Nate’s 32 roadster build
Discussion in 'Traditional Hot Rods' started by heyitsnate, Nov 17, 2020.
  1. heyitsnate
    heyitsnate
    Nah, I never did intend to convert my 36 to 3w , was just going to chop it . In any case this is my only project now.
    Hot Rod Ron and loudbang like this.
  2. heyitsnate
    heyitsnate
    I drew the dash out and converted it to a vector, then had a local place do an etching process they use for doing photos onto shiny metal. As I understand it the traditional etch has a flat look, and doesn’t stick well to polished surfaces . After it’s etched it gets cut out of the sheet with a cnc router. Thankfully it fit really well. It was an ordeal trying to make it right, mostly because I had to enlarge the holes on my prewar panel to fit the later gauges, so NOTHING was really symmetrical . It’s just minor little differences here and there but when you’re trying to make an accurate digital template it gets real.
  3. heyitsnate
    heyitsnate
    I meant to reply , see above, basically it’s etched
    loudbang and justabeater37 like this.
  4. el Roach
    el Roach
    WOW nice!
    loudbang and heyitsnate like this.
  5. heyitsnate
    heyitsnate
    I’ve barely had time to get to the shop lately, but I have been doing tiny jobs here and there on the dash. That will come back around later. I FINALLY got around to making the floor brackets and doing my trans cover. I still need to do the pedal bumper/tie in plate (if anyone has any ideas how I’d love to hear it) but looking forward to being done with the floors. I also welded the original seat holes up . D8CE4528-862D-41DA-AAE8-4187CEB9BB4B.jpeg E619E177-C0B1-4F37-9D4A-8D5F2BD91AF6.jpeg 5DDA9C3C-3564-406C-9CBD-B68F1669EBC7.jpeg D42AF42D-C6DC-4B3C-9F6C-C2A12DCD99D9.jpeg 11731648-8822-4871-A146-CB7D4E207069.jpeg
  6. heyitsnate
    heyitsnate
    I was having a hard time getting my seat cushions done so I figured I could just make a pattern from scraps to bring to my seat dude. I got some vintage upholstery books that have awesome info about seat geometry, pleat widths and lots of other useful info about 1930s cars . 4BDBABE0-E0D1-4FCE-B084-C36056B8C52C.jpeg 27AD1434-66AF-4E70-9C47-08032ADBF18B.jpeg 8EDDD113-D346-4DBA-829A-D8781E43C452.jpeg 9B87ADDF-6861-44BC-A371-BE4362117DE2.jpeg
  7. NJ Don
    NJ Don
    Looks like you'll have good lumbar support, that's what's missing on the Glide seat in my '32.
    Nice job on all the work!
  8. That dash is stunning! You have some amazing talent.
    Stogy, loudbang and heyitsnate like this.
  9. sloppy jalopies
    sloppy jalopies
    i didn't see it, but to cut foam like that i use an electric turkey carving knife...
  10. SPEC
    SPEC
    Great build.
  11. heyitsnate
    heyitsnate
    I used a vertical bandsaw but the carving knife works well too , especially in corners .
    Stogy and loudbang like this.
  12. heyitsnate
    heyitsnate
    Oh I don’t know about the talent part. I think I’m just stubborn, but thanks!
    -Brent-, NoSurf, Stogy and 1 other person like this.
  13. nice work ! I'll come by in the 36 .. dash insert is killer
  14. heyitsnate
    heyitsnate
    I made a plate for the bottom of the floor that will sandwich some rubber and help keep fumes and BS out of my car , glad to be done with the floors ( except a few finishing details ) 27EF935E-0882-48BD-B31D-BD514A941D0C.jpeg 8B9B668A-E0C9-47ED-A43E-56D74558ADFB.jpeg 1A0FD50F-2C27-4FA7-BD94-B65FBBB7DEE5.jpeg 372C1895-4EE9-4F86-A52E-9ADC61BEA203.jpeg
  15. heyitsnate
    heyitsnate
    2ECC1D10-58C6-49D7-B301-0B4CB9299DAC.jpeg 83984653-E07D-4C7B-8849-E682DF5735B7.jpeg EB51D136-5D9C-45D3-8FB5-25A21B4682AE.jpeg D02FBA47-8597-47A0-B2CD-6C7259DAEA33.jpeg 4377ADD4-3CF3-4AEA-8E36-B93A58E83AD0.jpeg 3E3ADA37-F5DF-4CFD-91AF-23632C0AC8E6.jpeg 44ABCD29-E80C-4FB6-9F1E-7130C405D90E.jpeg Once the plate was made , i route red the shape of it into the wood so when it’s got the rubber mounted the floor stays flat. Once I did all that I figured I’d macke a trim piece for my column at the floor which also would strengthen the floor pieces . I made a quick tool to find the column center. Also I’ve been busy Block sanding my dash getting ready to paint it. Along the way I wasn’t happy with the column drop extension so I made another. Lots of little jobs happening
  16. Stovebolt
    Stovebolt
    Extraordinary build, thanks for sharing your progress through this incredible journey.
