Art & Inspiration Just Louvers////////
Discussion in 'The Hokey Ass Message Board' started by Stogy, Aug 1, 2016.
  1. loudbang
  2. loudbang
  3. loudbang
  4. Stogy
    Stogy
    https://www.google.com/amp/s/inthegaragemedia.com/follow-the-dust-trail/?amp
    :rolleyes:...The Pierson Brothers were a very influential team and this Knockout Coupe did 140mph or so helping solidify that...I believe both Original Coupes still exist with this Incredible Capture above taken by Tim Sutton aka @notrod13...
    Must be surreal the mix of greatness enveloping the soul in many of these projects you undertake...
    Credit to Photographer, Owner
  5. Small heat shield I did for under a 32 Pickup .
    The machine I have for this is a Vibro-Shear , similar to the Pullmax.
    Shrappy
  6. loudbang
    Real nice. :) Like them better than all the same size.
    j hansen, Lil32, Stogy and 1 other person like this.
  7. loudbang
  8. Stogy
    Stogy
    Nice work @Shrapnel, is that all done with one die or several?
  9. Cheers Loudbang.
    These are cut to length , as opposed to punched at a set size .
    Takes 4 or 5 passes to cut and shape each louver.
    Shrappy
    john worden, loudbang and Stogy like this.
  10. Cheers Stogy.
    These ones are cut to length , not punched .
    Upper Tool is like a 1” long punch , lower Tool is also 1” long but has open ends to allow for the length of cut to be made .
    Takes 4 or 5 passes to cut and shape each louver .
    Not the quickest of process’s , but means than can be almost any length.
    Shrappy
    hfh, loudbang and Stogy like this.
  11. Stogy
    Stogy
    Cheers Shrappy...Such an interesting way to form Louvers...How old is that method of forming? For all I know it might be the original...
    Lil32 and loudbang like this.
  12. Stogy
    Stogy
    :rolleyes:...The Art of Hotrod...
    a powerhouse in perfection...the Lou Bingham Coupe...
  13. Stogy
    Stogy
  14. See if this works Stogy . It’s a link to a video of louvers being cut into a panel.
    The method of cutting louvers has been around a long time .
    If you look close , you’ll see him adjust the bottom die up (Lifting the panel) after each pass , making the louver shape deeper with each pass.
    Some guys will do the cut in one pass , but this can often mean there’s more work required to tidy up the louver .
    Hope this helps
    Shrappy
  15. Stogy
    Stogy
    :rolleyes:...Thanks for sharing that @Shrapnel...in metal shop we had a pullmax...we used it for shearing and dishing metal...It's obviously a very diverse machine...that's really cool...
    Is that a Roof being punched?
  16. All Good Stogy.
    I’m not sure what panel that is . It’s a random video I found on line .
    Yeah , the Pullmax and Vibro-Shear are both very versatile machines .
    Shrappy
  17. Stogy
    Stogy
    Shrappy I'm eyeing your Avatar...You look to have 1955 Covered in Period Hotrod...;)...please share a favorite pic...any louvers? Cheers Mate...
  18. loudbang
    Man those hood ones are CLOSE together. :eek:
  19. Stogy
    Stogy
    It suits it very well including the angle...
    Looks possibly from Downunder noting the close ratio fenders...
  20. loudbang
  21. loudbang
  22. 7273D89B-EAF6-428B-9EA9-8B8B15E4EDE5.jpeg A9FCFE65-6E63-4F46-8052-9517E6700B15.jpeg
    Our Roadster from behind.
    This car was first built as a Track Nosed T . Unfortunately the trunk lid is the only louvered panel left from its previous Track Nose Life .
    Hood Top and Sides , Rolled pans etc , all of which were louvered using a Vibro-Shear to cut them in 1980ish , have all long gone at the hands of previous owners to us .
    Shrappy
  23. Stogy
    Stogy
    Lil32, Shrapnel, Bowtie Coupe and 5 others like this.
  24. Stogy
    Stogy
  25. loudbang
  26. loudbang
  27. loudbang
  28. loudbang
  29. loudbang
    Never seen them in this orientation. :)
    posted by @59FORD in the mild custom thread
    Lil32, Bowtie Coupe, alfin32 and 7 others like this.
  30. Stogy
    Stogy