    Stogy, heyitsnate and loudbang like this.
  17. heyitsnate
    heyitsnate
    Well not much has happened since the last update. I moved to Oceanside California , now I’m in a race to beat the rust! Before I left though I got my windshield frame back from chrome plating.
  18. 1-SHOT
    1-SHOT
    from Denton
    Nice looking windshield frame. Even nicer view of the ocean.
  19. Travis latour
    Travis latour
    from Putnam CT
    WOW i cant wait to see more! lots of inspiration here!
  20. Eric16
    Eric16
    Sorry if this was brought up already, but what tire sizes are you running? Love the look of what ever combo you were running when you were testing out how the tire fit in the fender.
  21. heyitsnate
    heyitsnate
    760-16 rears and 6.00-16 fronts
  22. heyitsnate
    heyitsnate
    Started taking the car apart to get it at least put in primer. . Then I installed the outer door handles. Wasn’t too difficult, I’d already made the pilot holes. 9D0EFC4C-F89F-4EF2-891C-54737C778130.jpeg 767B87F4-9992-4E90-ACDB-8A46B02D5FCE.jpeg 6397E831-69E6-4048-ABE9-D33FA51EA369.jpeg 2A45C6FB-A6B8-4537-B070-56F174B8EBB9.jpeg 98992CFF-2F80-481E-A632-B3CE1BBEAE6B.jpeg A7B97359-D334-44B7-88F9-B27F912E32B9.jpeg
    Fordors, Stogy, Shadow Creek and 3 others like this.
  23. NealinCA
    NealinCA
    Your project is looking great. Lot's of neat ideas and craftmanship going on there.
    FYI, this dash example is 31 Cadillac...
    I have that same dash in my 32 closed cab pickup.
    Neal
  24. heyitsnate
    heyitsnate
    Love it Neal, thank you for the kind words !
  25. coming along.... In want to see that dash once its finished.. gonna be neat !
  26. heyitsnate
    heyitsnate
    Had all the bits for it plated at art brass, looking forward to wrapping it up!
  27. Art Brass no better people to do chrome around here.
  28. Deuce Daddy Don
    Deuce Daddy Don
    Great pix!!!-----Good luck on running that '39 box!---Gave up on mine after the first 100 miles.
  29. heyitsnate
    heyitsnate
    Fingers crossed
  30. heyitsnate
    heyitsnate
    770A5B65-B2F5-4886-BF38-A37D78C2F50B.jpeg F5A969F8-949F-45A6-8BD9-7E32019F6A7F.jpeg 77064E17-6C3C-4623-8F4E-E141C3F7B74F.jpeg FD627E32-1902-4A5C-9917-9A2D74CF4E31.jpeg B1AD68BC-ADA3-44E6-AB86-CF18327DB90E.jpeg 7A89FA5D-D2A6-4C31-A7B3-4C1890BE74EB.jpeg 868B336E-4E88-406E-A1E0-E1E1CD78D536.jpeg 902B5264-A3D7-4133-BF9A-C262B3AEFDE5.jpeg 053678E9-2B9D-4F0B-BD97-38F2EF348FD1.jpeg F35C11EB-8DCE-44ED-88B3-A019E6577502.jpeg 4D8BBBDD-B6CF-4B90-B7A4-1E88FE89818C.jpeg 5F7948EE-BBFD-40A1-833A-602DA0B6C496.jpeg 29FEC91D-5E8D-46B2-A4E2-165E7A9D5379.jpeg Filled a million holes in the firewall, then addressed the taillights. Marshall Woolery made these rad mini E+j taillights. I made some filler panels and got them all set up. Follow along.
